NRF24L01+ problems in 2.1.1 and 2.2.0 Beta
I have now tracked down the commit that makes the default raspberry pi gateway work: https://github.com/mysensors/MySensors/commit/4c31e22d6ff45c3a4f8aa70f915c5f10fe345f64
When using the commit before this (26c237adadda9f79b07d862708d8471285a96905 ) the radio init fails.
So now we at least know why development works and 2.1.1 does not.
git checkout 26c237adadda9f79b07d862708d8471285a96905 ... ./configure --extra-cxxflags="-DMY_DEBUG -DMY_DEBUG_VERBOSE_RF24" && make && sudo bin/mysgw -d ... mysgw: Starting gateway... mysgw: Protocol version - 2.2.0-beta mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: RF24:INIT mysgw: RF24:INIT:PIN,CE=9,CS=24 mysgw: RF24:WBR:REG=0,VAL=14 mysgw: RF24:WBR:REG=3,VAL=3 mysgw: RF24:WBR:REG=4,VAL=95 mysgw: RF24:WBR:REG=5,VAL=76 mysgw: RF24:WBR:REG=6,VAL=37 mysgw: RF24:WBR:REG=16,VAL=115 mysgw: RF24:WBR:REG=29,VAL=6 mysgw: RF24:RBR:REG=6,VAL=0 mysgw: RF24:RBR:REG=5,VAL=0 mysgw: !RF24:INIT:SANCHK FAIL mysgw: !TSM:INIT:TSP FAIL git checkout 4c31e22d6ff45c3a4f8aa70f915c5f10fe345f64 #68 ... ./configure --extra-cxxflags="-DMY_DEBUG -DMY_DEBUG_VERBOSE_RF24" && make && sudo bin/mysgw -d ... mysgw: Starting gateway... mysgw: Protocol version - 2.2.0-beta mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: RF24:INIT mysgw: RF24:INIT:PIN,CE=22,CS=24 mysgw: RF24:WBR:REG=0,VAL=14 mysgw: RF24:WBR:REG=3,VAL=3 mysgw: RF24:WBR:REG=4,VAL=95 mysgw: RF24:WBR:REG=5,VAL=76 mysgw: RF24:WBR:REG=6,VAL=37 mysgw: RF24:WBR:REG=16,VAL=115 mysgw: RF24:WBR:REG=29,VAL=6 mysgw: RF24:RBR:REG=6,VAL=37 mysgw: RF24:RBR:REG=5,VAL=76 mysgw: RF24:WBR:REG=2,VAL=2 mysgw: RF24:WBR:REG=1,VAL=0 mysgw: RF24:WBR:REG=28,VAL=3 mysgw: RF24:FRX mysgw: RF24:FTX mysgw: RF24:WBR:REG=7,VAL=112 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: RF24:WBR:REG=2,VAL=3 mysgw: RF24:WBR:REG=1,VAL=1 mysgw: RF24:STL mysgw: RF24:WBR:REG=0,VAL=15 mysgw: RF24:WBR:REG=10,VAL=0 mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: RF24:RBR:REG=23,VAL=17 mysgw: Listening for connections on 0.0.0.0:5003 -
I am glad I'm not the only one having this issue (but hope it will be resolved soon).
I had a RPi3 with the MQTT gateway working well for the past year, until I decided to upgrade to the latest version of Raspbian (and MySensors). I've now tried with a fresh install on both the RPi3 and a RPi2; with the same NRF24 as before (working well in the previous build); I also tried with a different radio using a socket and capacitor.
Looking forward to your progress!mysgw: Starting gateway... mysgw: Protocol version - 2.1.1 mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1 mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: !TSM:INIT:TSP FAIL mysgw: TSM:FAIL:CNT=1 mysgw: TSM:FAIL:PDT mysgw: TSM:FAIL:RE-INIT mysgw: TSM:INIT mysgw: !TSM:INIT:TSP FAIL mysgw: TSM:FAIL:CNT=2 mysgw: TSM:FAIL:PDT -
@miljume Are you using modules with the genuine Nordic Devices mounted on them? How do you have it connected? Are you successful with any other "compatible" modules?
