  3. Node-RED
  4. Node-red and Check_mk
Scheduled Pinned Locked Moved Node-RED
1 Posts 1 Posters 1.2k Views 1 Watching
  • A
    A
    Arun Dev
    i'm struggling with the communication between node-red and check_mk. The idea was to trigger an event (in check_mk) through a namped_pipe provided by checkmk. Therefore you can write a text message (e.g. '<78>Dec 18 10:40:00 myserver123 MyApplication: It happened again.') locally to the named pipe to trigger an event.
    Now everything should work in a node. The node should check the string for various test criteria and then write the string on the named pipe.
    To transfer the string to the named pipe i used these code-lines:
    var fs = require('fs');
    var writableStream = fs.createWriteStream('/opt/omd/sites/monitoring/tmp/run/mkeventd/events');
    writableStream.write(Msg);
    Now the Problem:
    If i declare the string within the js-file (which i need to create a node) and then transfer it to writableStream.write(); everything works fine and an event in checkmk gets triggered.
    But if im defining a string outside the node (like in an inject-node; msg.payload) and then using it in my node... the triggering fails.
    Here are some Variantes i tried without any success.
    //Var1
    var Msg2 = msg.payload;
    writableStream.write(Msg2);
    //Var2
    writableStream.write(msg.payload);
    //Var3
    Msg2 = Msg2.toString();
    Any advices will be taken with much gratitude :)
    regards
    Arun
