  3. Message is send twice
27 Posts 4 Posters 7.0k Views 4 Watching
  • E
    E
    esawyja
    Hi all,
    I'm trying to detect when my generator runs, the external detection circuit works with no problems, but when the ProMini starts, it sends the message twice to the controller, although there was not a state change, see me code below
       bool tripped = digitalRead(GENERATOR_PIN) == HIGH;
      wait(1000);
      if (tripped == 0) {
        wait(5000);
        Serial.println("Generator RUNNING");
        send(msgGENERATOR.set(1));
        sleep(digitalPinToInterrupt(GENERATOR_PIN), CHANGE, SLEEP_TIME);
        //send(msgGENERATOR.set(tripped?"1":"0"));
      if (tripped == 1) {
        Serial.println("Generator NOT running - Not sending");
        wait(5000);
          if (tripped == 1) {
            Serial.println("Generator NOT running - SENDING....");
            send(msgGENERATOR.set(0));
    The serial port output demonstrate the problem, I'm checking twice if the generator is running, but it does not seem to break out of the loop, any help please!!
    0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1
    4 TSM:INIT
    4 TSF:WUR:MS=0
    8 TSM:INIT:TSP OK
    10 TSM:INIT:STATID=11
    12 TSF:SID:OK,ID=11
    14 TSM:FPAR
    145 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    587 TSF:MSG:READ,0-0-11,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    593 TSF:MSG:FPAR OK,ID=0,D=1
    2152 TSM:FPAR:OK
    2152 TSM:ID
    2154 TSM:ID:OK
    2156 TSM:UPL
    2164 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2215 TSF:MSG:READ,0-0-11,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2222 TSF:MSG:PONG RECV,HP=1
    2224 TSM:UPL:OK
    2226 TSM:READY:ID=11,PAR=0,DIS=1
    2238 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2289 TSF:MSG:READ,0-0-11,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2304 TSF:MSG:SEND,11-11-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    2320 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4335 TSF:MSG:SEND,11-11-0-0,s=6,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4349 TSF:MSG:SEND,11-11-0-0,s=7,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
    4358 MCO:REG:REQ
    4368 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4417 TSF:MSG:READ,0-0-11,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    4423 MCO:PIM:NODE REG=1
    4427 MCO:BGN:STP
    5427 MCO:BGN:INIT OK,TSP=1
    11440 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
    11446 MCO:SLP:MS=3600000,SMS=0,I1=1,M1=2,I2=255,M2=255
    11452 MCO:SLP:TPD
    11454 MCO:SLP:WUP=1
    17469 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
    17475 MCO:SLP:MS=3600000,SMS=0,I1=1,M1=2,I2=255,M2=255
    17481 MCO:SLP:TPD
      Try adding some more debug prints of variables on serial an try to understand why it loops twice
      • core_cC
        core_cC
        core_c
        From your log i can see that your node goes to sleep, and immediately wakes up again.
        I don't know the value of your SLEEP_TIME, but i guess it's not a value close to 0.
        It looks like your sleep() cycle is interrupted by a change on your GENERATOR_PIN.
        What if you inserted a short pause just before going to sleep, just after send(msgGENERATOR)?
        Another way to handle interrupts:
        Your code uses an interrupt to detect changes of the generator status, but you handle possible changes outside the interrupt-handler (the code that is executed whenever there was a change on the pin). Your sleep function can exit in two ways: by interrupt OR by the SLEEP_TIME expiring. Your code does the same in both cases. Even if there was no change on the pin, but the timer expired, a message will be send.
