  3. Sketch for Lightning Sensor
58 Posts 14 Posters 41.0k Views 11 Watching
  • alexsh1A alexsh1
    @Sparkman it is a different board made (or designed) by a UK company.
    We are having a real British summer over here :-)))
    LIGHTNING DETECTED
    Lightning ~20km away
    LIGHTNING DETECTED
    LIGHTNING DETECTED
    Lightning ~6km away
    LIGHTNING DETECTED
    Lightning ~6km away
    LIGHTNING DETECTED
    Lightning ~6km away
    LIGHTNING DETECTED
    Lightning ~6km away
    LIGHTNING DETECTED
    Lightning ~6km away
    LIGHTNING DETECTED
    Lightning ~5km away
    NeverDieN
    NeverDieN
    @alexsh1
    There doesn't appear to be audio input to this board, nor a microphone on the board. So, how does it estimate the distance to the lightening?
    SparkmanS 1 Reply Last reply
    • NeverDieN NeverDie
      @alexsh1
      SparkmanS
      SparkmanS
      Sparkman
      @NeverDie All these breakout boards are based on this chip: http://ams.com/eng/Products/Wireless-Connectivity/Wireless-Sensor-Connectivity/AS3935. They use a proprietary method to figure out distance and is not based on sound.
      Cheers
      Al
      NeverDieN 1 Reply Last reply
      • SparkmanS Sparkman
        Cheers
        Al
        NeverDieN
        NeverDieN
        Cheers
        Al
        Any impression yet as to how accurate its distance estimates are?
        SparkmanS alexsh1A 2 Replies Last reply
          Cheers
          Al
          SparkmanS
          SparkmanS
          Sparkman
          @NeverDie No, as we've had very little lightning since I started using it.
            Cheers
            Al
            alexsh1A
            alexsh1A
            alexsh1
            @NeverDie Al, was quicker replying to your question. :-)
            yes, I think it is accurate for my needs - if a lightning detected at, say, 10km+/- 1km this is ok. How accurate do you want it to be?
            This is a great technology
            • alexsh1A alexsh1
              NeverDieN
              NeverDieN
              #46
              I'm not sure, but more accurate than lightningmaps.com or it's a no-go. I've played with lightningmaps.com during a few thunderstorms, and although it's great for getting a general idea of lightning strike rate and density, I was surprised that it seems to miss a lot of detections entirely that both my eyes and ears have confirmed. e.g. some strikes that were big enough to rattle the windows didn't show up at all on lightningmaps. Some of the others were detected, but the map plot of the strike was wrong by maybe 10 miles or so.
              alexsh1A 1 Reply Last reply
                alexsh1A
                alexsh1A
                alexsh1
                @NeverDie I have not tested this sensor long enough, but recently we have had torrential rain, lightning, etc - you can see some data I published above. The sensor did not miss a single one. There are a few parameters you can alter (noise floor). One has to setup it correctly. I have not started looking into converting the sketch for MySensors yet
                • alexsh1A
                  alexsh1A
                  alexsh1
                  #48
                  I have adopted the MOD-1016 module (https://www.embeddedadventures.com/datasheets/MOD-1016_hw_v8_doc_v4.pdf) for MySensors if anyone is interested:
                  Copyright (c) 2016, Embedded Adventures
                  All rights reserved.
                  Contact us at source [at] embeddedadventures.com
                  Redistribution and use in source and binary forms, with or without
                  modification, are permitted provided that the following conditions are met:
                  - Redistributions of source code must retain the above copyright notice,
                    this list of conditions and the following disclaimer.
                  - Redistributions in binary form must reproduce the above copyright
                    notice, this list of conditions and the following disclaimer in the
                    documentation and/or other materials provided with the distribution.
                  - Neither the name of Embedded Adventures nor the names of its contributors
                    may be used to endorse or promote products derived from this software
                    without specific prior written permission.
                  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
                  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
                  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
                  ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
                  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
                  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
                  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
                  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
                  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
                  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
                  THE POSSIBILITY OF SUCH DAMAGE.
