  3. FOTA flow in sleeping nodes - need two cycles?
14 Posts 3 Posters 3.6k Views 2 Watching
    manutremo
    I've finally managed to get my RFM69 radios working almost 100% and am testing FOTA on my battery powered nodes.
    These nodes sleep for 3h, wake up, do some processing, and then go back to sleep.
    The summarized sketch is as follows:
      if (!isFirmwareUpdateOngoing()) {
         < read sensors and do the processing>
        sleep(SLEEP_TIME_3h, true);
    When I upload a new fw to MYSController, the new fw is detected and the download appears to start for a few lines, but then the node goes to sleep and the update doesn't continue until the next wake-up cycle. This is the node log:
    0 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.0-rc.1
    4 TSM:INIT
    4 TSF:WUR:MS=0
    8 TSM:INIT:TSP OK
    10 TSF:SID:OK,ID=8
    12 TSM:FPAR
    12 TSM:FPAR:STATP=0
    14 TSM:ID
    16 TSM:ID:OK
    18 TSM:UPL
    24 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    45 TSF:MSG:READ,0-0-8,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    49 TSF:MSG:PONG RECV,HP=1
    53 TSM:UPL:OK
    55 TSM:READY:ID=8,PAR=0,DIS=1
    65 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:03000000400547620300
    133 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    145 TSF:MSG:READ,0-0-8,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    159 TSF:MSG:SEND,8-8-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-rc.1
    225 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    258 TSF:MSG:READ,0-0-8,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    272 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=11,pt=0,l=17,sg=0,ft=0,st=OK:Sensor de humedad
    337 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:3.0
    446 TSF:MSG:SEND,8-8-0-0,s=1,c=0,t=35,pt=0,l=13,sg=0,ft=0,st=OK:Humedad suelo
    454 MCO:REG:REQ
    509 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    524 TSF:MSG:READ,0-0-8,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    530 MCO:PIM:NODE REG=1
    534 MCO:BGN:STP
    534 MCO:BGN:INIT OK,TSP=1
    540 TSF:MSG:READ,0-0-8,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    737 TSF:MSG:SEND,8-8-0-0,s=1,c=1,t=37,pt=3,l=2,sg=0,ft=0,st=OK:0
    804 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:25
    Value1=775 96.87
    Value2=185 97.10
    Result = 96.99% (0.43cb)
    VCC = 3.30 Volts
    VCC% = 25 %
    819 MCO:SLP:MS=30000,SMS=1,I1=255,M1=255,I2=255,M2=255
    868 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
    899 TSF:MSG:READ,0-0-8,s=0,c=4,t=1,pt=6,l=8,sg=0:0300000040054396
    907 OTA:FWP:UPDATE
    909 OTA:FRQ:FW REQ,T=0003,V=0000,B=053F
    921 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003F05
    958 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003F05FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    968 OTA:FWP:RECV B=053F
    976 OTA:FRQ:FW REQ,T=0003,V=0000,B=053E
    989 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003E05
    1026 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003E05003F002100322E322E302D72632E3100
    1036 OTA:FWP:RECV B=053E
    1042 OTA:FRQ:FW REQ,T=0003,V=0000,B=053D
    1054 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003D05
    1093 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003D05003C4E4F4E43453E004F4B004E41434B
    1103 OTA:FWP:RECV B=053D
    1110 OTA:FRQ:FW REQ,T=0003,V=0000,B=053C
    1122 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003C05
    1155 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003C0525000D0A006E616E00696E66006F7666
    1165 OTA:FWP:RECV B=053C
    1171 OTA:FRQ:FW REQ,T=0003,V=0000,B=053B
    1183 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003B05
    1216 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003B0520566F6C74730056434325203D200020
    1226 OTA:FWP:RECV B=053B
    1234 OTA:FRQ:FW REQ,T=0003,V=0000,B=053A
    1247 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003A05
    1286 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003A05002520280063622900564343203D2000
    1296 OTA:FWP:RECV B=053A
    1302 OTA:FRQ:FW REQ,T=0003,V=0000,B=0539
    1314 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003905
    1349 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003905616C7565323D00526573756C74203D20
    1359 OTA:FWP:RECV B=0539
    1366 OTA:FRQ:FW REQ,T=0003,V=0000,B=0538
