  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • NeverDieN NeverDie
    Even after all this tweaking, the z-axis was off by 0.048mm after the latest set of probing.
    E
    E
    executivul
    @neverdie said in CNC PCB milling:
    What do you mean by "off"? Afaik grbl doesn't have a M48 equivalent command for probe/machine repeatability... So it can't probe the same place automatically. You have to write your own code for that, based on G32.2 command, take a few measurements and see the difference.
    If you mean across the whole board, depending on the size of the measured area that's not bad at all.
      andrewA
      andrewA
      andrew
      @neverdie could you please explain how did you find/measure this? also please let me know the details of the executed job, including the G code generation properties/settings (e.g. feed rate, depth, multiple passes etc.) used in flatcam.
      NeverDieN 1 Reply Last reply
      • andrewA andrew
        NeverDieN
        NeverDieN
        #383
        @andrew said in CNC PCB milling:
        1. Decided upon an origen. Used Chilipeppr to "run test probe" to find the zero z-height. Zeroed x,y,z at that location.
        2. Did an autolevel, at 1mm spacing, over a 20x10mm area.
        3. Following this, returned to x=0, y=0. Ran another test probe. Ideally it would have come back as z=0. Instead, it came back as z=-0.048.
        So, if at that point I were to actually run g-code with a cutting depth of z=-0.05, it would barely scratch the surface. Somehow during the 1mm autolevel probing, z became uncalibrated. If I were to re-zero z based on the second test probe, it would cut, but the cutting depth wouldn't be uniform.
        Anyhow, my new rule is that if I come across a situation like the above, I throw out the auto-leveling and start over rather than executing the g-code. Often, the next autoleveling will have less discrepancy by step 3.
        rmtuckerR andrewA 2 Replies Last reply
          rmtuckerR
          rmtuckerR
          rmtucker
          @neverdie
          Maybe run step 1
          Then run some g-code but above the job.(for a few mins).
          Then run step 3.
          This could be an autolevel problem.
          • rmtuckerR rmtucker
            @neverdie
            Maybe run step 1
            Then run step 3.
            NeverDieN
            NeverDieN
            @rmtucker said in CNC PCB milling:
            Maybe run step 1
            Then run step 3.
            How might that help?
            rmtuckerR 1 Reply Last reply
              Maybe run step 1
              Then run step 3.
              rmtuckerR
              rmtuckerR
              rmtucker
              @neverdie
              What if you have broken .048 off the end of the tool during autolevel?
              So run some g-code above the job then re-probe so you know you have not twatted the tool.:relaxed:
                @neverdie
                NeverDieN
                NeverDieN
                #387
                Good point. I'll have a closer look for that the next time it happens.
                Also, I'll try repeating the test using a dull bit (which presumably won't break) and see whether it still happens or not.
                Thanks!
                • E
                  E
                  executivul
                  wrote on last edited by executivul
                  #388
                  @NeverDie grbl 1.1 probing command is G38.2 Z-10 F25 where Z tells it how low should go before erroring if it doesn't touch and F is the speed.
                  You should try manually issuig G38, then G92 Z0 to set new Z0 position and then finally G0 Z10 F100 to lift the probe, rinse and repeat without the G92, how repeatable is the reading, does it stay at 10.00?
                  Then do the air job, or some simple moving (G0 X5 Y5 Z5, G0 X0 Y0 Z10 a few times )and retest manually with G38
                  LE. The probing command is G38.2, I've edited the post to correct it.
                    andrewA
                    andrewA
                    andrew
                    if your probe speed is too fast, then it could push the pcb at the given points and also it could damage your tip's end, as it was mentioned by @rmtucker, which could cause this issue as well.
                      did you manage to create double sided PCB jobs in the meantime based on my suggestion and on flatcam's documentation? it is not a hardcore process, let me know if you stuck at a given step.
                      Not sure what kind of pins to use for the alignment.
                      andrewA
                      andrewA
                      andrew
                      I missed this reply from you.
                      so, you have to define the alignment holes, typically outside of the actual pcb area, in the "frame".
                      you have to define two of them, the rest will be calculated automatically.
                      the steps are exactly the same as that you can see on http://flatcam.org/manual/procedures.html#side-pcb
                      see the pic below. note, that you don't have to write the coordinates to the input boxes manually, once you click on the design area the corresponding coordinates will be copied to the clipboard, so you can use ctrl-v to fill out the settings.
                      • click on the picture to define the axis (X in this example)
                      • copy the corresponding coordinates to the point/box input filed
                      • click on the design area to define the exact location of the first alignment hole (left side of the actual pcb)
                      • copy the corresponding coordinates to the alignment holes input filed
                      • click on the design area to define the exact location of the first alignment hole (right side of the actual pcb)
                      • copy the corresponding coordinates to the alignment holes input filed. the two set of coordinates have to be separated by coma.