        If you only want to send a message when there was actually a change of signal on the pin, i would use an interrupt-handler that detects any change, and let the loop() code know about it.
        volatile bool generator_pin_changed = false;
        volatile int generator_pin_value;
        void generator_pin_interrupt_handler() {
          generator_pin_changed = true;
          generator_pin_value = digitalRead(GENERATOR_PIN);
          attachInterrupt(digitalPinToInterrupt(GENERATOR_PIN), generator_pin_interrupt_handler, CHANGE);
          if (generator_pin_changed) {
            generator_pin_changed = false;  /* reset for next detection */
            if (generator_pin_value == LOW) {
            } else {
          wait(200);
          /* sleep again if the timer expired. stop sleeping if woken up by an interrupt. */
          while (sleep(digitalPinToInterrupt(GENERATOR_PIN), CHANGE, SLEEP_TIME) < 0);
        E 1 Reply Last reply
        • core_cC core_c
              } else {
            wait(200);
          E
          E
          esawyja
          @core_c Thanks so much, this did the trick, thanks again!!!
          • E esawyja
            E
            E
            esawyja
            @core_c I spoke to soon, looks like it detects the change, but does not do anything, I made the unsigned long SLEEP_TIME = 0;
            4 TSM:INIT
            4 TSF:WUR:MS=0
            8 TSM:INIT:TSP OK
            12 TSF:SID:OK,ID=11
            14 TSM:FPAR
            405 TSF:MSG:READ,0-0-11,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            411 TSF:MSG:FPAR OK,ID=0,D=1
            2152 TSM:FPAR:OK
            2152 TSM:ID
            2154 TSM:ID:OK
            2156 TSM:UPL
            2224 TSM:UPL:OK
            4358 MCO:REG:REQ
            4427 MCO:BGN:STP
            interupt
            5429 MCO:BGN:INIT OK,TSP=1
            5441 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
            5648 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
            5652 MCO:SLP:TPD
            5654 MCO:SLP:WUP=1
            5857 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
            5861 MCO:SLP:TPD
            5863 MCO:SLP:WUP=1
            6066 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
            6070 MCO:SLP:TPD
            core_cC 1 Reply Last reply
              Why sleep time = 0?
              • E esawyja
                4 TSM:INIT
                4 TSF:WUR:MS=0
                8 TSM:INIT:TSP OK
                12 TSF:SID:OK,ID=11
                14 TSM:FPAR
                2152 TSM:FPAR:OK
                2152 TSM:ID
                2154 TSM:ID:OK
                2156 TSM:UPL
                2224 TSM:UPL:OK
                4358 MCO:REG:REQ
                4427 MCO:BGN:STP
                interupt
                5652 MCO:SLP:TPD
                5654 MCO:SLP:WUP=1
                5861 MCO:SLP:TPD
                5863 MCO:SLP:WUP=1
                6070 MCO:SLP:TPD
                core_cC
                core_cC
                core_c
                @esawyja I don't really know what your goal is, but is it correct to send a 1 if the generator is running, and to send a 0 when it's not running?
                It seems more logical to send a 1 to enable a device, and 0 to disable it.
                Could it be that you disable the generator, and it simply is not responding anymore?
                • E
                  E
                  esawyja
                  @core_c Hi
                  Does it really matter, it's just the way the external circuitry is set up, it pulls to a low when the generator is running, I get get it working with this below, but I'm afraid my coding skills are not that good
                     Serial.print("value of tripped = ");
                     Serial.println(tripped);
                     wait(1000);
                     if ((tripped == 0) && ( tripped != oldValue)) {
                        Serial.println("Generator RUNNING - Not sending");
                        wait(1000);
                        if (tripped == 0) {
                          Serial.println("Generator RUNNING - SENDING");
                          wait(10000);
                          oldValue = tripped;
                          read_batt();
                    if ((tripped == 1) && ( tripped != oldValue)) {
                      wait(1000);
                      if (tripped == 1) {
                          wait(10000);
                          oldValue = tripped;
                          read_batt();
                  void read_batt() {
                    wait(15000);
                    float batteryV = sensorValue * volt_value;
                    send(batt_msg.set(batteryV,2));
                    return;
                  • E esawyja
                    @core_c Hi
                       wait(1000);
                          wait(1000);
                          if (tripped == 0) {
                            wait(10000);
                            oldValue = tripped;
                            read_batt();
                        wait(1000);
                        if (tripped == 1) {
                            wait(10000);
                            oldValue = tripped;
                            read_batt();
                    void read_batt() {
                      wait(15000);
                      return;
                    core_cC
                    core_cC
                    core_c
                    @esawyja No, it does not matter if it's active low or active high. I was only thinking that it could be an oversight.. something wrong in code that someone (possibly) keeps missing because they are assuming that that part of the code is correct.
