  3. Vera
  4. Vera luup engine rebooting.
1 Posts 1 Posters 1.4k Views 1 Watching
  • S
    stress nero
    wrote on last edited by stress nero
    After adding the sensors to vera edge I started to get random luup engine reboots i am not sure what i need to do to fix that issue. I am using RPI3 ethernet gateway. can one of u seasoned veterans take a look and see if i need to make any adjustments on the code side please. it also says controller did not repond under ALTUI.
    #include <DHT.h>
    #define DIGITAL_INPUT_WATER_SENSOR 5 // Digital input did you attach your soil sensor.
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_MOT 2   // Id of the sensor child
    #define CHILD_ID_LIGHT 3
    #define CHILD_ID_WAT 4      // Child id for Motion
    #define LIGHT_SENSOR_PIN A0 //Ambient light sensor reading
    #define WATER_LEAK_PIN 5
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    uint16_t lastlux;
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
    MyMessage msgWat(CHILD_ID_WAT, V_TRIPPED);
    MyMessage msgLight(CHILD_ID_LIGHT,  V_LIGHT_LEVEL);
    int lastWaterValue = -1;
    int lastLightLevel;
      pinMode(DIGITAL_INPUT_WATER_SENSOR, INPUT);
      pinMode(LIGHT_SENSOR_PIN, INPUT);
      sendSketchInfo("Humidity/Motion", "1.0");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_MOT, S_MOTION);
      present(CHILD_ID_WAT, S_MOISTURE);
      // Read digital motion value
        bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        Serial.println(tripped);
        send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    int WaterValue = digitalRead(DIGITAL_INPUT_WATER_SENSOR); // 1 = Not triggered, 0 = In water
    if (WaterValue != lastWaterValue) {
    Serial.println(WaterValue);
    if (WaterValue==0)
    Serial.println("Water!!!");
    send(msgWat.set("Water"));
    else
    Serial.println("No Water");
    send(msgWat.set("No Water")); // Send tripped when water detected
    lastWaterValue = WaterValue;
         // Read lux from TEMT6000
       uint16_t lightLevel = analogRead(LIGHT_SENSOR_PIN);  // 1000/1024
      if (int(lightLevel - lastLightLevel) > 5 || int(lastLightLevel - lightLevel) > 5) {
          send(msgLight.setSensor(CHILD_ID_LIGHT).set(lightLevel,1));
        sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
