  3. Multiple interuppts: One Arduino with two door sensors?
interruptdoor sensors
28 Posts 7 Posters 23.5k Views 4 Watching
  • A
    algoritm
    Here's the finished script.
      // For lipo gauge
      #include "Arduino.h"
      #include "Wire.h"
      #include "MAX1704.h"
      #define DOOR_ID 3
      #define MAILBOX_ID 2
      #define DOOR_PIN  3  // Arduino Digital I/O pin for button/reed switch
      #define MAILBOX_PIN 2
      MAX1704 fuelGauge;
      int oldBatteryPcnt = 0;
      byte oldValue[2] = { -1, -1};
      unsigned long sleepTime = 86400000UL; // 1 day
      //MyMessage msg(DOOR_PIN,V_TRIPPED);
      MyMessage msg[2];
        // Fuel gauge
        fuelGauge.reset();
        fuelGauge.quickStart();
        fuelGauge.showConfig();
        gw.begin();
        // Setup the buttons and Activate internal pull-ups
        pinMode(DOOR_PIN,INPUT_PULLUP);
        pinMode(MAILBOX_PIN, INPUT_PULLUP);
        // Set sensor (pin)
        msg[0].setSensor(DOOR_ID);
        msg[1].setSensor(MAILBOX_ID);
        // Set sensor (type)
        msg[0].setType(V_TRIPPED);
        msg[1].setType(V_TRIPPED);
        gw.present(DOOR_ID, S_DOOR);
        gw.present(MAILBOX_ID, S_DOOR);
        // Fuel gauge
        int batteryPcnt = fuelGauge.stateOfCharge();
        if (oldBatteryPcnt != batteryPcnt)
           oldBatteryPcnt = batteryPcnt;
        for (byte i = 0; i < 2; i++)
          debouncer[i].update();
          //if (value != oldValue[i]);
          gw.send(msg[i].set(value == HIGH? 1 : 0), false);
          oldValue[i] = value;
        gw.sleep(DOOR_PIN - 2, CHANGE, MAILBOX_PIN - 2, CHANGE, sleepTime);
    • gaduG
      gaduG
      gadu
      How about 3 doorsensors? Just +1 on everything?
      BulldogLowellB tbowmoT 2 Replies Last reply
      • gaduG gadu
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        #21
        @gadu
        there are two external interrupts on most Arduino... but Mega has six.
        so yes, you can extend the code above if you have the right hardware.
        but... @hek 's library may not support more than two.
        • gaduG gadu
          tbowmoT
          tbowmoT
          tbowmo
          You could make an or gate, with a couple of diodes, then you only only need 1 interrupt pin. If you need to check which one of the reed switches was triggered, you could wire each of them to a separate input on the arduino as well as the input to the or gate.
          • A
            algoritm
            I found this example file to work much better. The battery drained a lot slower.
              // Interrupt driven binary switch example with dual interrupts
              // Author: Patrick 'Anticimex' Fallberg
              // Connect one button or door/window reed switch between
              // digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
              // one in similar fashion on digital I/O pin 2.
              // This example is designed to fit Arduino Nano/Pro Mini
              // For lipo gauge
              #include "Wire.h"
              MAX1704 fuelGauge;
              #define SKETCH_MAJOR_VER "1"
              #define SKETCH_MINOR_VER "0"
              #define PRIMARY_CHILD_ID 3
              #define SECONDARY_CHILD_ID 4
              MySensor sensor_node;
                sensor_node.begin();
                // Activate internal pull-ups
                sensor_node.present(PRIMARY_CHILD_ID, S_DOOR);
                sensor_node.present(SECONDARY_CHILD_ID, S_DOOR);
                uint8_t value;
                static uint8_t sentValue=2;
                static uint8_t sentValue2=2;
                sensor_node.sleep(5);
                if (value != sentValue) {
                   sentValue = value;
                if (value != sentValue2) {
                   sentValue2 = value;
                // Fuel gauge
                   sensor_node.sendBatteryLevel(batteryPcnt);
              @algoritm said:
              TP4056
              Ok, need to have one of these to play with myself.
              We should probably have an example of using it distributed with the MySensors library. Might steal something from the code posted here.
              A 1 Reply Last reply
                @algoritm said:
                TP4056
                algoritm
                @hek They are great and very cheap. Just make sure you get the latest version of the board (the one with the micro-usb). 10pcs for $7 on Ebay.
                hekH 1 Reply Last reply
                • A algoritm
                  @algoritm
                  But the one you linked didn't have any I2C interface. How about this?
                  http://www.ebay.com.au/itm/Detection-Alarm-Module-A-D-Conversion-IIC-MAX17043-New-LiPo-Fuel-Gauge-Battery-/400749711661?
                    @algoritm
                    algoritm
                    @hek The TP4056 is the charger module. I didn't know you meant the fuel gauge. They are two separate boards which I solder together to one part. :)
                    • Paul AugustoP
                      Paul AugustoP
                      Paul Augusto
                      2 part video showing how to tie the TP4056 and MAX17043 boards together and to an arduino pro mini.
                      Part 1:
                      https://www.youtube.com/watch?v=3yHRrPDczK4
                      Part 2:
                      https://www.youtube.com/watch?v=ZtkIDwkrc6E