    1376 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003805
    1384 TSF:TDI:TSL
    1388 MCO:SLP:WUP=-1
    1390 TSF:TRI:TSB
    1398 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000
    1867 OTA:FRQ:FW REQ,T=0003,V=0000,B=0538
    1878 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003805
    1914 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003805207375656C6F0056616C7565313D0056
    1925 OTA:FWP:RECV B=0538
    1931 OTA:FRQ:FW REQ,T=0003,V=0000,B=0537
    1943 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003705
    1978 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:0300000037056564616400332E300048756D65646164
    1988 OTA:FWP:RECV B=0537
    1996 OTA:FRQ:FW REQ,T=0003,V=0000,B=0536
    2009 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003605
    2045 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:03000000360507010353656E736F722064652068756D
    2056 OTA:FWP:RECV B=0536
    2062 OTA:FRQ:FW REQ,T=0003,V=0000,B=0535
    2074 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003505
    2111 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:03000000350507070707070707070707070707070707
    2121 OTA:FWP:RECV B=0535
    2127 OTA:FRQ:FW REQ,T=0003,V=0000,B=0534
    2140 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003405
    2174 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:03000000340507000204060707070707070707070707
    2185 OTA:FWP:RECV B=0534
    2191 OTA:FRQ:FW REQ,T=0003,V=0000,B=0533
    2203 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003305
    2238 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:03000000330500AE0A7E0ADE0A520A760A620A530A05
    2248 OTA:FWP:RECV B=0533
    2256 OTA:FRQ:FW REQ,T=0003,V=0000,B=0532
    2269 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003205
    2304 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:0300000032051151117C112B12AD118B119F11000000
    2314 OTA:FWP:RECV B=0532
    2320 OTA:FRQ:FW REQ,T=0003,V=0000,B=0531
    2332 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003105
    2371 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003105FF3AFF3C053D106F30FF0000000000E4
    2381 OTA:FWP:RECV B=0531
    2387 OTA:FRQ:FW REQ,T=0003,V=0000,B=0530
    2400 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003005
    2433 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003005DC2C002D032E882F2D306437D4384239
    2443 OTA:FWP:RECV B=0530
    2449 OTA:FRQ:FW REQ,T=0003,V=0000,B=052F
    2461 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002F05
    2496 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002F0502044005030633188819422607281029
    2506 OTA:FWP:RECV B=052F
    2514 OTA:FRQ:FW REQ,T=0003,V=0000,B=052E
    2527 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002E05
    2562 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002E05FF1F0A1F0A01FFF709CF080104020003
    2574 OTA:FWP:RECV B=052E
    2580 OTA:FRQ:FW REQ,T=0003,V=0000,B=052D
    2590 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002D05
    2625 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002D056C084208A40856042708D407A8079507
    2635 OTA:FWP:RECV B=052D
    2641 OTA:FRQ:FW REQ,T=0003,V=0000,B=052C
    2654 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002C05
    2689 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002C055040E0F70895F894FFCFFFFF5A073207
    2701 OTA:FWP:RECV B=052C
    2705 OTA:FRQ:FW REQ,T=0003,V=0000,B=052B
    2717 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002B05
    2797 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002B0548F001900D920020C9F701C01D924150
    2807 OTA:FWP:RECV B=052B
    2818 OTA:FRQ:FW REQ,T=0003,V=0000,B=052A
    2828 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002A05
    2928 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002A0541505040D8F70895FB01DC0141505040
    2938 OTA:FWP:RECV B=052A
    <continues>
    As can be seen, the node starts, presents itself, etc, does the first processing cycle, and arrives to the sleep instruction (line 819, sleep time reduced to 30s to speed testing). Then some CRC seems to be exchanged with the gw, and it is determined that an fota is needed (line 907). Then some blocks of code are received until the node goes to sleep after receving block 0538 (line 1384). When it returns (line 1388), the update continues with the same block and from there on to the end of the update.