@Jokgi Mots probably they are not genuine (bought from Aliexpress) but these devices themselves have not caused me any issues before. It started when I upgraded to 2.1.1. Although, after a clean install with 2.2.0 Beta it started working again so I am 100% sure that it's not the modules
git checkout 26c237adadda9f79b07d862708d8471285a96905 ... ./configure --extra-cxxflags="-DMY_DEBUG -DMY_DEBUG_VERBOSE_RF24" && make && sudo bin/mysgw -d ... mysgw: Starting gateway... mysgw: Protocol version - 2.2.0-beta mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: RF24:INIT mysgw: RF24:INIT:PIN,CE=9,CS=24 mysgw: RF24:WBR:REG=0,VAL=14 mysgw: RF24:WBR:REG=3,VAL=3 mysgw: RF24:WBR:REG=4,VAL=95 mysgw: RF24:WBR:REG=5,VAL=76 mysgw: RF24:WBR:REG=6,VAL=37 mysgw: RF24:WBR:REG=16,VAL=115 mysgw: RF24:WBR:REG=29,VAL=6 mysgw: RF24:RBR:REG=6,VAL=0 mysgw: RF24:RBR:REG=5,VAL=0 mysgw: !RF24:INIT:SANCHK FAIL mysgw: !TSM:INIT:TSP FAIL git checkout 4c31e22d6ff45c3a4f8aa70f915c5f10fe345f64 #68 ... ./configure --extra-cxxflags="-DMY_DEBUG -DMY_DEBUG_VERBOSE_RF24" && make && sudo bin/mysgw -d ... mysgw: Starting gateway... mysgw: Protocol version - 2.2.0-beta mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: RF24:INIT mysgw: RF24:INIT:PIN,CE=22,CS=24 mysgw: RF24:WBR:REG=0,VAL=14 mysgw: RF24:WBR:REG=3,VAL=3 mysgw: RF24:WBR:REG=4,VAL=95 mysgw: RF24:WBR:REG=5,VAL=76 mysgw: RF24:WBR:REG=6,VAL=37 mysgw: RF24:WBR:REG=16,VAL=115 mysgw: RF24:WBR:REG=29,VAL=6 mysgw: RF24:RBR:REG=6,VAL=37 mysgw: RF24:RBR:REG=5,VAL=76 mysgw: RF24:WBR:REG=2,VAL=2 mysgw: RF24:WBR:REG=1,VAL=0 mysgw: RF24:WBR:REG=28,VAL=3 mysgw: RF24:FRX mysgw: RF24:FTX mysgw: RF24:WBR:REG=7,VAL=112 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: RF24:WBR:REG=2,VAL=3 mysgw: RF24:WBR:REG=1,VAL=1 mysgw: RF24:STL mysgw: RF24:WBR:REG=0,VAL=15 mysgw: RF24:WBR:REG=10,VAL=0 mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: RF24:RBR:REG=23,VAL=17 mysgw: Listening for connections on 0.0.0.0:5003@mfalkvidd Good! I have now succeded in getting 2.2.0 Beta up and running with Ethernet GW
@mfalkvidd said in NRF24L01+ problems in 2.1.1 and 2.2.0 Beta:
Okay, this works for me now as well. However, Domoticz still doesn't report any updated data beyond the first seen measurement for the temp portion of the sensors....I am about to see how far these slim nodes can fly...
I had the same problem with 2.1.1 on a Raspberry Pi Zero W.
Changing to the development version fixed it. -
I'm trying to connect Domoticz to a virtual serial.
./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-rf24-pa-level=RF24_PA_LOW --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/serial2
But while Domoticz sees the serial port, it does not seem to connect. I also see the "end of file" error in the Domoticz logs.
What baudrate should be set in Domoticz?
Tried that, still having problems.
Syslog says a lot of: "mysgw: Client 0: 0:0:3:0:18:PING
with an occasional "rsyslogd-2007: action 'action 17' suspended, which is probanly about the log being spammed by MySensors.- It uses a 3.3v stabiliser board.
- Tried different power levels in settings (usually use low power because it works better for the cheap Chinese knock-offs)
- Tried external 5v power supply.
My nodes are saying 'FPAR: NO REPLY'