                    About what you said previously: "looks like it detects the change, but does not do anything":
                    Correct me if i'm wrong, but this looks like it detects, and does something:
                    interupt
                    After that, when the generator did not change state anymore, you will see a stream of only sleep/wake-up messages (a stream, because sleeptime is 0). I see that stream start at 5648.
                    In your current program, i'm curious if that second send() is really needed (the last send in the "send,wait(10000),send" sequence).
                    But anyway, your skills got it working.. :heavy_check_mark:
                    • core_cC core_c
                      interupt
                      E
                      E
                      esawyja
                      @core_c thanks, just a bit worried about my programming skills, yes the reason for the double send is that sometimes I get st=NACK and I'm worried about missing the start , stop message, hence I send the message twice, I don't know how to detect the st=NACK, thanks for the help
                      Boots33B 1 Reply Last reply
                      • E esawyja
                        Boots33B
                        Boots33B
                        Boots33
                        @esawyja send will return a boolean result which you can use to determine if the message was successful. For an example have a look at this post
                        • Boots33B Boots33
                          E
                          E
                          esawyja
                          @Boots33 Thanks so much, I'll have a look
                          • E esawyja
                            core_cC
                            core_cC
                            core_c
                            wrote on last edited by core_c
                            @esawyja In your last program, your battery level is only send when the generator changed state.
                            Probably you want to let the battery report it's level at regular intervals, independent of the generator state.
                            Boots33 pointed out how to know if a message has been sent succesfully.
                            Here is a version of your sketch that does both things:
                            #define RETRY_TIMES 3
                            #define RETRY_WAIT 10000
                            #define BATTERY_REPORT_INTERVAL 60000
                            int oldValue;
                            uint32_t battery_report_time;
                              oldValue = digitalRead(GENERATOR_PIN);
                              sendGeneratorMsg(oldValue==HIGH?0:1);
                              battery_report_time = millis() + BATTERY_REPORT_INTERVAL;
                              int value = digitalRead(GENERATOR_PIN);
                              if (value != oldValue) {
                                oldValue = value;
                                if (value == LOW) {
                                  sendGeneratorMsg(1);
                                } else {
                                  sendGeneratorMsg(0);
                              long sleep_time_left = battery_report_time - millis();
                              if (sleep_time_left < 0) {
                                sleep_time_left = BATTERY_REPORT_INTERVAL;
                                read_batt();
                              sleep(digitalPinToInterrupt(GENERATOR_PIN), CHANGE, sleep_time_left);
                            void sendGeneratorMsg(int state) {
                              for (int i=0; i<RETRY_TIMES; i++) {
                                if (send(msgGENERATOR.set(state))) {
                                  Serial.println("Generator message sent");
                                  return;
                                wait(RETRY_WAIT);
                              Serial.println("Failed to send generator message");
                            void read_batt() {
                              wait(15000);
                            EDIT: I have changed ^^the code^^ with the suggestions i made in my next post.
                            • E
                              E
                              esawyja
                              @core_c thanks so much, I will try it ASAP and provide feedback, thanks again!