    As a side to this, I've capture occasions where the node determined that no fw update was necessary, went to sleep, and then did an update after waking up, like in this case:
    942 MCO:SLP:MS=30000,SMS=1,I1=255,M1=255,I2=255,M2=255
    993 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
    1021 TSF:MSG:READ,0-0-8,s=0,c=4,t=1,pt=6,l=8,sg=0:0300000040054396
    1028 OTA:FWP:UPDATE
    1030 OTA:FRQ:FW REQ,T=0003,V=0000,B=053F
    1042 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003F05
    1071 TSF:MSG:READ,0-0-8,s=0,c=4,t=1,pt=6,l=8,sg=0:0300000040054396
    1077 OTA:FWP:UPDATE SKIPPED
    1089 TSF:MSG:READ,0-0-8,s=0,c=4,t=1,pt=6,l=8,sg=0:0300000040054396
    1097 OTA:FWP:UPDATE SKIPPED
    1501 TSF:TDI:TSL
    1503 MCO:SLP:WUP=-1
    1505 TSF:TRI:TSB
    1513 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000
    1531 OTA:FRQ:FW REQ,T=0003,V=0000,B=053F
    1581 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003F05
    1615 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003F05FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    1626 OTA:FWP:RECV B=053F
    1636 OTA:FRQ:FW REQ,T=0003,V=0000,B=053E
    1646 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003E05
    1681 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003E05003F002100322E322E302D72632E3100
    1693 OTA:FWP:RECV B=053E
    1697 OTA:FRQ:FW REQ,T=0003,V=0000,B=053D
    1710 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003D05
    1980 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003D05003C4E4F4E43453E004F4B004E41434B
    1992 OTA:FWP:RECV B=053D
    1996 OTA:FRQ:FW REQ,T=0003,V=0000,B=053C
    2009 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003C05
    2048 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003C0525000D0A006E616E00696E66006F7666
    2058 OTA:FWP:RECV B=053C
    2064 OTA:FRQ:FW REQ,T=0003,V=0000,B=053B
    2076 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003B05
    2111 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003B0520566F6C74730056434325203D200020
    2121 OTA:FWP:RECV B=053B
    2129 OTA:FRQ:FW REQ,T=0003,V=0000,B=053A
    2142 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003A05
    2416 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003A05002520280063622900564343203D2000
    2426 OTA:FWP:RECV B=053A
    2433 OTA:FRQ:FW REQ,T=0003,V=0000,B=0539
    2445 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003905
    2484 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003905616C7565323D00526573756C74203D20
    2494 OTA:FWP:RECV B=0539
    Lines 1077 (and 1097 again for some reason) indicate UPDATE SKIPPED; the node goes to sleep, but then an update is launched after wake-up.
    Of course, no changes in the ino.hex file were done while the node was sleeping.
    Would this be expected behaviour or is there some inconsistency? The fact that the firmware update needs to wait until the next wake-up cycle is very inconvenient in this scenario where the node sleeps for hours.
    Alternatively is there some detailed description of the FOTA update process flow where I can try to understand?
    Thanks.
    • scalzS
      scalzS
      I will try to check that if I get some time, but you still can block your sleep mode until FOTA is finished (by adding a condition in your sketch)
      M 1 Reply Last reply
      • scalzS scalz
        manutremo
        @scalz Many thanks, let me know if I can help further with the testing.
        Regarding your comment on blocking the sleep - how would that be done? I thought the conditional in my sketch (shown above) would already be blocking it.
        tekkaT 1 Reply Last reply
        • scalzS
          scalzS
          @manutremo you're right. i need to take a look
          • M manutremo
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            @manutremo Can you post the entire sketch + full log when you receive a "OTA:FWP:UPDATE SKIPPED" message. In addition, it would be helpful to get infos on your setup, i.e. HW, IDE & board definition versions.
            • tekkaT tekka
              manutremo
              @tekka Sure, here it goes:
              #define MY_RADIO_RFM69
              #define MY_RFM69_NEW_DRIVER
              #define MY_IS_RFM69HW
              #define MY_RFM69_MAX_POWER_LEVEL_DBM 13
              #define MY_RFM69_FREQUENCY RFM69_868MHZ
              //#define MY_DEBUG_VERBOSE_RFM69
              #define MY_PARENT_NODE_ID 0
              #define MY_TRANSPORT_MAX_TX_FAILURES (3u)
              #define MY_OTA_FIRMWARE_FEATURE
              #define MY_OTA_USE_I2C_EEPROM
              #include <Vcc.h>
              #include <Streaming.h>
              #include <math.h>
              #define SLEEP_TIME_15min  900000    // 15min x 60s = 900000 ms -13% = 783000                (my arduinos show a delay of 8s/min = 13%)
              #define SLEEP_TIME_1h     3600000   // 1 h = 1*60*60000 = 3600000 ms -13% = 3132000 ms
              #define SLEEP_TIME_2h     7200000   // 2 h = 2*60*60000 = 7200000 ms -13% = 6264000 ms
              #define SLEEP_TIME_3h     10800000  // 3 h = 3*60*60000 = 10800000 ms -13% = 9396000 ms
              #define VERSION "3.0"
              #define PIN_ALIM1 4                                   // Connect to input of resistor
              #define PIN_ALIM2 7                                   // Connect to input of measuring probe
              #define PIN_LECTURA A0
              #define AGUA_DIR            800.0
              #define AGUA_INV            160.0
              #define AIRE_DIR            0.0
              #define AIRE_INV            1023.0
              #define TIEMPO_LECTURA      10
              #define MAX_REP_LECTURA     20
              #define MAX_REPORTING_LOOPS 4
              // Battery calibration (Li-ion)
              const float VccMin   = 3.0;                         // Minimum expected Vcc level, in Volts.
              const float VccMax   = 4.2;                         // Maximum expected Vcc level, in Volts.
