  3. Node with DS18B20+Relay dies, also with watchdog
6 Posts 3 Posters 2.4k Views 3 Watching
  • S
    sineverba
    wrote on last edited by sineverba
    Hi to all,
    I have a node with Atmega 8Mhz that sends temperature and receive on/off for relay. It is powered from wall with a charger and a breadboard power. 3.3v for Atmega (without XTAL) and 5V for the relay. So relay is not powered from Atmega, Atmega give only the "consensus".
    Sometimes it did hang. So, I did try to add watchdog. This morning on my wakeup I did find it die.
    First of all, I need to say you that relay was poweroff for about 2h (I have last temp report about at 00:02 (it did hang from 00:.02 and 00:07, so), relay instead was off from the 22:00), so no interference from it and node was only reading temp every 5 minutes and reporting it to the Domoticz.
    No more light status blinking (and no responding to the controller). I have at the end of the loop a function that light a led status for 10ms, pause 4990ms (total 5 sec) and repeat this instruction. At the end, restart the loop. So, I have a visual feedback if node is live.
    I did note that adding watchdog, also without reset, the watchdog itself is not fired, also with very small times. So I imagine that several Mysensors call "interfere" with watchdog. I can only fire the watchdog if - with a false returning send instruction - I call the "delay" base instructions (you can see it in my code).
    My logic: retry to send for max 4 times. If 4th time is false (the send), introduce delay. Watchdog is fired ("finally") and restart coming.
    This is the code. Please, someone can help me to render it more stable? I have no idea where it hangs, because is it not connected on the PC but it is "headless".
    Thank you in advance!
     * Sketch for a relay + termostat.
     * In test from 27/09/2017
     * @version 2.1
     * DEFINE MYSENSORS SECTION
    //#define MY_DEBUG                    // Enable Basic Debug
    //#define MY_DEBUG_VERBOSE_SIGNING    // Enable Signing Debug
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x3B,0xF4,0x61,0xDF,0x1E,0x97,0xB1,0x2D,0xEC}}}
    #define MY_NODE_ID 10               // Default ID
    #define MY_WITH_LEDS_BLINKING_INVERSE
    #define MY_DEFAULT_ERR_LED_PIN 16
    #define MY_DEFAULT_TX_LED_PIN 17
    #define MY_DEFAULT_RX_LED_PIN 18
     * Include libraries
    #include <OneWire.h>
    #include <avr/wdt.h>
     * Define section.
     *    // NAME
    #define SKETCH_NAME       "Termostato+Relay"
    #define SKETCH_VERSION    "2.1"
        //  PIN
    #define PIN_DS18B20       2
    #define PIN_RELAY         3
    #define PIN_LED_STATUS    19
        //  CHILD ID
    #define CHILD_ID_TEMP     0
    #define CHILD_ID_RELAY    1
        //  RELAY SECTION
    #define RELAY_ON          1   // if inverted, invert here
    #define RELAY_OFF         0   // if inverted, invert here
        //  WAITs TIMES
    #define WAIT_LOOPS        60  // The status led flashes ON 10 ms and OFF 4990 ms == 5000 ms of loop. 5000 * WAIT_LOOPS = number of cycles before new read. 60 == 5 minutes
                                  // 12 here means 1 minute. 12 * 5000 ms = 60 sec = 1 minute
                                  // 60 here means 5 minutes. 60 * 5000 ms = 300 sec = 5 minutes
     * One Wire Section
    OneWire oneWire(PIN_DS18B20); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
     * Mysensors message
    MyMessage msg_temperature(CHILD_ID_TEMP , V_TEMP);
    // Initialize relay message
    MyMessage msg_relay(CHILD_ID_RELAY , V_STATUS);
     * Before class
    void before() {
      sensors.begin();
     * Presentation.
     * Presents the child to the controller
    void presentation() {
      // send sketch name
      sendSketchInfo(SKETCH_NAME , SKETCH_VERSION);
      // Present all sensors to controller.
      // TEMPERATURE
      // RELAY
      present(CHILD_ID_RELAY , S_BINARY);
     * Our Setup
      wdt_enable(WDTO_2S);
      Serial.println("Start sketch");
     // SETUP LED STATUS
        // Set the LED STATUS as OUTPUT and shutdown it.
      pinMode(PIN_LED_STATUS , OUTPUT);
      digitalWrite(PIN_LED_STATUS , LOW);
      // SETUP RELAY
        // Set the RELAY PIN as OUTPUT and LOW
      pinMode(PIN_RELAY , OUTPUT);
      digitalWrite(PIN_RELAY , RELAY_OFF);
      // initialize sensors
     * Our loop
      // send the relay state to controller
      sendRelayStateToController();
      // executed the reading
      loopTemperature();
      // light the status led... so wait
      lightLedStatus();
     * Send the state of relay to controller.
     * @since 2.1
    void sendRelayStateToController() {
      Serial.println("-------------- DEBUG sendRelayStateToController() ---------------");
      bool current_state = digitalRead(PIN_RELAY);
      //current_state = !current_state; // delete if NOT inverted
      if (current_state == 1) {
        current_state = RELAY_ON;
      } else {
        current_state = RELAY_OFF;
      Serial.print("current_state value is ");
      Serial.println(current_state);
      bool transmission_was_ok = false;
      int i = 0;
      do {
        transmission_was_ok = send(msg_relay.set(current_state) , true);
        Serial.print("Variable i is ");
        Serial.println(i);
        Serial.print("Variable transmission_was_ok value is ");
        Serial.println(transmission_was_ok);
        i++;
        if ( i > 3 ) {
          delay(5000); // this delay will call watchdog!
      } while (transmission_was_ok == false);
      Serial.println("------------------------------------------------------------");
     * Loop temperature.
