  3. Relay Actuator - send periodic status as heart beat.
3 Posts 3 Posters 3.1k Views 2 Watching
  • sealS
    sealS
    seal
    wrote on last edited by seal
    i successfully added heartbeat sending to RelayActuator.ino and relay sensor is sending data every one minute - but domoticz don't update last seen - this is only visible on gateway log. So i decided to send relay status as heartbeat - i have relay with two relay switches.
    Source code:
    #define MY_RADIO_RFM69
    #define MY_RFM69_NEW_DRIVER
    #define MY_NODE_ID 3
    //#define MY_REPEATER_FEATURE
    #define RELAY_2  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define MY_DEBUG_VERBOSE
    long double last_heartbeat_time = millis();
    long double HEARTBEAT_TIME = 30000;
    int oldValue=0;
    bool state;
    MyMessage msg(2,V_LIGHT);
    MyMessage msg2;
    void before() {
        pinMode(pin, OUTPUT);
        present(sensor, S_LIGHT);
       long double temp = (millis() - last_heartbeat_time);
      if (temp > HEARTBEAT_TIME) {
      // If it exceeds the heartbeat time then send a heartbeat
      sendHeartbeat();
      send(msg.set(msg2.getBool()?1:0));
      Serial.println("Sent heartbeat" );
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
         msg2 = message;
    but state is send only for one switch (second) and when i try to change switch 1 - this change is send aslo as relay 2. I added msg2 for export message from recieve to loop.
    How to send status for both relays as heartbeat?
    • sealS seal
      Source code:
      int oldValue=0;
      bool state;
      MyMessage msg2;
      void before() {
        sendHeartbeat();
           msg2 = message;
      @seal - sorry to say, this is a known problem in Domoticz. Is it a feature or is it a bug - depends on who you ask.
      This was just up: https://forum.mysensors.org/topic/7806/error-customercounter-hardware-12-nothing-received-for-more-than-5-minutes.
      This is me asking in DOmoticz forum: https://www.domoticz.com/forum/viewtopic.php?f=42&t=9775
      • D
        D
        Denis Renaud
        Hi, yout post is quit old but I changed your code a bit. Now it sends the status of both relays:
        int oldValue = 0;
        bool state;
        MyMessage msg1a(1, V_STATUS);
        MyMessage msg1b;
        MyMessage msg2a(2, V_STATUS);
        MyMessage msg2b;
        void before() {
          for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
            digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
            present(sensor, S_BINARY);
            sendHeartbeat();
            send(msg1a.set(msg1b.getBool() ? 1 : 0));
            send(msg2a.set(msg2b.getBool() ? 1 : 0));
            digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
            if (message.sensor == 1) {
              msg1b = message;
            if (message.sensor == 2) {
              msg2b = message;
        rg Denis