              const float VccCorrection = 3.82/3.74;              // Measured Vcc by multimeter divided by reported Vcc
              #define CHILD_MOIST_ID 1
              MyMessage msgmoist(CHILD_MOIST_ID, V_LEVEL);
              Vcc vcc(VccCorrection);
              int count=0;
              signed int oldv1=0, oldv2=0;
              float oldresultcb=0;
              #ifdef MY_DEBUG
                Serial.begin(115200);
                analogReference(DEFAULT);
                pinMode(PIN_LECTURA, INPUT);
                pinMode(PIN_ALIM1, OUTPUT);
                pinMode(PIN_ALIM2, OUTPUT);
              void presentation(){
                  sendSketchInfo("Sensor de humedad", VERSION);
                  present(CHILD_MOIST_ID, S_MOISTURE, "Humedad suelo");
                  signed int value1=0, value2=0, i=0;
                  float result1, result2, resultp, resultcb;
                  //Loop until readings are stable or max number of readings is reached
                  do {
                    oldv1=value1; oldv2=value2;
                    wait(TIEMPO_LECTURA);
                    digitalWrite(PIN_ALIM1, HIGH);
                    digitalWrite(PIN_ALIM2, LOW);
                    value1 = analogRead(PIN_LECTURA);
                    digitalWrite(PIN_ALIM1, LOW);
                    digitalWrite(PIN_ALIM2, HIGH);
                    value2 = analogRead(PIN_LECTURA);;
                  } while (((oldv1 != value1) && (oldv2 != value2)) || (i == MAX_REP_LECTURA));
                    0-10 Saturated Soil. Occurs for a day or two after irrigation
                    10-20 Soil is adequately wet (except coarse sands which are drying out at this range)
                    20-60 Usual range to irrigate or water (most soils except heavy clay soils).
                    60-100 Usual range to irrigate heavy clay soils
                    100-200 Soil is becoming dangerously dry
                  result1=constrain(value1/(AGUA_DIR-AIRE_DIR)*100.0, 1, 100);
                  result2=constrain(100-(value2-AGUA_INV)/(AIRE_INV-AGUA_INV)*100.0,1,100);
                  resultp = (result1+result2)/2.0;
                  resultcb = resultcb + constrain(square((-2.96699 + 351.395/resultp)),0,200);                           //Equation fit using stat software
                  count++;
                  //Send the data - only if moisture changed to save battery (send anyways once every 4 readings). If moisture sent, send battery level.
                  if ((oldresultcb!=resultcb) || (count==MAX_REPORTING_LOOPS)) {
                    send(msgmoist.set((unsigned int)resultcb));
                    oldresultcb=resultcb;
                    //Measure battery voltage and send level
                    float v = vcc.Read_Volts();
                    int p = vcc.Read_Perc(VccMin, VccMax);
                    p=constrain(p,0,100);
                    sendBatteryLevel(p);
                    #ifdef MY_DEBUG
                      Serial << "Value1=" << value1 << " " << result1 << endl << "Value2=" << value2 << " " << result2 << endl << "Result = " << resultp << "% (" << resultcb << "cb)" << endl;
                      Serial << "VCC = " << v << " Volts" << endl << "VCC% = " << p << " %" << endl;
                  if (count==MAX_REPORTING_LOOPS) count=0;
              The node uses a Mini Pro 3.3v @ 8 MHz. I'm powering it with a Li battery through a MCP1703 LDO with the 2 caps as shown in the datasheet. The radio is a RFM69HW with a 47uF cap in the power rail and a 0.1uF soldered to the power pins of the board shield. I'm using Arduino IDE v1.8.4, with boards definition v1.6.20.
              Thanks in advance.
              • M manutremo
                #include <Vcc.h>
                #include <math.h>
                int count=0;
                #ifdef MY_DEBUG
                    do {
                    count++;
                      #ifdef MY_DEBUG
                Thanks in advance.
                tekkaT
                tekkaT
                tekka
                @manutremo you're using a i2c eeprom? Please re-run a FOTA update with
                #define MY_DEBUG_VERBOSE_OTA_UPDATE
                enabled and post the full log. Could be an issue with the i2c eeprom...let's see
                  manutremo
                  wrote on last edited by manutremo
                  Yes, an AT24C256. Will enable fota verbose debug but the update skipped issue doesn't happen always. Will try to reproduce it, though.
                  in case it matters, I'm using kisse66's bootloader here
                  • tekkaT tekka
                    manutremo
                    @tekka See below the log of a new occurence of the same issue with UPDATE SKIPPED. This time I enabled verbose debug for OTA . This time I was testing with another different node with a similar hw setup - I'm also adding the sketch below although I think that from an OTA standpoint it's the same. First the node says UPDATE (line 2600), then UPDATE SKIPPED (line 2654), then goes to sleep, and after wake-up the update starts. This time the firmware was a new one, so the update is correct - which makes me think that maybe it's just that the UPDATE SKIPPED appears incorrectly.
