  2. Bug Reports
  3. NRF24L01+ problems in 2.1.1 and 2.2.0 Beta
49 Posts 9 Posters 16.9k Views 12 Watching
    Did you check if spi is enabled in configuration? Sorry for stupid questions, but I need to broaden the search for the issue
    W
    W
    wergeld
    @gohan, I can only speak for me but I have done the following on my RPi 2 B:
    Changed out radios
    Used shield for radio or just straight wiring to radio
    New flash of latest minimal Raspbian
    Enabled SPI
    And various combinations of those. Maybe something broke in an update to Raspbian or some other change to the mysensors repo?
      miljumeM
      miljumeM
      miljume
      @gohan Yes, otherwise it fails already during build
      • A
        A
        arraWX
        This post is deleted!
        • A
          A
          arraWX
          wrote on last edited by arraWX
          #24
          With 2.1.1 I have the exact same problems.
          However, everything seems to be fine with 2.2.0 Beta:
          git clone https://github.com/mysensors/MySensors.git --branch development
          cd MySensors
          ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003 --my-rf24-pa-level=RF24_PA_MAX
          make
          In domoticz:
          The result:
          pi@raspberrypi:~/MySensors $ sudo ./bin/mysgw -d
          mysgw: Starting gateway...
          mysgw: Protocol version - 2.2.0-beta
          mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-beta
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:INIT:TSP OK
          mysgw: TSM:INIT:GW MODE
          mysgw: MCO:REG:NOT NEEDED
          mysgw: Listening for connections on 0.0.0.0:5003
          mysgw: MCO:BGN:STP
          mysgw: MCO:BGN:INIT OK,TSP=1
          mysgw: TSF:MSG:READ,2-2-0,s=1,c=1,t=0,pt=7,l=5,sg=0:24.0
          mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=1,pt=2,l=2,sg=0:58
          After success with 2.2.0 Beta I tried to go back to 2.1.1. However, it still does not work.
          I am on rpi3 and use a socket adapter board for the radio.
          • W
            W
            wergeld
            So, I did a lot of re-configuring and using 2.2.0 beta when a node sends a value payload (in my case a temp/humidity/battery value I get this while running my RPi ethernet gateway in debug:
            mysgw: TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            mysgw: TSF:MSG:BC
            mysgw: TSF:MSG:FPAR REQ,ID=3
            mysgw: TSF:CKU:OK,FCTRL
            mysgw: TSF:MSG:GWL OK
            mysgw: !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            mysgw: TSF:MSG:BC
            This continues until I kill the process. In the middle of all of these error messages though, it also reports client PING events:
            mysgw: Client 0: 0;0;3;0;18;PING
            Other interesting items of note:
            Domoticz says the values for temp have not been updated for 3+ hours for that node.
            Domoticz says that node only has a temp sensor.
            MYSController reports it having 2 sensors (temp and humidity) and it reports the values when i would expect them to be sent (ie, not 3+ hours old but updated continuously when temp changes).
            I am at my wits end here.
              NACK on the gateway usually means that the radio module is not powered correctly or there is a range issue (or you didn't set max tx power on the gateway)
              W 1 Reply Last reply
              • W
                W
                wergeld
                This is getting odder and odder.
                I am running 2.2.1 beta on my RPi2B. It is running on channel 76, with power max, and using ethernet gateway config.
                I have MYSController running on separate laptop and it is seeing updates to temp/hum and/or battery level. However, neither Domoticz or OpenHab2 have seen a change since last night at 9pm.
                In Domoticz - Setup - Hardware - Mysensors 2.2.0 Gateway it shows 2 nodes. First node is the gateway, of course, and the second is the sensor node. The data and the last seen times are correct! But, the Domoticz - Setup - Device list only shows the Temp sesnor and a last seen date of last night at 9pm. There are not other mysensors devices available.
                So, what is different between MYSControler and Domoticz and OpenHab?
                  W
                  W
                  wergeld
                  @gohan This doesnt really make sense to me. This happens after I get data from a sensor and the gateway gets stuck in a loop of those messages. MYSControler shows the correct value that triggered these messages while OpenHab and Domoticz do not.
                    Do you have capacitors on the radio modules? If you move the node closer to the gateway (3/4 meters apart) , does it work better?
                      W
                      W
                      wergeld
                      @gohan Yes, capacitors on both the node(s) and the gateway radios. Moving the nodes closer to gateway has no affect. The gateway is sending out udpates (per MYSControler at least) but Domoticz sees no new devices and OpenHab has not seen an update either. So frustrating.
                        Try to stop the gateway and run it with debug from console and c'è if you see any NACK occurring, also on the node if you can, because probably the controller is not accepting messages with NACK. If you can, try to make another arduino based gateway and see if you still get same errors. Keep in mind that if radio modules are not genuine you have to consider they are the cause of your problems.
                          W
                          W
                          wergeld
                          @gohan unable to run my node in debug with radio attached at the moment (no 3.3v FTDI or mosfets available right now).
                          But, that being said - the MYSControler does get the updated values. Just not Domoticz or OpenHab. So, why does one client connecting to the gateway get data while the other two do not?
                            Myscontroller doesn't see all debug messages. Get a ftdi adapter quickly 😁
                              W
                              W
                              wergeld
                              @gohan Yea, I have one on order taking the slow boat from China. But, it bothers me that MYSControler "gets" the sensor node values and the other controlers do not. Same IP config. And the weird NACK errors. Something just seems screwy as this hardware was working up until about 3 months ago - no changes made.
