  3. GUVA-S12SD UV sensor sketch required
2 Posts 2 Posters 2.7k Views 1 Watching
  • T
    Tommas
    wrote on last edited by Tommas
    Dear All!
    Does anybody have mysensors compatible GUVA-S12SD UV sensor sketch?
    I would like to operate it from 3.3V battery connected to Sensebender MIcro.
    Thank you in advance!
    • scalzS
      scalzS
      wrote on last edited by scalz
      if you're new to MySensors:
      • you can use the light sensor example, change the calculation for your sensor, and also change the msg type to UV. https://www.mysensors.org/build/light-lm393
      • or use and change directly the UV example https://www.mysensors.org/build/uv
      According to adafruit, your calc should look something like that:
      UVindex = (ADC reading * Sensor_VCC / 102.4) where Sensor_VCC in your case would be 3.3V. You might need to adapt for a variable voltage as it will follow the battery voltage.
      In case you have trouble, post your sketch.