                    18 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.0-rc.1
                    28 TSM:INIT
                    28 TSF:WUR:MS=0
                    32 TSM:INIT:TSP OK
                    34 TSM:INIT:STATID=22
                    36 TSF:SID:OK,ID=22
                    38 TSM:FPAR
                    38 TSM:FPAR:STATP=0
                    40 TSM:ID
                    43 TSM:ID:OK
                    45 TSM:UPL
                    53 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    71 TSF:MSG:READ,0-0-22,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    77 TSF:MSG:PONG RECV,HP=1
                    79 TSM:UPL:OK
                    81 TSM:READY:ID=22,PAR=0,DIS=1
                    307 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010001000005990D0300
                    370 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    382 TSF:MSG:READ,0-0-22,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    397 TSF:MSG:SEND,22-22-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-rc.1
                    464 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    491 TSF:MSG:READ,0-0-22,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    507 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=11,pt=0,l=23,sg=0,ft=0,st=OK:Sensor de fugas de agua
                    575 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                    638 TSF:MSG:SEND,22-22-0-0,s=1,c=0,t=32,pt=0,l=13,sg=0,ft=0,st=OK:Fugas de agua
                    647 MCO:REG:REQ
                    700 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    952 TSF:MSG:READ,0-0-22,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    958 MCO:PIM:NODE REG=1
                    960 MCO:BGN:STP
                    962 MCO:BGN:INIT OK,TSP=1
                    2459 !TSF:MSG:SEND,22-22-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:0
                    2498 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:36
                    No detection
                    2506 MCO:SLP:MS=30000,SMS=1,I1=1,M1=1,I2=255,M2=255
                    2560 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                    2592 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3
                    2600 OTA:FWP:UPDATE
                    2603 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF
                    2615 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04
                    2648 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3
                    2654 OTA:FWP:UPDATE SKIPPED
                    3069 TSF:TDI:TSL
                    3072 MCO:SLP:WUP=-1
                    3074 TSF:TRI:TSB
                    3082 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000
                    3104 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF
                    3143 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04
                    3178 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FF04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                    3188 OTA:FWP:RECV B=04FF
                    3198 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FE
                    3211 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FE04
                    3254 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FE04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                    3264 OTA:FWP:RECV B=04FE
                    3270 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FD
                    3282 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FD04
                    3315 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FD042E310000FFFFFFFFFFFFFFFFFFFFFFFF
                    3328 OTA:FWP:RECV B=04FD
                    3334 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FC
                    3346 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FC04
                    3379 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FC0441434B003F002100322E322E302D7263
                    3389 OTA:FWP:RECV B=04FC
                    3397 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FB
                    3407 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FB04
                    3446 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FB04696F6E003C4E4F4E43453E004F4B004E
                    3457 OTA:FWP:RECV B=04FB
                    3467 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FA
                    3477 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FA04
                    3514 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FA04746564000D0A004E6F20646574656374
                    3524 OTA:FWP:RECV B=04FA
                    3530 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F9
                    3543 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F904
                    3579 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F9046167756100466C6F6F64206465746563
                    3592 OTA:FWP:RECV B=04F9
                    3598 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F8
                    3608 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F804
                    3651 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F804756100312E3100467567617320646520
                    3661 OTA:FWP:RECV B=04F8
                    3667 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F7
                    3680 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F704
                    3715 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F70472206465206675676173206465206167
                    3727 OTA:FWP:RECV B=04F7
                    #define MY_RFM69_NEW_DRIVER   // ATC on RFM69 works only with the new driver (not compatible with old=default driver)
                    #define MY_NODE_ID 22
                    #include <Vcc.h>
                    #define SLEEP_TIME_5min   300000
                    #define SLEEP_TIME_10min  600000
                    #define VERSION "1.1"
                    #define PIN_INTERRUPT 3
                    #define CHILD_FLOOD_ID 1
                    MyMessage msgflood(CHILD_FLOOD_ID, V_TRIPPED);
                    bool res;
                    int interrupt=digitalPinToInterrupt(PIN_INTERRUPT), oldbat=101;     // Set so that it will be sent always on the first run
                    void setup(){
                      pinMode(PIN_INTERRUPT, INPUT);
                        sendSketchInfo("Sensor de fugas de agua", VERSION);
                        present(CHILD_FLOOD_ID, S_WATER_LEAK, "Fugas de agua");
                        // Contact status is always sent as a safety measure to allow checking if the sensor is working
                        // We start with a short delay for debouncing the contact (otherwise the reading from the pin might be incorrect after exiting from the sleep()
                        delay(150);
                        res = (digitalRead(PIN_INTERRUPT) == LOW);
                        send(msgflood.set(res));
                        //Measure battery voltage and send level if it has changed
                        if (p != oldbat) { oldbat = p; sendBatteryLevel(p); }
                        #ifdef MY_DEBUG
                        if (res) Serial.println("Flood detected"); else Serial.println("No detection");
                        sleep(interrupt, CHANGE, 20000, true);//SLEEP_TIME_3h, true);
                      manutremo
                      By the way - following the above, I made a small modification to the sketch, compiled, etc. Myscontroller detected the new fw corectly and the update run fine at the next wake-up, with no SKIPPED messages.