                              • E esawyja
                                E
                                E
                                esawyja
                                @core_c This works a treat, but I don't get the battery readings, if I look at the debug log, the MS seems to become quite large
                                71362 MCO:SLP:MS=9681,SMS=0,I1=1,M1=1,I2=255,M2=255
                                71366 MCO:SLP:TPD
                                71370 MCO:SLP:WUP=-1
                                71372 MCO:SLP:MS=9671,SMS=0,I1=1,M1=1,I2=255,M2=255
                                71378 MCO:SLP:TPD
                                71380 MCO:SLP:WUP=1
                                71383 MCO:SLP:MS=9660,SMS=0,I1=1,M1=1,I2=255,M2=255
                                71389 MCO:SLP:TPD
                                71391 MCO:SLP:WUP=1
                                71401 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
                                81424 MCO:SLP:MS=4294966915,SMS=0,I1=1,M1=1,I2=255,M2=255
                                81430 MCO:SLP:TPD
                                81432 MCO:SLP:WUP=1
                                81434 MCO:SLP:MS=4294966905,SMS=0,I1=1,M1=1,I2=255,M2=255
                                81440 MCO:SLP:TPD
                                81444 MCO:SLP:WUP=1
                                81498 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
                                91521 MCO:SLP:MS=4294956818,SMS=0,I1=1,M1=1,I2=255,M2=255
                                91527 MCO:SLP:TPD
                                Any suggestions please?
                                • E esawyja
                                  71366 MCO:SLP:TPD
                                  71378 MCO:SLP:TPD
                                  71380 MCO:SLP:WUP=1
                                  71389 MCO:SLP:TPD
                                  71391 MCO:SLP:WUP=1
                                  81430 MCO:SLP:TPD
                                  81432 MCO:SLP:WUP=1
                                  81440 MCO:SLP:TPD
                                  81444 MCO:SLP:WUP=1
                                  91527 MCO:SLP:TPD
                                  E
                                  E
                                  esawyja
                                  @core_c Sorry me again, here I made
                                  #define BATTERY_REPORT_INTERVAL 2000
                                  and printed the value
                                  Serial.print("Battery report time is = ");
                                  Serial.println(battery_report_time);
                                  It looks like the sleep uses the time left over, as it prints faster and faster on the serial port and then the MS value just increases 10 fold
                                  21035 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
                                  Battery report time is = 23043
                                  21043 MCO:BGN:INIT OK,TSP=1
                                  21049 MCO:SLP:MS=1994,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  21053 MCO:SLP:TPD
                                  21057 MCO:SLP:WUP=1
                                  21059 MCO:SLP:MS=1984,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  21065 MCO:SLP:TPD
                                  21067 MCO:SLP:WUP=-1
                                  21069 MCO:SLP:MS=1974,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  21075 MCO:SLP:TPD
                                  21078 MCO:SLP:WUP=-1
                                  21080 MCO:SLP:MS=1963,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  21086 MCO:SLP:TPD
                                  21088 MCO:SLP:WUP=-1
                                  21092 MCO:SLP:MS=1951,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  21096 MCO:SLP:TPD
                                  21100 MCO:SLP:WUP=-1
                                  22878 MCO:SLP:MS=165,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22882 MCO:SLP:TPD
                                  22884 MCO:SLP:WUP=-1
                                  22888 MCO:SLP:MS=155,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22892 MCO:SLP:TPD
                                  22896 MCO:SLP:WUP=-1
                                  22898 MCO:SLP:MS=145,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22904 MCO:SLP:TPD
                                  22906 MCO:SLP:WUP=-1
                                  22908 MCO:SLP:MS=135,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22915 MCO:SLP:TPD
                                  22917 MCO:SLP:WUP=-1
                                  22919 MCO:SLP:MS=124,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22925 MCO:SLP:TPD
                                  22927 MCO:SLP:WUP=-1
                                  22931 MCO:SLP:MS=112,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22935 MCO:SLP:TPD
                                  22937 MCO:SLP:WUP=-1
                                  22941 MCO:SLP:MS=102,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22945 MCO:SLP:TPD
                                  22947 MCO:SLP:WUP=-1
                                  22951 MCO:SLP:MS=92,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22958 MCO:SLP:TPD
                                  22960 MCO:SLP:WUP=-1
                                  22962 MCO:SLP:MS=81,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22968 MCO:SLP:TPD
                                  22970 MCO:SLP:WUP=-1
                                  22972 MCO:SLP:MS=71,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22978 MCO:SLP:TPD
                                  22980 MCO:SLP:WUP=-1
                                  22982 MCO:SLP:MS=61,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22988 MCO:SLP:TPD
                                  22990 MCO:SLP:WUP=-1
