  3. Debug messages over Wi-Fi
7 Posts 5 Posters 3.0k Views 8 Watching
    marceloaqno
    Code Contributor
    I wrote a library to be able to watch the debug messages from a ethernet gateway over Wi-Fi (or ethernet).
    It opens port 2300, so you can connect with putty (change the "Connection type" to Telnet or Raw).
    If anyone is interested, here is the code: https://github.com/marceloaqno/MyNetDebug
    To use it, add the following lines in your sketch before MySensors.h
    #include <MyNetDebug.h>
    #define MY_SERIALDEVICE NetDebug
    And into your loop function:
      (void)NetDebug.available();
    For more details, please check the examples.
    alexsh1A 1 Reply Last reply
    • M marceloaqno
      alexsh1A
      alexsh1A
      alexsh1
      @marceloaqno interesting. Did you try it on atmega328p only? Other MCU?
      • R
        R
        ricorico94
        Your initiative seems a bright idea, thanks for that !
        I tried your library to debug a gateway on a wemos D1 mini with Mysensors 2.3.0, but I got error messages when compiling. Maybe it's because I didn't follow proper installation of your library as I'm not friendly with Arduino IDE library system.
        I did symply download your folders from github and installed Mynetdebug-master folder in same folder than Mysensors library folder. IN the Mynetdebug folder, I have a keywords.txt file and a library.json and library.master, and a src folder where I have the .cpp and .h files.
        Is it correct ?
        I used your example for ESP8266 to modify my working gateway .ino.
        Then, when I compiled, I got following error messages:
        Arduino: 1.8.5 (Windows 7), Board: "WeMos D1 R2 & mini, 80 MHz, 115200, 4M (3M SPIFFS)"
        WARNING: Category 'MySensors' in library MyNetDebug is not valid. Setting to 'Uncategorized'
        In file included from d:\userdata\myname\My Documents\Arduino\libraries\MySensors/MySensors.h:212:0,
                         from D:\userdata\myname\My Documents\Arduino\LoraGTWperso04Mynetdebug\LoraGTWperso04Mynetdebug.ino:67:
        d:\userdata\myname\My Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportInit()':
        d:\userdata\myname\My Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:28:22: error: 'MY_ESP8266_SSID' was not declared in this scope
         #define MY_WIFI_SSID MY_ESP8266_SSID
        d:\userdata\myname\My Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:163:19: note: in expansion of macro 'MY_WIFI_SSID'
          (void)WiFi.begin(MY_WIFI_SSID, MY_WIFI_PASSWORD, 0, MY_WIFI_BSSID);
        d:\userdata\myname\My Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:34:26: error: 'MY_ESP8266_PASSWORD' was not declared in this scope
         #define MY_WIFI_PASSWORD MY_ESP8266_PASSWORD
        d:\userdata\myname\My Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:163:33: note: in expansion of macro 'MY_WIFI_PASSWORD'
        exit status 1
        Error compiling for board WeMos D1 R2 & mini.
        option enabled in File -> Preferences.
        Can you help me ?
        br,
        Ricorico94
        • R ricorico94
          Is it correct ?
          exit status 1
          Can you help me ?
          br,
          Ricorico94
          @ricorico94 did you define these in your sketch, before including MySensors.h?
          #define MY_ESP8266_SSID "MySSID"
          #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
          • R
            R
            ricorico94
            Thanks for your help.
            Yes, I defined them before the Mysesnors.h.