                      20987 MCO:SLP:MS=20000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      21041 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                      21073 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:010001000005990D
                      21082 OTA:FWP:UPDATE
                      21084 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF
                      21096 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04
                      21135 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FF04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      21145 OTA:FWP:RECV B=04FF
                      21155 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FE
                      However I then modified the sketch again, uploaded it to Myscontroller, etc, but this time I reset the node. The log showed the UPDATE SKIPPED message again before starting the update.
                      28 TSM:INIT
                      28 TSF:WUR:MS=0
                      32 TSM:INIT:TSP OK
                      36 TSF:SID:OK,ID=22
                      38 TSM:FPAR
                      38 TSM:FPAR:STATP=0
                      40 TSM:ID
                      43 TSM:ID:OK
                      45 TSM:UPL
                      79 TSM:UPL:OK
                      94 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010001000005990D0300
                      161 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      172 TSF:MSG:READ,0-0-22,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      188 TSF:MSG:SEND,22-22-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-rc.1
                      253 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      282 TSF:MSG:READ,0-0-22,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      299 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=11,pt=0,l=23,sg=0,ft=0,st=OK:Sensor de fugas de agua
                      364 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                      428 TSF:MSG:SEND,22-22-0-0,s=1,c=0,t=32,pt=0,l=13,sg=0,ft=0,st=OK:Fugas de agua
                      436 MCO:REG:REQ
                      489 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      505 TSF:MSG:READ,0-0-22,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      512 MCO:PIM:NODE REG=1
                      514 MCO:BGN:STP
                      516 MCO:BGN:INIT OK,TSP=1
                      675 TSF:MSG:SEND,22-22-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                      739 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:32
                      No detection
                      745 MCO:SLP:MS=30000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      802 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                      831 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3
                      839 OTA:FWP:UPDATE
                      841 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF
                      854 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04
                      882 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3
                      888 OTA:FWP:UPDATE SKIPPED
                      1220 TSF:MSG:READ,0-0-22,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      1288 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FF04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      1298 OTA:FWP:RECV B=04FF
                      1308 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FE
                      1320 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FE04
                      1329 TSF:TDI:TSL
                      1331 MCO:SLP:WUP=-1
                      1333 TSF:TRI:TSB
                      1343 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000
                      1810 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FE
                      1820 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FE04
                      1859 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FE04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      1869 OTA:FWP:RECV B=04FE
                      1878 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FD
                      1888 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FD04
                      1925 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FD042E310000FFFFFFFFFFFFFFFFFFFFFFFF
                      1935 OTA:FWP:RECV B=04FD
                      1943 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FC
                      1953 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FC04
                      1992 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FC0441434B003F002100322E322E302D7263
                      2002 OTA:FWP:RECV B=04FC
                      2009 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FB
                      2021 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FB04
                      2056 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FB04696F6E003C4E4F4E43453E004F4B004E
                      2066 OTA:FWP:RECV B=04FB
                      2076 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FA
                      2086 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FA04
                      2123 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FA04746564000D0A004E6F20646574656374
                      2134 OTA:FWP:RECV B=04FA
                      2140 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F9
                      2152 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F904
                      2187 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F9046167756100466C6F6F64206465746563
                      2197 OTA:FWP:RECV B=04F9
                      2203 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F8
                      So it looks this happens only if right after a node reset. I hope this gives a hint.
                      As a side note - I also find interesting that the number of update blocks sent before the node goes to sleep changes between test runs.
                      tekkaT 2 Replies Last reply
                      • M manutremo
                        28 TSM:INIT
                        28 TSF:WUR:MS=0
                        32 TSM:INIT:TSP OK
                        36 TSF:SID:OK,ID=22
                        38 TSM:FPAR
                        38 TSM:FPAR:STATP=0
                        40 TSM:ID
                        43 TSM:ID:OK
                        45 TSM:UPL
                        79 TSM:UPL:OK
                        436 MCO:REG:REQ
                        514 MCO:BGN:STP
                        No detection
                        839 OTA:FWP:UPDATE
                        1329 TSF:TDI:TSL
                        1331 MCO:SLP:WUP=-1
                        1333 TSF:TRI:TSB
                        tekkaT
                        tekkaT
                        tekka
                        @manutremo ok, I'm on something - it has to do with the smart sleep feature. I will prepare a fix for you to test.
