  3. DIY Outdoor LED
DIY Outdoor LED
diyled12vdrivercree
60 Posts 12 Posters 28.4k Views 6 Watching
  • A
    A
    activemind
    Ready to rock n roll...
    Packaging is done though I dont know how weatherproof this is going to be..0_1463108803840_20160512_183825_resized.jpg
    AWIA 1 Reply Last reply
    • A activemind
      AWIA
      AWIA
      AWI
      @activemind looks good. I use these boxes outside. Just turn it upside down and your circuit should be protected from rain. I'm not sure your connectors will survive on the long run. (in fact i'm sure they won't :wink: )
      • A
        A
        activemind
        Thanks for your response. Whats my other options for connectors? I really dont want to hardwire it.
        -AM
        • A activemind
          -AM
          AWIA
          AWIA
          AWI
          @activemind you could either:
          • use waterproof connectors
          • don't use connectors and apply some sealing kit
          • ignore the rusting and take action when it stops working :wink:
          • A
            A
            activemind
            I think i will go with option#3 for now. These are landscape lights...world won't end if they go off after some time.
            Lets see how long it lasts and if its too short then i could look at other options.
            Plan to build 9 more of these ( total 10) and run some 14/2 LV this weekend. Will post pics when done.
            I tested the light last night at its prospective location and it works like a champ. Nrf range aint that bad for the price ☺
            -AM
              Something like this might be useful if you decide to go for waterproof connectors https://www.adafruit.com/product/743
              • A
                A
                activemind
                @mfalkvidd Those connectors look intersting, let me look at them in more detail.
                First one deployed today. Scheduled to come on at dusk and turn off at 10PM through Vera.
                Will update with a pic in action.
                Went ahead and ordered 8 more and now need to assemble the "mysensor boxes" for them.
                -AM
                • A
                  A
                  activemind
                  I changed the banana plugs to regular DC 2.1mm plugs and it looks less cluttered now.
                  Deployed it yesterday. Looks good.
                  Will upload pics if someone is interested.
                  -AM
                  • Boots33B
                    Boots33B
                    Boots33
                    Pics are always good. Please do upload
                    • A
                      A
                      activemind
                      Here are some pics of the "final" product:
                      Thanks to everyone for their input.
                      -AM
                      0_1465148123345_20160605_103454_resized.jpg 0_1465148136827_20160605_103520_resized.jpg
                      • A
                        A
                        activemind
                        So I deployed 5 more of these yesterday, so I have a total of 6 on the chain now.
                        The total current draw is ~5A at 12V...not bad!
                        Though I have an issue where the lights will go off for a little bit and then come back on.
                        Almost all of them are doing this and it doesnt happen at the same time so its not that the power is interrupted.
                        Makes me think as if the LED is heating up and shutting down and then when it cools down after a bit, it comes back on.
                        I tested them prior to deployment to make sure that they worked but didnt run them long enough that they would heat up. Plan on putting up one on the bench and leave it on longer to see if it does that.
                        But overall, not bad landscape light for 10 bucks!
                        -AM
                        • A
                          A
                          activemind
                          Update: The landscape light are programmed to come on in the evening and they did not turn on this evening. Further investigation yielded this:
                          The FET was touching the plastic case and melted it :-(
                          -AM
                            This might help a bit http://www.aliexpress.com/item/10pcs-Free-Shipping-Aluminium-TO-220-Heatsink-TO-220-Heat-Sink-Transistor-Radiator-TO220-Cooler-Cooling/32684240364.html
                            • A activemind
                              -AM
                              AWIA
                              AWIA
                              AWI
                              @activemind are you dimming the led or only switch it? A (swich) fet in full saturation should have an internal resistance of less than 0.1 ohm. It would be hard to get it heated that much with a current in the range of 1 amp..
                              It could well be that your fet is not in full saturation. Take a look at the data sheet..
                                A
                                A
                                activemind
                                Yup! I have them on order from China. Will try but I think I need to perforate the box too. Its drwaing ~5A which is amlost 60W. Maybe a little too much for a totally closed box!
                                -AM
                                • AWIA AWI
                                  A
                                  A
                                  activemind
                                  I am dimming as well as turning them on/off. There are 6 such lights on this FET and when all are on, the draw is around 5A. I am guessing thats a little too much for this tiny heatsink in an enclosed box. Need to change the heatsink and perforate the box.
                                  Thanks for the datasheet reminder. Let me go back and check whats the power I am dissipating when dimming these lights.
                                  -AM
                                  • A activemind
                                    -AM
                                    #57
                                    Most of the power will be dissipated in the lights. The power dissipated in the FET is the FET's resistance * current^2. If you are using a IRLZ44N FET I think that means 0.025 * 5^2 = 0.625W if you give the FET a signal of 5V. (0.025 ohm is the Static Drain-to-Source On-Resistance from the datasheet)
                                      A
                                      A
                                      activemind
                                      Heat dissapation in the lights is another issue I need to look into because with this new batch I ordered, they have been turning off after like 5 mins and then come back on by themselves. I think the heat sink on this new batch is not that good because the last batch did not do this.
                                      I am using them at 12V so the power would be ~4W. Not too much but still enough to get the sink hot!
                                      -AM
                                      • A activemind
                                        -AM
                                        The voltage makes no difference. 5A is still 5A.
                                          A
                                          A
                                          activemind
                                          you are right :-) brain fart