     * Executed inside loop()
     * @since 2.0
    void loopTemperature() {
      // we need sensors.requestTemperatures() to NO BLOCK THE THREAD!!!
      float temperature = readTemperature();
      Serial.println("-------------- DEBUG loopTemperature() ---------------");
      Serial.print("Temperature is now ");
      Serial.println(temperature);
      Serial.println("------------------------------------------------------");
      sendTemperatureToController(temperature);
    /****       VARIOUS FUNCTION TO SUPPORT     *****/
     * Receive function
     * @since 2.0
      Serial.println("-------------- DEBUG receive() ---------------");
      Serial.print("message.type value is ");
      Serial.println(message.type);
      Serial.println("------------------------------------------");
      Serial.print("message.getCommand() value is ");
      Serial.println(message.getCommand());
      if ( message.isAck() ) {
        if ( message.type == V_STATUS ) {
          Serial.println("Relay state transmitted");
        if ( message.type == V_TEMP ) {
          Serial.println("Temperature transmitted");
      if ( !message.isAck() ) {
        if ( message.type == V_STATUS) {
          if (  message.getCommand() == 1 ) {
            bool received_state = message.getBool();
            Serial.print("received_state value is ");
            Serial.println(received_state);
            if ( received_state == 1) {
              digitalWrite(PIN_RELAY , RELAY_ON);
            } else {
      Serial.println("--------------------------------------------");
     * Read the temperature from DS18B20
     * @since 2.0
    float readTemperature() {
      int16_t conversionTime = millisToWaitForConversion(sensors.getResolution());
      wait(conversionTime);
      float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(CHILD_ID_TEMP):sensors.getTempFByIndex(CHILD_ID_TEMP)) * 10.)) / 10.;
      return temperature;
     * Get the millis to wait before reading based on resolution.
     * @since 2.0
    int16_t millisToWaitForConversion(uint8_t bitResolution) {
      switch (bitResolution) {
        case 9:
        return 94;
        case 10:
        return 188;
        case 11:
        return 375;
        default:
        return 750;
     * Send the temperature to controller
     * @since 2.0
    void sendTemperatureToController(float temperature) {
        int i = 0;
        do {
          transmission_was_ok = send(msg_temperature.setSensor(CHILD_ID_TEMP).set(temperature,1) , true);
          Serial.println(i);
          i++;
          if ( i > 3 ) {
      } else {
        delay(5000); // this call the watchdog!
        Serial.println("-------------- DEBUG sendTemperatureToController() ---------------");
        Serial.println("! ERROR reading temperature");
     * Light the LED status
     * @since 2.0
    void lightLedStatus() {
      int k = 0;
      for ( k = 0; k < WAIT_LOOPS; k++) {
        digitalWrite(PIN_LED_STATUS,HIGH);
          wait(10); // 5 * 1000 millisends = 5 seconds;
        digitalWrite(PIN_LED_STATUS,LOW);
          wait(4990);
    rejoe2R 1 Reply Last reply
    • S sineverba
      Hi to all,
       * @version 2.1
       * Include libraries
       * Define section.
       *    // NAME
          //  PIN
      #define PIN_RELAY         3
          //  CHILD ID
          //  RELAY SECTION
          //  WAITs TIMES
       * One Wire Section
       * Mysensors message
       * Before class
      void before() {
        sensors.begin();
       * Presentation.
        // send sketch name
        // TEMPERATURE
        // RELAY
       * Our Setup
       // SETUP LED STATUS
        // SETUP RELAY
       * Our loop
        loopTemperature();
        lightLedStatus();
       * @since 2.1
        } else {
        int i = 0;
        do {
          Serial.println(i);
          i++;
          if ( i > 3 ) {
       * Loop temperature.
       * @since 2.0
       * Receive function
       * @since 2.0
              } else {
       * @since 2.0
        return temperature;
       * @since 2.0
          case 9:
          return 94;
          case 10:
          return 188;
          case 11:
          return 375;
          default:
          return 750;
       * @since 2.0
          int i = 0;
          do {
            Serial.println(i);
            i++;
            if ( i > 3 ) {
        } else {
       * @since 2.0
        int k = 0;
            wait(4990);
      rejoe2R
      rejoe2R
      rejoe2
      @sineverba I didn't analyse your post in depth yet, but I suffer from effects that sound pretty similar, so here's the link fyi.
      S 1 Reply Last reply
      • rejoe2R rejoe2
        sineverba
        @rejoe2 Thank you, at least for your sharing.... There is an error in your link, right link is:
        https://forum.mysensors.org/topic/7454/rs485-nodes-stop-sending-data-after-some-hours-or-days
        (I think that forum has changed a bit your link)....
        Btw, tonight the node is still die 2 times. I'm re-arranging it with a Mini. I will update asap.
        PS Remain my doubt: how watchdog is implemented inside main functions of MySensors.....
        YveauxY 1 Reply Last reply
        • S sineverba
          YveauxY
          YveauxY
          @sineverba said in Node with DS18B20+Relay dies, also with watchdog:
          It isn't. Only deep sleeping uses the watchdog timer to wake up on atmega.
          • YveauxY Yveaux
            sineverba
            @Yveaux thank you. But, why whatchdog is never fired , also without a wtd_reset() in my loop?
            I did setup 2 sec, never reset It, but my atmega finish the loop without problem, never resetting itself ....
            • S sineverba
              YveauxY
              YveauxY
              @sineverba See here (bit old, but most is still valid): https://forum.mysensors.org/topic/1004/watchdog-on-ethernet-gateway
              MySensors does globally define a watchdog interrupt handler (for sleeping nodes, but always present). Keep that in mind if you want to do something with the interrupt handler.
