  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • NeverDieN NeverDie
    So, I tried a couple more wild guesses, and the last guess was a match. It turns out that the scaling is off by a factor of 10x:
    I have no idea why the scaling is in error, but at least now I have an antidote. :)
    andrewA
    andrewA
    andrew
    @neverdie why do you use any scaling factor at all? be sure you export the grbl files with proper metrics, then apply the given metrics settings in flatcam (it has global and project specific settings as well), then no scaling is necessary.
    • andrewA andrew
      NeverDieN
      NeverDieN
      @andrew said in CNC PCB milling:
      I'm using Diptrace. I export from Diptrace an "N/C Drill" file. Then, when in flatcam, I open it as an Excellon file. Perhaps an "N/C Drill" file is not 100% compatible with an Excellon file opened from within flatcam? Perhaps there is some other way?
      • andrewA andrew
        NeverDieN
        NeverDieN
        It turns out to be a known issue for users of both diptrace and flatcam:: https://muut.com/i/flatcam/usage:diptrace-drill-file-off-sca
        • NeverDieN
          NeverDieN
          Here's my first milled PCB that's standalone:
          • NeverDieN
            NeverDieN
            #345
            I soldered on three 0805 components, but afterward I was surprised to find that all three were shorted (tested using a cotinuity meter):
            I thought I had been reasonably careful soldering them on too, so I'm not sure what went wrong.
            Scratch that. I found that the faults were measurement error. Re-testing it, it checks out 100%. No shorts. :)
            • NeverDieN
              NeverDieN
              #346
              This morning I soldered on the load switch IC. I then tested the circuit, and voilà, it works. :)
              Fortunately, solder doesn't seem attracted to the PCB substrate, and it behaves like solder mask. :)
              By the way, the PCB above it I cut out with tin snips, which is very fast and avoids all the dust generated if using the CNC to route the board outline to release it from the copper clad blank. The result looks crude, but that doesn't matter if it's just for prototyping.
              • NeverDieN
                NeverDieN
                #347
                @andrew Are you planning to provide more detail about how to setup and do double sided PCBs, or is it pretty much RTFM at this point? Just wondering. Your earlier posts were very thorough and helped a lot.
                andrewA 1 Reply Last reply
                • NeverDieN
                  NeverDieN
                  @executivul I noticed this youtube video, where they use mineral oil for dust containment:
                  https://www.youtube.com/watch?v=d9kfzRycQzE
                  Have you tried that?
                  E 1 Reply Last reply
                    E
                    E
                    executivul
                    @neverdie no, I haven't. I don't have the oil and I don't want to mess with anything non water soluble. To much hassle to clean the machine afterwards in case of splashing.
                    • NeverDieN
                      NeverDieN
                      #350
                      I think if I could upgrade the z-axis to use a ball-screw, I would do that, because I notice a lot of variability in cutting depth from one CNC session to the next. However, I don't see an easy way to upgrade this machine to use a ball screw.
                      So... alternative might be to add a linear motion tracker to the z-axis. Unlike a rotary encoder, it wouldn't be fooled by backlash. The question then, though, would be: which software to use? I don't know that chilipeppr can take advantage of the closed loop feedback.
                      • NeverDieN
                        NeverDieN
                        #351
                        So, notionially, the height measurement might look like:
                        https://www.amazon.com/Woodhaven-6015-Digital-Readout-6000-6004/dp/B004BUGW8E/ref=sr_1_16?ie=UTF8&qid=1514743618&sr=8-16&keywords=digital+height+router
                        but preferably with some kind of known digital interface for reading the height, so it doesn't have to be reverse engineered just to extract that basic information.
                        • NeverDieN
                          NeverDieN
                          #352
                          Something like this would probably do the business:
                          https://www.aliexpress.com/item/High-accuracy-Linear-Scale-5micron-linear-encoder-with-linear-sensor/32827867788.html?spm=2114.10010108.1000013.2.217d28ff67mKcv&traffic_analysisId=recommend_2088_1_90158_iswistore&scm=1007.13339.90158.0&pvid=986e2ba2-43bc-4db4-8edd-f9ca9d1f9b6e&tpp=1
                          It can resolve to 0.001mm.
                          • NeverDieN
                            NeverDieN
                            #353
                            On the other hand, retrofitting with just a ballscrew for the z-axis might be the cheapest/easiest next step:
                            https://www.aliexpress.com/item/1204-Ball-Screw-SFU1204-L-150mm-Rolled-Ballscrew-with-single-Ballnut-for-CNC-parts-RM1204-without/1998914494.html?spm=2114.search0104.3.138.DFiNws&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10344_10068_5000016_10130_10324_10342_10547_10325_10343_51102_10546_10340_5060016_10341_10548_10545_5130016_10084_10083_10307_5920011_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10594_10142,searchweb201603_25,ppcSwitch_4&algo_expid=e7be0642-ef8c-4a19-ac8b-5c19f850ec57-21&algo_pvid=e7be0642-ef8c-4a19-ac8b-5c19f850ec57&rmStoreLevelAB=5
                            Opinions, anyone? Also, what would be the best ballscrew to get?
