  3. Multiple interuppts: One Arduino with two door sensors?
interruptdoor sensors
28 Posts 7 Posters 23.2k Views 4 Watching
  • gaduG gadu
    How about 3 doorsensors? Just +1 on everything?
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    wrote on last edited by BulldogLowell
    #21
    @gadu
    there are two external interrupts on most Arduino... but Mega has six.
    so yes, you can extend the code above if you have the right hardware.
    but... @hek 's library may not support more than two.
    • gaduG gadu
      tbowmoT
      tbowmoT
      tbowmo
      You could make an or gate, with a couple of diodes, then you only only need 1 interrupt pin. If you need to check which one of the reed switches was triggered, you could wire each of them to a separate input on the arduino as well as the input to the or gate.
      • A
        A
        algoritm
        I found this example file to work much better. The battery drained a lot slower.
          // Interrupt driven binary switch example with dual interrupts
          // Author: Patrick 'Anticimex' Fallberg
          // Connect one button or door/window reed switch between
          // digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
          // one in similar fashion on digital I/O pin 2.
          // This example is designed to fit Arduino Nano/Pro Mini
          // For lipo gauge
          #include "Arduino.h"
          #include "Wire.h"
          #include "MAX1704.h"
          MAX1704 fuelGauge;
          int oldBatteryPcnt = 0;
          #define SKETCH_NAME "Binary Sensor"
          #define SKETCH_MAJOR_VER "1"
          #define SKETCH_MINOR_VER "0"
          #define PRIMARY_CHILD_ID 3
          #define SECONDARY_CHILD_ID 4
          #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
          #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
          #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
          #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
          #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
          #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
          #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
          #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
          #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
          #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
          MySensor sensor_node;
          MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
          MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
            sensor_node.begin();
            // Setup the buttons
            pinMode(PRIMARY_BUTTON_PIN, INPUT);
            pinMode(SECONDARY_BUTTON_PIN, INPUT);
            // Activate internal pull-ups
            digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
            digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
            sensor_node.sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER"."SKETCH_MINOR_VER);
            // Register binary input sensor to sensor_node (they will be created as child devices)
            sensor_node.present(PRIMARY_CHILD_ID, S_DOOR);
            sensor_node.present(SECONDARY_CHILD_ID, S_DOOR);
            uint8_t value;
            static uint8_t sentValue=2;
            static uint8_t sentValue2=2;
            sensor_node.sleep(5);
            value = digitalRead(PRIMARY_BUTTON_PIN);
            if (value != sentValue) {
               // Value has changed from last transmission, send the updated value
               sensor_node.send(msg.set(value==HIGH ? 1 : 0));
               sentValue = value;
            value = digitalRead(SECONDARY_BUTTON_PIN);
            if (value != sentValue2) {
               sensor_node.send(msg2.set(value==HIGH ? 1 : 0));
               sentValue2 = value;
            // Fuel gauge
            int batteryPcnt = fuelGauge.stateOfCharge();
            if (oldBatteryPcnt != batteryPcnt)
               sensor_node.sendBatteryLevel(batteryPcnt);
               oldBatteryPcnt = batteryPcnt;
            // Sleep until something happens with the sensor
            sensor_node.sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
          @algoritm said:
          TP4056
          Ok, need to have one of these to play with myself.
          We should probably have an example of using it distributed with the MySensors library. Might steal something from the code posted here.
          A 1 Reply Last reply
            @algoritm said:
            TP4056
            A
            A
            algoritm
            @hek They are great and very cheap. Just make sure you get the latest version of the board (the one with the micro-usb). 10pcs for $7 on Ebay.
            hekH 1 Reply Last reply
            • A algoritm
              @algoritm
              But the one you linked didn't have any I2C interface. How about this?
              http://www.ebay.com.au/itm/Detection-Alarm-Module-A-D-Conversion-IIC-MAX17043-New-LiPo-Fuel-Gauge-Battery-/400749711661?
                @algoritm
                A
                A
                algoritm
                @hek The TP4056 is the charger module. I didn't know you meant the fuel gauge. They are two separate boards which I solder together to one part. :)
                • Paul AugustoP
                  Paul AugustoP
                  Paul Augusto
                  2 part video showing how to tie the TP4056 and MAX17043 boards together and to an arduino pro mini.
                  Part 1:
                  https://www.youtube.com/watch?v=3yHRrPDczK4
                  Part 2:
                  https://www.youtube.com/watch?v=ZtkIDwkrc6E