                                  22992 MCO:SLP:MS=51,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  22999 MCO:SLP:TPD
                                  23001 MCO:SLP:WUP=-1
                                  23005 MCO:SLP:MS=38,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  23009 MCO:SLP:TPD
                                  23011 MCO:SLP:WUP=-1
                                  23015 MCO:SLP:MS=28,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  23019 MCO:SLP:TPD
                                  23021 MCO:SLP:WUP=-1
                                  23025 MCO:SLP:MS=18,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  23029 MCO:SLP:TPD
                                  23031 MCO:SLP:WUP=-1
                                  23035 MCO:SLP:MS=8,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  23040 MCO:SLP:TPD
                                  23044 MCO:SLP:WUP=-1
                                  23046 MCO:SLP:MS=4294967293,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  23052 MCO:SLP:TPD
                                  After this, there is nothing more on the serial port
                                  • E esawyja
                                    21053 MCO:SLP:TPD
                                    21057 MCO:SLP:WUP=1
                                    21065 MCO:SLP:TPD
                                    21075 MCO:SLP:TPD
                                    21086 MCO:SLP:TPD
                                    21096 MCO:SLP:TPD
                                    22882 MCO:SLP:TPD
                                    22892 MCO:SLP:TPD
                                    22904 MCO:SLP:TPD
                                    22915 MCO:SLP:TPD
                                    22925 MCO:SLP:TPD
                                    22935 MCO:SLP:TPD
                                    22945 MCO:SLP:TPD
                                    22958 MCO:SLP:TPD
                                    22968 MCO:SLP:TPD
                                    22978 MCO:SLP:TPD
                                    22988 MCO:SLP:TPD
                                    22999 MCO:SLP:TPD
                                    23009 MCO:SLP:TPD
                                    23019 MCO:SLP:TPD
                                    23029 MCO:SLP:TPD
                                    23040 MCO:SLP:TPD
                                    23052 MCO:SLP:TPD
                                    core_cC
                                    core_cC
                                    core_c
                                    @esawyja You are right. I made a mistake. This should fix it:
                                    Change this line:
                                    uint32_t sleep_time_left = battery_report_time - millis();
                                    into this:
                                    A variable of type long can hold a negative number, but an unsigned long (same as uint32_t) can never hold a negative number (because it is unsigned, no sign, no minus sign, no negative).
                                    So, if (sleep_time_left < 0) will never be true.. That was the mistake.
                                    I was also wondering if the generator would produce interrupts without using attachInterrupt().
                                    Without that, you can still poll the generator pin, and see if the value changed (what is happening now), but the sleep() cycle would not be interrupted when the pin changed.
                                    To be on the safe side, i would also add the following to your code:
                                    Hopefully that'll make it work as intended.
                                    • core_cC core_c
                                      Change this line:
                                      into this:
                                      E
                                      E
                                      esawyja
                                      wrote on last edited by esawyja
                                      @core_c Thanks for that
                                      I had to change the battery reading routine to this below, else when it gets to the routine, it stays there and never get back to the loop, I hope it makes sense
                                      void read_batt() {
                                        wait(15000);
                                        return;
                                      If I add this to setup, I get the following error
                                      gen_run_sketch:54: error: 'generator_pin_interrupt_handler' was not declared in this scope
                                      exit status 1
                                      • E esawyja
                                        void read_batt() {
                                          wait(15000);
                                          return;
                                        exit status 1
                                        core_cC
                                        core_cC
                                        core_c
                                        @esawyja attachInterrupt() should only be done once, in the setup() function.
                                        • core_cC core_c
                                          E
                                          E
                                          esawyja
                                          @core_c I'm sorry I do not understand, must I replace this in loop
                                          With this in setup?
                                          Sorry for all the questions!! This is sooo confusing to me, it also seems that the battery level is not sending, I left it running for 12 hours plus and never got a reading, the line
                                          Does this define that the battery level must be send ever 60000 milli seconds?
