  3. FOTA with MYSController does not work with sleeping Sensebender Micro
4 Posts 3 Posters 1.7k Views 2 Watching
  • A
    A
    arraWX
    wrote on last edited by arraWX
    I use the "official" sketch for the Sensebender Micro. However, with "MEASURE_INTERVAL = 6000" and "FORCE_TRANSMIT_INTERVAL = 1" in order to transmit every 6 seconds.
    Gateway is rpi ethernet.
    MYSController 1.0.0beta (build 3316), "Sensebender board = TRUE", "Battery-powered / sleeping = TRUE" gives the following message but nothing more happens.
    If I replace sleep by wait in the sketch and set "Battery-powered / sleeping = FALSE" in MYSController then FOTA works flawlessly. But then node is not sleeping.
    Anyone knows how to get it working with a sleeping node?
    tekkaT 1 Reply Last reply
    • A arraWX
      tekkaT
      tekkaT
      tekka
      @arrawx You should enable smart sleep.
      Substitute:
      https://github.com/mysensors/SensebenderMicro/blob/master/Arduino/SensebenderMicro/SensebenderMicro.ino#L221
      for
      sleep(MEASURE_INTERVAL, true);
      and in MYSController set Sensebender board = TRUE, Battery-powered/sleeping = TRUE
      A 1 Reply Last reply
      • tekkaT tekka
        Substitute:
        for
        A
        A
        arraWX
        @tekka Thank you. However, it turned out that your advice was only part of the solution.
        In order to solve the problem I had to also change the sensebender from 2.1.1 to development branch.
        My rpi gateway uses development branch (due to reasons discussed here). Does the version mismatch between node and gateway explain why FOTA was not working?
        M 1 Reply Last reply
        • A arraWX
          manutremo
          wrote on last edited by manutremo
          @arrawx may be related to this?