                                #35
                                I have now purchased an extra Raspberry Pi to test the raspberry pi gw.
                                2.1.1 fails with the most basic configure (without any parameters) while the same wiring and configure command works for development (I used commit 901258f16598)
                                git checkout 2.1.1
                                ./configure
                                make
                                sudo ./bin/mysgw -d
                                mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: !TSM:INIT:TSP FAIL
                                mysgw: TSM:FAIL:CNT=1
                                mysgw: TSM:FAIL:PDT
                                git checkout development
                                ./configure
                                make
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: MCO:BGN:STP
                                I'm not sure how to proceed though. Is there anything you want me to try?
                                  This is the verbose rf24 output. Not sure if it helps.
                                  2.1.1:
                                  ./configure --extra-cxxflags="-DMY_DEBUG -DMY_DEBUG_VERBOSE_RF24" && make && sudo bin/mysgw -d
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: RF24:write register, reg=0, value=14
                                  mysgw: RF24:write register, reg=3, value=3
                                  mysgw: RF24:write register, reg=4, value=95
                                  mysgw: RF24:write register, reg=5, value=76
                                  mysgw: RF24:write register, reg=6, value=39
                                  mysgw: RF24:write register, reg=16, value=115
                                  mysgw: RF24:write register, reg=29, value=6
                                  mysgw: RF24:read register, reg=6, value=0
                                  mysgw: RF24:read register, reg=5, value=0
                                  mysgw: !RF24:INIT:SANCHK FAIL
                                  development:
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: RF24:INIT
                                  mysgw: RF24:INIT:PIN,CE=22,CS=24
                                  mysgw: RF24:WBR:REG=0,VAL=14
                                  mysgw: RF24:WBR:REG=3,VAL=3
                                  mysgw: RF24:WBR:REG=4,VAL=95
                                  mysgw: RF24:WBR:REG=5,VAL=76
                                  mysgw: RF24:WBR:REG=6,VAL=37
                                  mysgw: RF24:WBR:REG=16,VAL=115
                                  mysgw: RF24:WBR:REG=29,VAL=4
                                  mysgw: RF24:RBR:REG=6,VAL=37
                                  mysgw: RF24:RBR:REG=5,VAL=76
                                  mysgw: RF24:WBR:REG=2,VAL=2
                                  mysgw: RF24:WBR:REG=1,VAL=0
                                  mysgw: RF24:WBR:REG=28,VAL=3
                                  mysgw: RF24:FRX
                                  mysgw: RF24:FTX
                                  mysgw: RF24:WBR:REG=7,VAL=112
                                  mysgw: RF24:WBR:REG=2,VAL=3
                                  mysgw: RF24:WBR:REG=1,VAL=1
                                  mysgw: RF24:STL
                                  mysgw: RF24:WBR:REG=0,VAL=15
                                  mysgw: RF24:WBR:REG=10,VAL=0
                                  mysgw: RF24:RBR:REG=23,VAL=17
                                  • miljumeM miljume
                                    I would like to submit a bug report for these libraries in the use of NRF24L01+ radio
                                    I have problems with NRF24L01+ on both 2.1.1 and 2.2.0 Beta
                                    I have installed a fresh RPI with all new libraries and trying to make a RPI Serial GW
                                    In 2.1.1 it doesn't start at all but in 2.2.0 it starts but in the log I constantly receive the following in the Domoticz log where I have added the GW
                                    I2017-10-09 19:25:12.306 MySensors: Gateway Version: 2.2.0-beta
                                    2017-10-09 19:25:12.306 Error: Serial Port closed!... Error: End of file
                                    2017-10-09 19:25:13.306 MySensors: retrying in 30 seconds...
                                    After a while I get the following in the console
                                    mysgw: TSF:MSG:READ,0-0-0,s=0,c=3,t=2,pt=0,l=11,sg=0:Get Version
                                    mysgw: !TSF:MSG:LEN,0!=18
                                    The above points at something wrong with the radio connection
                                    I have tried 3 different radios but still no luck so I guess it has something to do with the libraries
                                    JokgiJ
                                    JokgiJ
                                    Jokgi
                                    @miljume Are you using modules with the genuine Nordic Devices mounted on them? How do you have it connected? Are you successful with any other "compatible" modules?
                                    mfalkviddM miljumeM 2 Replies Last reply
                                    • JokgiJ Jokgi
                                      @Jokgi to my knowledge, there is no way to know if devices are genuine, besides sending them to Nordic to have them checked. I have not done that, so I don't know whether they are genuine.
                                      The radio module is connected using a 2x4 pin jumper wire connector on the nrf24 end and a 2x5 jumper wire connector on the raspberry pi end. Wiring for the nrf end is according to https://www.mysensors.org/build/connect_radio and https://www.mysensors.org/build/raspberry for the raspberry pi end.
                                      I don't understand your third question. Could you clarify/rephrase?
                                        I think he is asking if you tried other modules from different manufacturer
                                          #40
                                          Thanks @gohan
                                          In that case, the answer is that I don't know. I have ordered through Aliexpress 3-4 times. I don't know which modules came from which order, or if the orders were sourced from different manufacturers.
