  3. [security] Migrating from library version 2.1 to 2.2
48 Posts 7 Posters 14.6k Views 9 Watching
  • A Anticimex
    @alowhum right, but if you update your sketches OTA, he can potentially sniff your key OTA as well and then he does not need to enter your house ;)
    alowhumA Offline
    alowhumA Offline
    alowhum
    @anticimex Heh, then I will invite him/her over for tea congratulate them. And then apply some verbal security :-P
    Can Arduino nano's be updated OTA?
    A 1 Reply Last reply
    • alowhumA alowhum
      A Offline
      A Offline
      Anticimex
      @alowhum afaik all MySensors capable nodes can be updated OTA with the appropriate bootloader programmed.
      alowhumA 1 Reply Last reply
      • A Anticimex
        alowhumA Offline
        alowhumA Offline
        alowhum
        @anticimex Wow, I didn't know that! I've gotta look into that! cool!
        • alowhumA alowhum
          A Offline
          A Offline
          Anticimex
          @alowhum in general where are two options, DualOptiboot which require an external spi flash but is radio agnostic, or the mysbooloader which have no requirements on external components but might need to be recompiled to match your radio settings.
          gohanG 1 Reply Last reply
          • A Anticimex
            @anticimex I haven't found dual optiboot for all mysensors boards, but maybe there is a way to make it work and I'm not expert on this
              A Offline
              A Offline
              Anticimex
              @gohan hence my comment "in general", and in this sence I believe the board in question is "Can Arduino nano's be updated OTA?" and a nano is atmega328p based, and I believe it supports both bootloader variants. Of course there are some devices that might not support both, or perhaps even any of them, but as most of this discussion relates to resource limited nodes, I think only atmega328p based devices are considered.
              • alowhumA alowhum
                @anticimex Awesome!
                So I had a look at the new code, and is this a fair summary?:
                • Simple encryption and simple signing are now two separate functions you can call at the top of your script by adding a line with a password: MY_ENCRYPTION_SIMPLE_PASSWD and MY_SIGNING_SIMPLE_PASSWD.
                • You can also just put "MY_SECURITY_SIMPLE_PASSWD" at the top of your script, and that will do both in one go. This used to be called the MY_SIGNING_SIMPLE_PASSWD option, which also did both.
                MY_SIGNING_SIMPLE_PASSWD is now
                called MY_SECURITY_SIMPLE_PASSWD.
                MY_SIGNING_SIMPLE_PASSWD only affects signing,
                and a new flag, MY_ENCRYPTION_SIMPLE_PASSWD
                only affects encryption.
                MY_SECURITY_SIMPLE_PASSWD enable both these flags.
                This is simply wonderful.
                • More choice and flexibility for the end user.
                • Get some simple security on your existing Arduino hardware.
                Thank you so much for this.
                DavidZH
                @alowhum said in [security] Migrating from library version 2.1 to 2.2:
                @anticimex Awesome!
                I want to follow upon this: I use RFM69 for transport, they have an encryption engine in hardware. Will there be any difference in time to process the message between using:
                • MY_SECURITY_SIMPLE_PASSWORD with soft encryption done on the ATmega or
                • MY_SIGNING_SIMPLE_PASSWORD and encryption on the RFM or
                • just MY_SIGNING_SIMPLE_PASSWORD.
                If I'm not mistaken a signed message is the full 32 byes anyway, so the actual "airtime" will not change, but maybe the processing time before that will.
                And yes, I am aware of the implications in total system security. But none of my nodes are accessible from the outside of my house. I am not worried about someone reading the contents of my sketch.
                • D DavidZH
                  @anticimex Awesome!
                  A Offline
                  A Offline
                  Anticimex
                  @davidzh If you enable any form of encryption feature, RFM69 will always use the hardware to implement it. So there is no "soft encryption" on RFM69.
                  D 1 Reply Last reply
                  • A Anticimex
                    DavidZH
                    @anticimex
                    Ok clear. Thank you.
                    • B Offline
                      B Offline
                      bilbolodz
                      I've a lot devices with very hard physical access to them. I'm using OTA to change firmware so please describe how to implement "new 2.2 checksum feature" into existing sketch using OTA.
                      • B bilbolodz
                        A Offline
                        A Offline
                        Anticimex
                        @bilbolodz Not sure what you mean. Then you have to send personalization sketch OTA and that is really not recommended unless you can do that in a secure way. And the personalizer is not designed to use any radios so you cannot expect to be able to FOTA over a new sketch after personalization. You will have to "bring in" your devices if you want to redo personalization.
                        • B Offline
                          B Offline
                          bilbolodz
                          So it means that (If I want use signing) I'm stuck with mysensors version 2.1?
                          I'm not able compile new code (using 2.2) and upload it over OTA because I will loose signing right (without changeing EEPROM content)?
                          I think there should be a way to migrate sketch (which is using soft signing) from 2.1 to 2.2 with OTA. Secure sending of keys actually is NOT a problem because (as I understood) new in 2.2 is "only checksum" of EEPROM.
                          So if I have "2.1 mysensors library" personalized devices, it's possible to write a program which gets existing data from EEPROM calculate checksum and write it to EEPROM (maybe also migrating other structures if there were other changes). Such sketch can be in safe way transferred via OTA because it doesn't contain any secret information. Then I can upload new (using 2.2 library) version of my sketch and I will have working "2.2" devices without touching it (only OTA). What do you think about it?
                          Actually now I've realised (luckily) that in these "hard to get devices" I'm using hardware signing so it should be not a problem (?) :-)
                          A gohanG 2 Replies Last reply
                          • B bilbolodz
                            A Offline
                            A Offline
                            Anticimex
                            @bilbolodz Correct, checksum is on EEPROM data, so you can make a sketch to read it and calculate the checksum yourself. It is all open source so you can just see in the personalizer how it is calculated and replicate that :)
                            B 1 Reply Last reply
                            • A Anticimex
                              B Offline
                              B Offline
                              bilbolodz
                              @anticimex OK maybe I will try but I think it could be a good idea to extend you "migration guide".
                              • B bilbolodz
                                A Offline
                                A Offline
                                Anticimex
                                @bilbolodz I disapprove manipulating security related data without the personalizer, so no. You can do it, but I do not endorse it.
                                • B Offline
                                  B Offline
                                  bilbolodz
                                  "Your code your rules" but I'm little surprised with your standpoint.
                                  • B bilbolodz
                                    A Offline
                                    A Offline
                                    Anticimex
                                    @bilbolodz That is fine. But as I have currently no means of verifying, I will not make a update to the guide. If you find a way to do it, you are free to post a guide if other need to make a similar thing.
                                    • B bilbolodz
                                      @bilbolodz you can still enable signing on gateway and make it optional, so you will have time to update nodes later on.
                                      • A Anticimex
                                        alexsh1A Offline
                                        alexsh1A Offline
                                        alexsh1
                                        @anticimex I have a question - I have two GWs: one with ATSHA204A and one soft signing.
                                        I have noticed that when doing #define PERSONALIZE_ATSHA204A, AES key is saved to ATSHA204A and EEPROM. Is this correct? In what case I need a combination of HMAC + AES keys? I do not do whitelisting
                                        • alexsh1A alexsh1
                                          A Offline
                                          A Offline
                                          Anticimex
                                          @alexsh1 AES key is never saved to atsha204. It is for encryption and always stored in eeprom.
                                          alexsh1A 1 Reply Last reply
                                          12.1k
