  3. How to implement whatchdog for Arduino Serial Gateway
1 Posts 1 Posters 679 Views 3 Watching
  • S
    sineverba
    Hi to all!
    I would implement a watchdog on the Arduino Serial Gateway connected on my PI.
    You know that gateway sketch basically... does nothing in loop or in setup. It is blank.
    Is sufficient put a watchdog of 1/2 seconds on setup, reset on loop and "forget"?
    I mean...
    //#define MY_DEBUG
    //#define MY_DEBUG_VERBOSE_SIGNING //!< Enable signing related debug prints to serial monitor
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
     * SECURITY // SIGNING SECTION
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
    #include <avr/wdt.h>
     // activate watchdog
     wdt_enable(WDTO_2S);
      // reset watchdog
    wdt_reset();
