  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 768.5k Views 27 Watching
  • zboblamontZ zboblamont
    @neverdie Wall thickness as well as the material characteristics determine tube stiffness, comparison on the modulus alone is misleading.
    As well as carrying the load, the section must also support it's own weight, one aspect where carbon fibre will out-perform steel.
    NeverDieN
    NeverDieN
    #601
    @zboblamont said in CNC PCB milling:
    Granted. What's a better way to compare them based on the available info?
    • NeverDieN NeverDie
      zboblamontZ
      zboblamontZ
      zboblamont
      @neverdie Bluntly no idea whatsoever, I was merely highlighting the incorrect interpretation.
      There is no magic bullet, that's why engineers are still in business, the analysis can be complex.
      Were I looking at such a project it would to the lightest and stiffest complex alloy extrusions I would be focusing attention, and figuring out how best to combine them in a frame with minimal deformation.
      Complex alloy extrusions are cheap sections with known quantified parameters and constraints, composites are relatively new, and their interconnections are less well understood than with conventional materials. unless you work for Lotus or Ferrari...
      • coddingtonbearC
        coddingtonbearC
        coddingtonbear
        @NeverDie -- the motors used in 1610 CNC mills are generally what are called a "775 Motor". You might be able to find other specs, but the ones I've found suggest that at 24V and no load , they claim 7kRPM -- http://linksprite.com/wiki/index.php5?title=File:Motor_performance_parameter.png; I'm not sure how much slower we could expect it to be while milling. As far as actually measuring this, there are devices you could buy, but you could pretty easily fabricobble your way to an answer if you wanted to make a project out of it: http://www.instructables.com/id/Measure-RPM-DIY-Portable-Digital-Tachometer/.
        I have the same mill as you, and swapped for one of these https://www.amazon.com/gp/product/B074FVKRZM/ and have had much better results so far.
        NeverDieN RFM69R 3 Replies Last reply
        • coddingtonbearC coddingtonbear
          NeverDieN
          NeverDieN
          @adam-coddington said in CNC PCB milling:
          Any less vibration also?
          • coddingtonbearC
            coddingtonbearC
            coddingtonbear
            wrote on last edited by coddingtonbear
            #605
            I actually haven't had much trouble with vibration, so I can't really speak to that. The problems I've had have mostly been around runout, occasional arcing in the old spindle causing enough EMI to reset the microcontroller, Z-Axis backlash, the super-slow milling speeds necessary when spinning at such a low RPM, copper flakes everywhere, etc. Having the faster (and, maybe unfortunately, heavier) brushless spindle has been great for all of those things.
            I happened to notice you looking into tool changers; if you're using bCNC, you might not have noticed the tool change workflow -- it's actually pretty elegant and will automatically re-zero your Z-Axis. It does require having a limit switch on at least the top of that axis, though. I used to hate tool changes given how tedious they were, but now they're pretty effortless.
            • NeverDieN
              NeverDieN
              #606
              Seems like most DC CNC spindles can do no more than 12,000RPM (if that). Which leads me to wonder: would replacing a spindle with a dremel be advisable? A dremel has an adjustable range of 5,000 to 35,000RPM.
              Anyone tried this? Any downsides?
              [Edit: I see that a number of the AC powered spindles can go as high as 24,000RPM. e.g.: https://www.aliexpress.com/item/1-5kw-Air-Cooled-Motor-cnc-Spindle-Motor-Spindle-110v-220v-ER11-CNC-Square-Milling-Machine/32850346694.html?spm=2114.search0104.3.53.6e8c5be0Uqy1Fs&ws_ab_test=searchweb0_0,searchweb201602_5_10152_5711320_10151_10065_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10307_5711220_5722420_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_5&algo_expid=42fb944e-06c3-4821-8a8b-3b49200ec2fd-8&algo_pvid=42fb944e-06c3-4821-8a8b-3b49200ec2fd&transAbTest=ae803_3&priceBeautifyAB=0
              Interestingly, I did find one that claims to do up to 60,000RPM: https://www.aliexpress.com/item/800W-electric-water-cooling-spindle-110V-ER11-with-65MM-diameter-158MM-length-for-cnc-router/32653823271.html?spm=2114.search0104.3.1.3bda4ab3F2KVPE&ws_ab_test=searchweb0_0,searchweb201602_5_10152_5711320_10151_10065_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10307_5711220_5722420_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_5&algo_expid=9a9cc87f-4ffa-46c7-bca9-1bba7f82e5bc-0&algo_pvid=9a9cc87f-4ffa-46c7-bca9-1bba7f82e5bc&transAbTest=ae803_3&priceBeautifyAB=0
              That sure would be interesting!