                        • M manutremo
                          28 TSM:INIT
                          28 TSF:WUR:MS=0
                          32 TSM:INIT:TSP OK
                          36 TSF:SID:OK,ID=22
                          38 TSM:FPAR
                          38 TSM:FPAR:STATP=0
                          40 TSM:ID
                          43 TSM:ID:OK
                          45 TSM:UPL
                          79 TSM:UPL:OK
                          436 MCO:REG:REQ
                          514 MCO:BGN:STP
                          No detection
                          839 OTA:FWP:UPDATE
                          1329 TSF:TDI:TSL
                          1331 MCO:SLP:WUP=-1
                          1333 TSF:TRI:TSB
                          tekkaT
                          tekkaT
                          tekka
                          @manutremo here you go: https://github.com/tekka007/MySensors/tree/FOTAUpdates
                          M 2 Replies Last reply
                          • tekkaT tekka
                            manutremo
                            Many thanks @tekka, that was really fast! I'll give it a try as soon as I can spare some minutes.
                            • tekkaT tekka
                              manutremo
                              @tekka Tested the new library and both issues seem to be gone now, great job ! :clap:
                              I have one more question though :)
                              During testing I treid to put things difficult for my radios and move them until reception started to be bad. At some point the FOTA process gave up with a FW UPD FAIL message (line 41146 in attached log). So the node gave up and went to sleep. I was expecting it to try again after wake-up, but it didn't (see lines after 43589).
                              36734 !RFM69:SWR:NACK
                              36737 RFM69:PTX:NO ADJ
                              36771 RFM69:SWR:SEND,TO=0,RETRY=5
                              36966 RFM69:SWR:ACK,FROM=0,SEQ=119,RSSI=-55
                              36972 RFM69:ATC:ADJ TXL,cR=-55,tR=-80,TXL=12
                              36976 RFM69:PTX:LEVEL=12 dBm
                              36978 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005
                              36988 OTA:FRQ:FW REQ,T=0001,V=0001,B=0520
                              36993 RFM69:SWR:SEND,TO=0,RETRY=0
                              37203 !RFM69:SWR:NACK
                              37206 RFM69:PTX:LEVEL=13 dBm
                              37216 RFM69:SWR:SEND,TO=0,RETRY=1
                              37423 !RFM69:SWR:NACK
                              37425 RFM69:PTX:NO ADJ
                              37459 RFM69:SWR:SEND,TO=0,RETRY=2
                              37666 !RFM69:SWR:NACK
                              37668 RFM69:PTX:NO ADJ
                              37679 RFM69:SWR:SEND,TO=0,RETRY=3
                              37885 !RFM69:SWR:NACK
                              37888 RFM69:PTX:NO ADJ
                              37922 RFM69:SWR:SEND,TO=0,RETRY=4
                              38129 !RFM69:SWR:NACK
                              38131 RFM69:PTX:NO ADJ
                              38174 RFM69:SWR:SEND,TO=0,RETRY=5
                              38313 RFM69:SWR:ACK,FROM=0,SEQ=120,RSSI=-56
                              38318 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=12
                              38322 RFM69:PTX:LEVEL=12 dBm
                              38326 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005
                              38334 OTA:FRQ:FW REQ,T=0001,V=0001,B=0520
                              38338 RFM69:SWR:SEND,TO=0,RETRY=0
                              38547 !RFM69:SWR:NACK
                              38549 RFM69:PTX:LEVEL=13 dBm
                              38559 RFM69:SWR:SEND,TO=0,RETRY=1
                              38768 !RFM69:SWR:NACK
                              38770 RFM69:PTX:NO ADJ
                              38805 RFM69:SWR:SEND,TO=0,RETRY=2
                              39012 !RFM69:SWR:NACK
                              39014 RFM69:PTX:NO ADJ
                              39024 RFM69:SWR:SEND,TO=0,RETRY=3
                              39231 !RFM69:SWR:NACK
                              39233 RFM69:PTX:NO ADJ
                              39268 RFM69:SWR:SEND,TO=0,RETRY=4
                              39475 !RFM69:SWR:NACK
                              39477 RFM69:PTX:NO ADJ
                              39520 RFM69:SWR:SEND,TO=0,RETRY=5
                              39702 RFM69:SWR:ACK,FROM=0,SEQ=121,RSSI=-54
                              39706 RFM69:ATC:ADJ TXL,cR=-54,tR=-80,TXL=12
                              39712 RFM69:PTX:LEVEL=12 dBm