                            Then, if that's still insufficient, adding a more powerful stepper motor would be next I suppose, to avoid skipping steps (assuming that's part of what's happening).
                            • E
                              E
                              executivul
                              No offence but upgrading with dro, ballscrew, stronger stepper, beefier driver, you end up with more cost than buying a real cnc platform like 3020 or 3040 😁
                              That machine has great results for its price, maybe relaxing tolerances a bit in design and using larger bits would achieve better predictibility.
                              Happy new year! Happy new toys!
                              • NeverDieN
                                NeverDieN
                                #355
                                Not sure why I'd have to buy a bigger machine in order to get quality parts, yet it is true that none of the 2418 kits appear to come with ballscrews. Strange how that is. In terms of just size alone, though, the 2418 seems about right for etching hobbyist circuit boards. If anything, it could be a little smaller. Does the sheer mass of the bigger machines somehow help with accuracy (maybe less vibration for instance)?
                                The ballscrews themselves, and even the linear scales, don't seem all that expensive, which is why I thought maybe upgrading even just the z-axis might make sense.
                                If nothing else, replacing the stepper motor with either a larger stepper motor (less skipping) or some kind of servo equivalent might at least put a cap on how far off the z-axis is from what is assumed. In that case, I would think the maximum error would less than or equal to the maximum possible backlash.
                                Anyhow, any suggestions appreciated.
                                • NeverDieN
                                  NeverDieN
                                  I'll need an adapter plate to go from Nema 17 to Nema 23. Will the existing motor drivers be able to handle a Nema 23?
                                  • NeverDieN
                                    NeverDieN
                                    #357
                                    Well, maybe the simplest upgrade would be to upgrade to a higher torque nema 17 motor, such as:
                                    https://www.aliexpress.com/item/Nema17-stepper-motor-60mm-length-1-7A-0-73Nm-7-3kg-cm-104Oz-in-High-torque/32727142878.html?spm=2114.search0104.3.1.RoU5IE&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_5000015_10151_10344_10068_10130_10324_10342_10547_10325_10343_51102_10546_10340_10548_10341_10545_5130015_10084_10083_10307_5920012_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10594_5060015_10142,searchweb201603_2,ppcSwitch_5&algo_expid=31255370-90b4-4695-94c0-997d9d68e388-0&algo_pvid=31255370-90b4-4695-94c0-997d9d68e388&rmStoreLevelAB=5
                                    or
                                    https://www.aliexpress.com/item/14-1-Planetary-Gearbox-High-Torque-Nema-17-Stepper-1-68A-CNC-Robot-3D-Printer/32585666715.html?spm=2114.search0104.3.22.RoU5IE&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_5000015_10151_10344_10068_10130_10324_10342_10547_10325_10343_51102_10546_10340_10548_10341_10545_5130015_10084_10083_10307_5920012_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10594_5060015_10142,searchweb201603_2,ppcSwitch_5&algo_expid=31255370-90b4-4695-94c0-997d9d68e388-3&algo_pvid=31255370-90b4-4695-94c0-997d9d68e388&rmStoreLevelAB=5
                                    or perhaps even
                                    https://www.aliexpress.com/item/High-Torque-NEMA-17-Planetary-Gearbox-Stepper-Motor-25N-m-3472oz-in-100-1-40mm-Motor/32789989913.html?spm=2114.search0104.3.56.RoU5IE&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_5000015_10151_10344_10068_10130_10324_10342_10547_10325_10343_51102_10546_10340_10548_10341_10545_5130015_10084_10083_10307_5920012_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10594_5060015_10142,searchweb201603_2,ppcSwitch_5&algo_expid=31255370-90b4-4695-94c0-997d9d68e388-8&algo_pvid=31255370-90b4-4695-94c0-997d9d68e388&rmStoreLevelAB=5
                                    Not sure what kind of impact it might have on the feedrate....
                                    The idea is that the higher torque would eliminate missed steps, provided that the feedrate is low enough.
                                    rmtuckerR 1 Reply Last reply
                                      or
                                      or perhaps even
                                      rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      @neverdie
                                      I think you should start by altering the acceleration/Max velocity settings etc in grbl.
                                      Slow them down a little:grinning:
                                      • rmtuckerR rmtucker
                                        @neverdie
                                        NeverDieN
                                        NeverDieN
                                        #359
                                        @rmtucker said in CNC PCB milling:
                                        I don't see those parameters exposed in flatcam or in chilipeppr either. I guess I have to set them by issuing the grbl commands manually?
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          @neverdie
                                          Yes or use bCNC to set them.
