  3. Some help to port MySensors to PCDUINO?
pcduino
5 Posts 2 Posters 2.1k Views 1 Watching
    msantang
    wrote on last edited by msantang
    Hi
    Im just planing to implement a home automation system using mysensors and I have a PCDuino3 that i want to use like gateway(serial) and controller.
    Someone could make MySensors works on PCDuino?
      @msantang
      Are you talking about running the gateway on the PCDuino or just attaching a serial arduino-gateway to it?
        msantang
        I want to run the gateway on the PCDuino. It's currently possible or need a complete rewrite?
          wrote on last edited by hek
          A complete rewrite is probably not necessary. I suggest you have a look at the raspberry code.
          You might also want to check out id there are any RF24-library ports available.
            msantang
            thank you! i will have a look to raspberry code.