                              39714 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005
                              39723 OTA:FRQ:FW REQ,T=0001,V=0001,B=0520
                              39729 RFM69:SWR:SEND,TO=0,RETRY=0
                              39938 !RFM69:SWR:NACK
                              39940 RFM69:PTX:LEVEL=13 dBm
                              39983 RFM69:SWR:SEND,TO=0,RETRY=1
                              40192 !RFM69:SWR:NACK
                              40194 RFM69:PTX:NO ADJ
                              40228 RFM69:SWR:SEND,TO=0,RETRY=2
                              40435 !RFM69:SWR:NACK
                              40437 RFM69:PTX:NO ADJ
                              40480 RFM69:SWR:SEND,TO=0,RETRY=3
                              40687 !RFM69:SWR:NACK
                              40689 RFM69:PTX:NO ADJ
                              40724 RFM69:SWR:SEND,TO=0,RETRY=4
                              40931 !RFM69:SWR:NACK
                              40933 RFM69:PTX:NO ADJ
                              40943 RFM69:SWR:SEND,TO=0,RETRY=5
                              41125 RFM69:SWR:ACK,FROM=0,SEQ=122,RSSI=-54
                              41129 RFM69:ATC:ADJ TXL,cR=-54,tR=-80,TXL=12
                              41134 RFM69:PTX:LEVEL=12 dBm
                              41138 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005
                              41146 !OTA:FRQ:FW UPD FAIL
                              41299 RFM69:SWR:SEND,TO=0,RETRY=0
                              41506 !RFM69:SWR:NACK
                              41508 RFM69:PTX:LEVEL=13 dBm
                              41519 RFM69:SWR:SEND,TO=0,RETRY=1
                              41725 !RFM69:SWR:NACK
                              41728 RFM69:PTX:NO ADJ
                              41762 RFM69:SWR:SEND,TO=0,RETRY=2
                              41969 !RFM69:SWR:NACK
                              41971 RFM69:PTX:NO ADJ
                              42014 RFM69:SWR:SEND,TO=0,RETRY=3
                              42221 !RFM69:SWR:NACK
                              42223 RFM69:PTX:NO ADJ
                              42258 RFM69:SWR:SEND,TO=0,RETRY=4
                              42465 !RFM69:SWR:NACK
                              42467 RFM69:PTX:NO ADJ
                              42477 RFM69:SWR:SEND,TO=0,RETRY=5
                              42684 !RFM69:SWR:NACK
                              42686 RFM69:PTX:NO ADJ
                              42721 !TSF:MSG:SEND,22-22-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:0
                              42729 RFM69:SWR:SEND,TO=0,RETRY=0
                              42950 !RFM69:SWR:NACK
                              42952 RFM69:PTX:NO ADJ
                              42995 RFM69:SWR:SEND,TO=0,RETRY=1
                              43005 RFM69:SWR:ACK,FROM=0,SEQ=124,RSSI=-55
                              43010 RFM69:ATC:ADJ TXL,cR=-55,tR=-80,TXL=12
                              43014 RFM69:PTX:LEVEL=12 dBm
                              43018 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:20
                              No detection
                              43026 MCO:SLP:MS=30000,SMS=1,I1=1,M1=1,I2=255,M2=255
                              43030 RFM69:SWR:SEND,TO=0,RETRY=0
                              43065 RFM69:SWR:ACK,FROM=0,SEQ=125,RSSI=-56
                              43069 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=11
                              43075 RFM69:PTX:LEVEL=11 dBm
                              43077 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                              43585 TSF:TDI:TSL
                              43587 RFM69:RSL
                              43589 MCO:SLP:WUP=-1
                              43591 TSF:TRI:TSB
                              43593 RFM69:RSB
                              43595 RFM69:SWR:SEND,TO=0,RETRY=0
                              43606 RFM69:SWR:ACK,FROM=0,SEQ=126,RSSI=-56
                              43610 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=10
                              43616 RFM69:PTX:LEVEL=10 dBm
                              43618 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000
                              43778 RFM69:SWR:SEND,TO=0,RETRY=0
                              43788 RFM69:SWR:ACK,FROM=0,SEQ=127,RSSI=-59
                              43792 RFM69:ATC:ADJ TXL,cR=-59,tR=-80,TXL=9
                              43796 RFM69:PTX:LEVEL=9 dBm
                              So when this occurs the only way I can think of to force another update would be update the sketch, refresh the repo in MysController and assign it to the node again. Therefore I wonder if this is intended behaviour and if so, if there is some other way to force an update after a failed one.
                              Thanks.
