  3. Another possible board - ATMega328, nRF socket, DHT22 socket, MOSFET, Uno pinout
board
39 Posts 17 Posters 24.1k Views 5 Watching
  • C
    C
    ceech
    If interested in another voltage regulator, I can equip a few boards with ADP3338, low dropout and low ground current regulators. Description:
    http://www.analog.com/en/power-management/linear-regulators/adp3338/products/product.html
    Any other wish - let me know.
    hekH AWIA 2 Replies Last reply
    • C ceech
      @ceech
      Are you the creator of the board?
      C 1 Reply Last reply
        @ceech
        C
        C
        ceech
        @hek
        I've made it, yes.
        • C
          C
          ceech
          This is the enclosure from the pictures:
          http://www.ebay.com/itm/Aluminum-Project-Box-Enclosure-Case-Electronic-DIY-1111-4-33-2-44-0-98-L-W-H-/300376371464?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item45efd3b108
          It's a tight fit. Needs a few strokes with the sand paper over the PCB. No need for drilling holes, though.
          And here is one more option for a voltage regulator:
          http://www.microchip.com/wwwproducts/Devices.aspx?product=TC2117
          • AWIA AWI
            @obstler42 Got mine also upload-75883dcf-6004-4676-8600-82332f72b86b
            Beautiful boards! I "assembled" all 4 of them and will transform them into Sensors this weekend. At this moment I am powering the boards as shown. Measurement: 4 mA active, < 15uA when in MySensors "Sleep" mode.... nothing removed.. So I don't see any need for replacing/ removing the LDO..
            Looks like a very good candidate for future expansion..
            O
            O
            obstler42
            How are you measuring power consumption? Are you powering from ftdi and measuring on the vcc cable? I've found that when TX/RX are connected and power consumption goes down that with some ftdi boards power is supplied through ftdi TX to the board RX, which makes exact measurements difficult. I only ever connect GND and VIN when measuring now.
            So I'd be really interested in how you can get 15 uA sleep with the stock regulator as I spent a whole day trying everything before desoldering it ;)
            AWIA 1 Reply Last reply
            • O obstler42
              AWIA
              AWIA
              AWI
              @obstler42 Oops... . Just tried again and found out that my uA meter was on "autorange". Only a factor 1000 off... I'm sorry for that, how can I compensate. for this stupid mistake..
              • O
                O
                obstler42
                I've made so many mistakes myself trying to optimize for lowest power consumption battery deplyment...
                BTW: another gotcha: don't leave the NRF24 on the board when connecting to a 5V FTDI... the FTDI connector voltage pin does NOT go through the voltage regulator but straight to VCC -- which means you'll be roasting the NRF24 with 5 V...
                • C ceech
                  AWIA
                  AWIA
                  AWI
                  @ceech Since you are the creator of this board. I am interested in how you use it. Especially how to operate this board on battery power and the power consumption..
                  C 2 Replies Last reply
                  • AWIA AWI
                    C
                    C
                    ceech
                    @AWI
                    I normally use a 12V car battery, for monitoring different values in the car. When the board is used in single cell battery applications, I go with a different type of voltage regulator. Normally I use TC2117 3.3V voltage regulator. Unfortunately those regulators are not available for purchase either form Farnell nor Microchip at the moment. They will be available on the 9th of March. So a bit of a set back. As for the enclosure, I use this:
                    And a little 5V solar cell, when appropriate:
                    there is also a matter of battery charging, which I leave to this fellow:
                    http://www.ebay.com/itm/221533778016?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                    I'm also preparing a new board, with integrated battery charger for LiPo, LiIon batteries and some other cool features.
                    • AWIA AWI
                      C
                      C
                      ceech
                      wrote on last edited by ceech
                      #30
                      @AWI Here is a graphical explanation of the socket connections:
                      SDA and SCL lines also have pull-up resistors. They are 10k.
                      • C ceech
                        AWIA
                        AWIA
                        AWI
                        @ceech Thanks!!
                        • R
                          R
                          rachmat aditiya27
                          how to upload custom bootloader?maybe you should put additional icsp port
                          • R rachmat aditiya27
                            C
                            C
                            ceech
                            #33
                            @rachmat-aditiya27 The board is kind of hardware oriented, so I ran out of space for the ICSP header. All the needed pins are available though. Either from remaining pins of the NRF24 socket, either from digital 11, 12 and 13 header pins.
                            • R
                              R
                              rachmat aditiya27
                              oh, okay got it :)
                              • R
                                R
                                Raoul Hecky
                                I just got 2 boards and I'em trying to test them. For now I only plugged a usb/serial adapter with an ftdi to the JP3 connector to program the board. The program is simple as Serial.begin(9600); Serial.println("test");
                                But that's not working. The programming was done successfully, and when I open the Serial monitor in the arduino ide, all I got is garbage characters. I have setup the correct communication option in the ide of course. The power VCC comes from my USB and I tried with 3.3v or 5v, but it did not change anything.
                                When I do the with a standard arduino mini pro, it works correctly, but not with the @ceech boards...
                                Any idea why and whats wrong here?
                                thanks
                                AWIA C 2 Replies Last reply
                                • S
                                  sharath krishna
                                  @Raoul-Hecky said:
                                  9600
                                  may be a baud rate setting error.... else its possible that there is a mismatch of frequency btw the controller HW and the software it is complied for..just a thought
                                  • R Raoul Hecky
                                    thanks
                                    AWIA
                                    AWIA
                                    AWI
                                    wrote on last edited by AWI
                                    #37
                                    @Raoul-Hecky Did you use the Arduino Pro or Pro mini (3.3v 8mHz) w/ ATmega328 setting?
                                    • R Raoul Hecky
                                      thanks
                                      C
                                      C
                                      ceech
                                      @Raoul-Hecky If you can't make the board to work properly, let me know. I'll send you a replacement :)
                                      • R
                                        R
                                        Raoul Hecky
                                        I finally made them work :)
                                        I was not using the right clock for programming, 16MHz instead of 8MHz...
                                        Thanks @AWI ;)