            here's my ino (I anonymised ssid and password):
            // Application details
            #define APPLICATION_NAME    "Gateway RFM95 Eric"
            #define APPLICATION_VERSION "0.0.0.Beta Eric"
            #define MY_BAUD_RATE 115200
            #define   MY_RADIO_RFM95
            #define   MY_DEBUG_VERBOSE_RFM95
            //#define   MY_DEBUG_VERBOSE_RFM95_REGISTERS
            //#define MY_RFM95_ATC_TARGET_RSSI (-70)  // target RSSI -70dBm
            //#define   MY_RFM95_MAX_POWER_LEVEL_DBM (20)   // max. TX power 10dBm = 10mW
            #define   MY_RFM95_FREQUENCY (RFM95_434MHZ)
            //#define   MY_RFM95_MODEM_CONFIGRUATION (RFM95_BW500CR45SF128)
            //below was used in first successful testings then modified to try improving coverage
            //#define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR45SF128
            #define MY_RFM95_MODEM_CONFIGRUATIONRFM95_BW125CR48SF4096
            #define MY_TRANSPORT_STATE_TIMEOUT_MS  (3*1000ul)
            #define RFM95_RETRY_TIMEOUT_MS  (3000ul)
            #define   MY_RFM95_IRQ_PIN 5
            #define   MY_RFM95_IRQ_NUM MY_RFM95_IRQ_PIN
            #define   MY_RFM95_CS_PIN 15
            #define MY_GATEWAY_ESP8266
            // Set WIFI SSID and password
            #define MY_ESP8266_SSID "nameofmywifi"
            #define MY_ESP8266_PASSWORD "mypassword"
            #define MY_HOSTNAME "lora-gateway"
            #define MY_PORT 5003
            //added for MyNetdebug
            #if defined(MY_USE_UDP)
            #include <WiFiUdp.h>
            // end added for Mynetdebug
            #include <ESP8266WiFi.h>
            //added for Mynetdebug
            // end added
              //all block below added for Mynetdebug
                 // Echo all data sent by the debug client
              NetDebug.echo(true);
              // Send a carriage return before each line feed
              NetDebug.crBeforeLF(true);
              // If you want the debug message to also be sent to Serial port
              NetDebug.mirror(&Serial);
              // Initialize the serial port if you plan to use it in your sketch or if you are using the mirror function
              // MySensors usually does this for us, however, since we've set up our serial device to be NetDebug,
              // we have to do it ourselves
              Serial.begin(MY_BAUD_RATE);
              // end added Mynetdebug
              sendSketchInfo(APPLICATION_NAME, APPLICATION_VERSION);
            For your info, before I make these changes, it was compiling OK. My changes are embedded within the comments "added for Mynetdebug".
            In IDE, I use the setting wemos D1R2 & mini, 80MHz and "4M(3M SPIFFS)".
            Maybe I installed the library i a wrong manner ? Shoudl I move the .h and .cpp one level up in folders ?
            Thanks,
            • R
              R
              ricorico94
              wrote on last edited by ricorico94
              I found the cause of the error..
              Since 2.3.0, we shouldn't write anymore:
              but:
              #define MY_WIFI_SSID "MySSID"
              #define MY_WIFI_PASSWORD "MyVerySecretPassword"
              I found because I discovered than compiling was OK with 2.2.0 and not anymore with 2.3.0 (even without the MyNetDebug library) and I looked at the example in the 2.3.0 library..
              I had been misleaded by the fact than in release description, it was stated that 2.3 is backward compatible and that network had not to be modified.. So I had thought that no change was required in the sketch..
              I could test the library MyNetDebug and it seems working: the only thing is that it seems slow. Letters show up one after the other fairly slowly (much more slowly than if Serial Monitor used alone). I hope it's not disturbing radio communication..
              But it's great to be able to catch debug messages without plugging the ESP8266 in a computer ! I'll have to investigate if the debug status can be switched on/off by a remote command to the ESP8266 gateway to avoid overloading the device if not necessary.
              Thanks again for your efforts!
              • electrikE
                electrikE
                electrik
                Hello
                I've tried to use this with an ESP32 (I modified some defines for the architecture, to make it compatible). In MyHwESP32.h I've changed
                #define MY_SERIALDEVICE Serial
                to
                #ifndef MY_SERIALDEVICE
                I think this why it doesn't work for you @ricorico94 with version 2.3 of MySensors.
                It worked sometimes, but usually Putty responds "Network error: Connection refused"
                Any ideas?