                      • configure the alignment holes' drill size
                      • click on the create align drill button and you're done. back on the project tab you can find a new drill job which you have to further process to create the belonging G code from it.
                      • andrewA andrew
                        NeverDieN
                        NeverDieN
                        @andrew Are you using male header pins for your alignment? How deep are you drilling the holes them?
                        andrewA 1 Reply Last reply
                          andrewA
                          andrewA
                          andrew
                          @neverdie yes, I use male pins, with 0.7mm drill (so it is tight for the pin), 5mm depth. but this is really up to you, choose anything which you have easy access to.
                          • andrewA andrew
                            NeverDieN
                            NeverDieN
                            @andrew
                            With single sided PCB, I soldered the ground wire (for probing) to the copper cladding, just as the Chilipeppr author did. How are you handling it for two sided? If I do it that way for two sided, the solder bump may prevent the board laying flat on the wasteboard.
                            E andrewA 2 Replies Last reply
                              @andrew
                              E
                              E
                              executivul
                              @neverdie I use a wood screw in the sacrificial board holding a piece of metal as a "clamp" I slide it over the board (1mm overlap) and clip one alligator clip to the screw, the other to the bit. After probing I slide it out of the way. The metal piece is about 10cm long and it's left in place for the life of the wood board.
                              • andrewA
                                andrewA
                                andrew
                                hackaday just released a relevant post:
                                https://hackaday.com/2018/01/04/guide-why-etch-when-you-can-mill/
                                  @andrew
                                  andrewA
                                  andrewA
                                  andrew
                                  @andrew
                                  I use some flat metal weight connected to the given wire, placed on top of the pcb.
                                  • andrewA andrew
                                    NeverDieN
                                    NeverDieN
                                    #397
                                    Interesting that the engraving bits he liked the best were the 30 degree 0.1mm bits. So far, that's been my preference as well.
                                    YveauxY 1 Reply Last reply
                                      YveauxY
                                      YveauxY
                                      @neverdie Possibly too late, but it still might contain some handy tips: https://hackaday.com/2018/01/04/guide-why-etch-when-you-can-mill
                                      • NeverDieN
                                        NeverDieN
                                        #399
                                        @yveaux said in CNC PCB milling:
                                        It nicely sums up the biggest challenge of all:
                                        The biggest challenge in this DIY process is getting a correct and consistent cutting depth. These V-bits yield a wider cut the deeper you go, effectively robbing you of precious engraving resolution. If you do not tune in just the right depth, some traces will come out too thin and frail.
                                        The results I'm getting seem random. Sometimes it's great. Sometimes it's totally unusable (obliterated traces). Some of the time it's usable, but only just barely.
                                        So, I'm trying to think of a better approach that might deal with that. Maybe one way might be to start every etching session by running @executivul 's calibration traces. If it's cutting too deep, adjust, and then run again. When it's finally cutting right, then cut the desired PCB traces.
                                        I don't know what the answer is, but that's where it currently stands with me.
                                        The alternative is to just make a number of boards. Then cherry pick the good ones and dispose of the rest.
                                        • NeverDieN
                                          NeverDieN
                                          #400
                                          I think I've found at least one reason for the trouble I've been having: sometimes the double sided scotch tape hasn't been holding the board completely flat against the waste board. Instead, during the milling process, which has a lot of vibration, it can pop up in the area being milled. When that happens, it's effectively the same as having the milling go much deeper, and so traces can be obliterated. Hence, I may try the Shurtape GG-200 that was recommended in the Hackaday article.
                                          It may be that the copper clad boards I'm using just aren't flat enough in the first place. Add to that a waste board that may not be perfectly flat either, and it's not a good formula for keeping everything perfectly flat, which is evidently what it needs to be. The tape itself can't compensate for too large a mismatch.
                                          So, I'd like to try the earlier idea of milling the waste board flat. Just not sure how to do that.
                                          I would't be surprised if single sided copper clad boards are inherently prone to warping. If you think about it, the copper can expand/contract with temperature, and if it's on only one side....Unless the substrate has the same coefficient of thermal expansion, the result will inevitably be warping. The same would be true if the substrate is affected by humidity.
                                          The Hackaday article does mention that it's not necessarily easy to find good copper clad boards. He hints that it has been an ongoing issue over time. He gives a reference for an ebay board vendor in England that he currently likes, but unfortunately that doesn't help me much.
                                          What blank copper clad boards have folks here found that they like?
                                          zboblamontZ NeverDieN 2 Replies Last reply