              • NeverDieN
                NeverDieN
                I suppose another factor worth considering is audible noise. Here's one that claims to be relatively quiet:
                https://www.inventables.com/technologies/quiet-cut-spindle
                https://www.youtube.com/watch?v=g259rm2tfbA
                It only goes to 12,000RPM, but I may be willing to trade speed for quiet. I can only assume that the 60000RPM unit isn't very quiet. Not at all sure how the brushless motor would compare. Possibly quieter?
                • NeverDieN
                  NeverDieN
                  I upgraded my CNC LoRa remote monitor into a more universal remote control by making it more compact and giving it 14 buttons:
                  It turns out I can count the number of auto-leveling probes performed, in real time, because the total CNC current briefly drops to almost zero each time the probe makes contact with the PCB. Thus, this gives me a way of tracking auto-leveling progress remotely. :)
                  • NeverDieN
                    NeverDieN
                    #609
                    I went ahead and ordered this spindle upgrade, which looks as though it may be the same (?) as the Quiet Cut spindle.
                    https://www.aliexpress.com/item/BEST-300W-Mini-Spindle-motor-DC12-48V-ER11-12000rpm-Engraving-milling-grind-air-cooling-spindle-motor/32799767627.html?spm=a2g0s.13010208.99999999.262.sgcb5Q
                    • RFM69R
                      RFM69R
                      RFM69
                      I'm also looking for a good spindle so thanks for the links and comments.
                      Thought I'd share this link text. Its the 30A High Power Single way H-bridge DC Motor Driver Module. That "Frank From Germany" found and is using as part of his tool changing, along with a current sensor so he can brake, reverse and control speed on his tool changer, via arduino, to make it all work.
                      RFM69R 1 Reply Last reply
                        RFM69R
                        RFM69R
                        RFM69
                        @coddingtonbear What materials are you milling ?
                        I want to get a spindle for mostly wood, just hobby, but don't want to go too cheap, and face buying over when I realize its just not > W
                        coddingtonbearC 1 Reply Last reply
                        • RFM69R RFM69
                          RFM69R
                          RFM69R
                          RFM69
                          wrote on last edited by RFM69
                          #612
                          Just found a more powerful one...
                          @rfm69 link text
                          So could this or the 30A version, power an 800w DC 0-48V motor ?
                          NeverDieN 1 Reply Last reply
                          • RFM69R RFM69
                            @rfm69 link text
                            NeverDieN
                            NeverDieN
                            #613
                            @rfm69
                            800/48=16.7amp. Therefore, at least in terms of amps alone, the first (cheaper) one you posted should easily be sufficient, if you're running it just full-on or full-off.
                              @rfm69
                              RFM69R
                              RFM69R
                              RFM69
                              @neverdie Thanks thats what I thought, but I'm confused about the voltage range of some of the spindles. They use variable DC voltage to regulate speed ? I don't thinks so, they use PWM at any voltage I provide it with, no ?
                              So the V range specified on DC spindle is just what it can be driven at, and its the PWM which actually controls the speed ? Is this right ?
                              • RFM69R RFM69
                                NeverDieN
                                NeverDieN
                                @rfm69 I believe so, at least for brush motors. For brushless, I get the impression the motors are missing the electronics which tell them when to alternate their currents internally, so (it appears) you need a special driver to make them move at all. I'm not sure how, or even if, PWM fits into that. Maybe motor speed is all managed entirely through the brushless controller, and all the brushless controller wants as input is pure DC?
                                RFM69R coddingtonbearC 2 Replies Last reply
                                  RFM69R
                                  RFM69R
                                  RFM69
                                  @neverdie :) Now I'm even more confused with this difference between brushed and brushless...
                                  • RFM69R RFM69
                                    NeverDieN
                                    NeverDieN
                                    @rfm69 The main advantages of brushless, as I understand it, are longer motor life (because no brushes to wear out) and probably less EMI if it's done right.
                                    • NeverDieN
                                      NeverDieN
                                      Also, I should think it would be easy for a brushless controller to provide accurate tachometer readings.
                                      • NeverDieN
                                        NeverDieN
                                        #619
                                        I'll probably get this to power my new spindle after it arrives:
                                        https://www.amazon.com/gp/product/B0716XVR7P/ref=ox_sc_act_title_1?smid=AFHAE9RJVUMB&psc=1#customerReviews
                                        Instead of PWM, I'll just adjust the voltage directly. Wish they could have given it a normal power plug for its AC input voltage....
                                        • NeverDieN
                                          NeverDieN
                                          #620
                                          In any case, I suspect that greater control over the speed of the spindle will lead to greater control over vibration as well. i.e. select a speed where there is less resonance/vibration of the pcb/spindle. Using an accelerometer to measure vibration, perhaps that could even be made somewhat automatic.
                                          Alternatively, a trick I've seen used is to continuously vary the RPM over some range, so that the amount of time spent dwelling at the resonance frequency is reduced. That would also be easier to implement.
                                          I imagine that either method might also lead to a generally quieter machine, which, IMHO, is generally desirable.
