  3. No Auto node id
No Auto node id
nodeidnode id
7 Posts 4 Posters 4.2k Views 2 Watching
  • C
    C
    C.r.a.z.y.
    All of my devices don't get AUTO node id in Vera or openHab.Everytime i write it manually
    in the skech. Is this normal? I couldn't find a solution in the forum.
    D 1 Reply Last reply
    • C C.r.a.z.y.
      D
      D
      doctor64
      wrote on last edited by doctor64
      @C.r.a.z.y.
      I am not use Vera, but OpenHab with MQTT gateway works Ok. Which gateway you using? As i understand, serial and ethernet gateway's does not have such functionality.
      UPD: I may be unclear, sorry, english not my native language. Only MQTT Gateway assign node id's on sensors by itself, Serial and Ethernet gateway does not, and id's should be assigned by controller.
      • C
        C
        C.r.a.z.y.
        Thank you i am using serial so this is why i dont get auto node id.
        funky81F 1 Reply Last reply
          What does the logs say on sensor when your start them the first time (without any id-set).
          • C
            C
            C.r.a.z.y.
            wrote on last edited by C.r.a.z.y.
            Hi hek,
            Orginal Relay sketch;
            repeater started, id 0
            send: 0-0-0-0 s=255,c=0,t=18,pt=0,l=5,st=fail:1.4.1
            send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
            send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=5,st=fail:Relay
            send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
            send: 0-0-0-0 s=1,c=0,t=3,pt=0,l=5,st=fail:1.4.1
            I used orginal motion sensor sketch only change is define CHILD_ID 90
            sensor started, id 0
            send: 0-0-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
            send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=13,st=fail:Motion Sensor
            send: 0-0-0-0 s=90,c=0,t=1,pt=0,l=5,st=fail:1.4.1
            send: 0-0-0-0 s=90,c=1,t=16,pt=0,l=1,st=fail:0
            send: 0-0-0-0 s=90,c=1,t=16,pt=0,l=1,st=fail:1
              wrote on last edited by hek
              Your repeater seems to have problems ack:ing (which also means id won't be transmitted).
              There also is an issue when fetching id via repeater in the current version. Try moving it closer to gateway during the initial id exchange.
              • C C.r.a.z.y.
                funky81F
                funky81F
                funky81
                @C.r.a.z.y. is this confirm? coz i'm having the same problem.
                and Yes, i'm using serial for my gateway and usb for my sensor.
                Please share if there's possible answer for this problem.
                thanks
