  3. Home Assistant
  4. mysensors.json file structure
18 Posts 7 Posters 7.1k Views 8 Watching
  • Richard van der PlasR
    wrote on last edited by Richard van der Plas
    When creating new nodes, the mysensos.json file is updated, but sometimes i need to edit the json file,
    the structure is clear but the file is one line with all the nodes, sensors in one line.
    I find it personally difficult to edit this file.
    Isn't it possible to structure the file with newlines idents etc ?
    You can do it manually, but i assume when a new node is added the structure is gone again.
    • archiijsA
      archiijsA
      archiijs
      @Richard-van-der-Plas said in mysensors.json file structure:
      Agreed. Needed to edit couple times and messed up once or twice. I usually copy the file contents to online .json file checker that formats file to more understandable and then I can figure out where to make changes.
      Richard van der PlasR 1 Reply Last reply
      • archiijsA archiijs
        @archiijs yes, problem is im working on a chromebook, thus the commands to select and copy a file in nano doesn't work, so i have to shift cursor to the end of the line :)
        • archiijsA
          archiijsA
          archiijs
          Well, my 10" laptop also makes hard to work with lengthy text. I guess that in normal size monitor this is not as much a problem. :grimacing:
          Let's see what @martinhjelmare has to say.
            thats all i see, only the 1st node
            • S
              sindrome73
              Sorry the question, but this mysensos.json files where it is located ?? I did not understand it !!
              • archiijsA
                archiijsA
                archiijs
                Hi @sindrome73 by instructions here https://home-assistant.io/components/mysensors/ you chose path to .json file (and it is automatically created after that) by adding path to it to your configuration.yaml
                maghacM 1 Reply Last reply
                  maghacM
                  maghacM
                  maghac
                  @sindrome73 It's not used unless you use Home Assistant as a controller for mysensors.
                  @Richard-van-der-Plas It's a JSON file, so you can use any editor that understands json to edit it. No need to use nano or vi.
                  I personally use notepad++ to remote edit files on my server, it has a nice json plugin to pretty print json files. You could also use an online editor, e.g https://jsonformatter.org/ or something.
                  IrisPanabakerI 1 Reply Last reply
                    @maghac problem is my limited editor / shell on chrome os makes it a tediuos job on selecting the line :(
                    can you paste the formatted data back to the file? (with enters etc?). i thought the first round mysensors edits the file its a flat file again ?.
                    • martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      I use atom editor where there's a plugin that can automatically format the json prettily. But we can add formatting to the dump, I don't see anything hindering that.
                      I'll happily except a PR that adds indentation to the json dump. Otherwise I can do it when I find some time.
                      • archiijsA
                        archiijsA
                        archiijs
                        wrote on last edited by archiijs
                        Hi all.
                        @maghac Can you please share what plugin do You use? I already use np++ but have not thought of that, thanks.
                        @martinhjelmare Can atom editor can connect to my home assistant files through ssh without using samba shares as np++ can with plugins? If so, I should check that.
                        Otherwise, no worries about rushing this implementation and thanks for your work.
                        martinhjelmareM maghacM 2 Replies Last reply
                          Hi all.
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @archiijs
                          I don't think atom can connect via ssh.
                          • archiijsA
                            archiijsA
                            archiijs
                            Sorry, I meant to say ftp/sftp... Its early morning for me :confused:
                            I will definitely check atom after work, seems to be an answer to a lot of my problems, thanks for mentioning it.
                            • martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              I think this plugin does what you want:
                              https://atom.io/packages/remote-ftp
                              • archiijsA
                                archiijsA
                                archiijs
                                Thanks for your help, could not wait and already downloaded portabble verssion on my work pc to test this thing out, seems to work as expected, thanks again for your recomendation.
                                • maghacM maghac
                                  IrisPanabakerI
                                  IrisPanabakerI
                                  IrisPanabaker
                                  @maghac I loved https://jsonformatter.org and also uses https://codebeautify.org/jsonviewer
                                    Hi all.
                                    maghacM
                                    maghacM
                                    maghac
                                    @archiijs I use the NppFTP plugin, it supports both ftp and sftp.
                                      mirodin
                                      I made a pull request over on github, if @martinhjelmare accepts it we should be good to go.
