  3. nRF24LE1 full controller to control devices and sensors reading!!
18 Posts 7 Posters 13.9k Views 4 Watching
  • T
    Timurufa
    there is a good Russian project with the compiler
    it makes it possible to create actuators without arduino ... small size and long battery life
    http://homes-smart.ru/index.php/oborudovanie/bez-provodov-2-4-ggts/nrf24le1-nrf24l01-mikrokontroller
    • axillentA
      axillentA
      axillent
      yes, it is cool
      this guy is a member of russian arduino.ru forum
      he also have on the fly generator for the bootloader
      sense and drive
      • T
        Timurufa
        very good project and a very convenient solution to many problems for the project Mysensors!
        need help in adapting nRF24LE1 ( controller ) to the project mysensors
        • daulagariD
          daulagariD
          daulagari
          Yes, very nice IC. From the datasheet:
          Key Features:
          • nRF24L01+ 2.4 GHz transceiver (250 kbps, 1 Mbps and 2 Mbps air data rates)
          • Fast microcontroller (8051 compatible)
          • 16 kB program memory (on-chip OTP)
          • 1 kB data memory (on-chip RAM)
          • 1 kB OTP data memory
          • AES encryption HW accelerator
          • 16-32 bit multiplication/division co-processor (MDU)
          • 6–12 bit ADC
          • High flexibility IOs
          • Serves a set of power modes from ultra low power to a power efficient active mode
          • Several versions in various QFN packages
          There is also a variant that has 16 kB flash instead of OTP.
          16 kB is not that much, would a simple MySensors sensor fit in that?
          • T
            Timurufa
            yes of course!
            Serial Communication Examples from mysensors "12; 6; 0; 0; 3; 1.4\n"
            Serial Communication Examples "1 11 1 205" - that means a command sets the PWM level on 205 on an output of 1 (p0.3). Well to 2 PWM outputs on the radio module: the second is on p0.2 and has an output number 0 (zero).
            and thus the executive unit or the unit of sensors consists a tolkor of nRF24LE1 and the battery
            • T
              Timurufa
              only of nRF24LE1 and the battery
                mitekg
                @hek , is it possible to implement it in mysensor? may be like it was made with "433" sensors?
                  As nRF24LE1 is over-the-air compatible with NRF24L01 the best thing would probably be to send MySensors packages from LE1-nodes.
                  But someone needs to port parts of the MySensors library to AVR.
                  • B
                    B
                    binladin
                    MaksMS the author of homes-smart.ru - http://habrahabr.ru/users/maksms/topics/
                    I am leave a request for mysensors adoptation on the forum - http://homes-smart.ru/index.php/component/kunena/5-soft/106-konstruktor-besprovodnogo-klienta-na-nrf24le1?limit=6&Itemid=0&start=18#625
                    • axillentA
                      axillentA
                      axillent
                      He had replied with request for mysensors protocol specification. Do we have any?
                      sense and drive
                      hekH 1 Reply Last reply
                      • B
                        B
                        binladin
                        I explained at his forum as I could. Maybe it would have made a better programmer. I could to translate this into Russian.
                        By the way, MaxMS developments relating NRF24LE1 are here - https://github.com/maksms/NRF24LE1_client
                        It would be nice if programmers seeing and correctly put questions.
                        • T
                          Timurufa
                          went development of the theme !! it's very good
                          • T
                            Timurufa
                            As the creator of idea promised, he will make the designer especially for mysensors... if it embodies ideas at least of the elementary sensors and switches, it is enough. Idea to umeslit everything in one le1 to benefit battery life and the size, for example to build in the standard switch of ringing type for switching on or a dimmirovaniye of light in the room or generally the miniature long-living temperature sensor or movements
                            • axillentA axillent
                              It is probably easiest to have a look at MyMessage/MySensor classes when doing a port. The over-the-air protocol and behavior isn't super complicated.
                              axillentA 1 Reply Last reply
                                axillentA
                                axillentA
                                axillent
                                @hek Yes, I think so
                                sense and drive
                                  mitekg
                                  ESP8266 support
                                  http://homes-smart.ru/index.php/oborudovanie/bez-provodov-wi-fi
                                  • AnticimexA
                                    AnticimexA
                                    Anticimex
                                    The chip looks nice, however, I am a bit concerned about the AES functionality. I find no mention in the datasheet of key storage. I guess they expect the AES key to be stored in flash but if so, there has to be a way of preventing readout of the flash, since AES is a symmetric-key algorithm, so whoever obtains the key, owns the system.
                                    But apart from this, I am all for RF backend encryption. But if it is sloppily implemented then it is useless in my opinion. But perhaps there are fuses in the chip to prevent readout.
                                    It would be nice to have a single-board option with both RF and a simple MCU. But 32kB flash would be better. Perhaps they will offer a slightly fatter one soon.
                                    EDIT: The specification for the flash-variant does seem to offer some readback protection, so AES should be ok to use on the platform. However, with 16Kb it will be tricky to squeeze in anything more sophisticated than the simplest form of sketch examples I am afraid. For me, the ideal platform would be something that has at least 32Kb flash, readback protection and AES encryption of RF data. That way, both signing and encryption can be used for really hard-core sensitive nodes.
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      They also make a slightly fatter module with USB: http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24LU1P
                                      This puppy does come in 32Kb flash variant.