                  #define MY_NODE_ID 15
                  #include <Wire.h>
                  #include <AS3935.h> // AS3935 MOD-1016 by Embedded Adventures
                  volatile bool detected = false;
                   //-----------------IMPORTANT--------------------
                   //---------------CHANGE SETTINGS HERE-----------
                  #define IRQ_pin 2
                  #define AS3935_TUNE_CAPS     6 // <-- SET THIS VALUE TO THE NUMBER LISTED ON YOUR BOARD
                  #define AS3935_INDOORS       1 // AS3935_INDOORS=1 indoors, AS3935_INDOORS=0 outdoors
                  #define AS3935_NOISE_FLOOR   6
                  #define AS3935_ENABLE_DISTURBERS 1 // 0 or 1
                  #define CHILD_ID_DISTANCE 1
                  #define CHILD_ID_INTENSITY 2
                  MyMessage msgDist(CHILD_ID_DISTANCE, V_DISTANCE);
                  MyMessage msgInt(CHILD_ID_INTENSITY, V_VAR1);
                    Serial.begin(115200);
                    while (!Serial) {}
                    Serial.println("MOD-1016 (AS3935) Lightning Sensor");
                    Serial.println("beginning boot procedure....");
                    Wire.begin();
                    mod1016.init(IRQ_pin);
                    //Tune Caps, Set AFE, Set Noise Floor
                    //autoTuneCaps(IRQ_pin);
                    mod1016.setTuneCaps(AS3935_TUNE_CAPS);
                  delay(2);
                  #if AS3935_INDOORS == 1
                    mod1016.setIndoors();
                    #else
                    mod1016.setOutdoors();
                  delay(2);
                  mod1016.setNoiseFloor(AS3935_NOISE_FLOOR);
                  delay(2);
                  #if AS3935_ENABLE_DISTURBERS == 1
                    mod1016.enableDisturbers();
                  #else
                    mod1016.disableDisturbers();
                  //mod1016.calibrateRCO();
                  delay(2);
                    Serial.println("TUNE\tIN/OUT\tNOISEFLOOR");
                    Serial.print(mod1016.getTuneCaps(), HEX);
                    Serial.print("\t");
                    Serial.print(mod1016.getAFE(), BIN);
                    Serial.print("\t");
                    Serial.println(mod1016.getNoiseFloor(), HEX);
                    Serial.print("\n");
                    pinMode(IRQ_pin, INPUT);
                    attachInterrupt(digitalPinToInterrupt(IRQ_pin), alert, RISING);
                    Serial.println("after interrupt");
                      // delay execution to allow chip to stabilize.
                    delay(1000);
                  void presentation()  {
                    sendSketchInfo("Lightning Sensor MOD-1016", "1.0");
                    present(CHILD_ID_DISTANCE, S_DISTANCE);
                    present(CHILD_ID_INTENSITY, S_CUSTOM);
                    if (detected) {
                      translateIRQ(mod1016.getIRQ());
                      detected = false;
                  void alert() {
                    detected = true;
                  void translateIRQ(uns8 irq) {
                    switch(irq) {
                        case 1:
                          Serial.println("Noise detected");
                          break;
                        case 4:
                          Serial.println("Disturber detected");
                          break;
                        case 8:
                          Serial.println("Lightning detected!");
                          printandsendToGW();
                          break;
                  void printandsendToGW() {
                    int distance = mod1016.calculateDistance();
                    unsigned int lightning_intensity = mod1016.getIntensity();
                    if (distance == -1)
                      Serial.println("Lightning out of range");
                    else if (distance == 1)
                      Serial.println("Distance not in table");
                    else if (distance == 0)
                      Serial.println("Lightning overhead");
                    else {
                      Serial.print("Lightning ~");
                      Serial.print(distance);
                      Serial.println("km away\n");
                      Serial.print("Lightning Intensity: ");
                      Serial.println(lightning_intensity);
                      send(msgDist.set(distance));
                      send(msgInt.set(lightning_intensity));
                  You have to change the sketch according to your module settings
                  skywatchS 1 Reply Last reply
                  • skywatchS
                    skywatchS
                    skywatch
                    #49
                    I ordered one form embedded adventures on 27/7 - Now it is 3/9 and still nothing.
                    Waiting to hear from them....
                    That's the whole truth.
                    • skywatchS skywatch
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @skywatch give them a call or send a e-mail. Maybe your order was lost in post. Happens.
                      My order arrived in 2 days from Embedded Adventures
                      • skywatchS
                        skywatchS
                        skywatch
                        OK - finally got board, seems the problem was in the warehouse. I got email to say it had been sent and it never did. At least I can try it out soon and see how it compares to the current lightning sensors I use.
                        • alexsh1A alexsh1
                          #include <Wire.h>
                          #define IRQ_pin 2
                            while (!Serial) {}
                            Wire.begin();
                          delay(2);
                            #else
                          delay(2);
                          delay(2);
                          #else
                          delay(2);
                            Serial.print("\t");
                            Serial.print("\t");
                            Serial.print("\n");
                            delay(1000);
                            if (detected) {
                              detected = false;
                          void alert() {
                            detected = true;
                            switch(irq) {
                                case 1:
                                  break;
                                case 4:
                                  break;
                                case 8:
                                  printandsendToGW();
                                  break;
                            if (distance == -1)
                            else {
                          skywatchS
                          skywatchS
                          skywatch
                          @alexsh1
                          Is your example using I2C or SPI? I can't make it out.
                          I'd guess I2C, but want to make sure first.....
                          Thank you
                            NeverDieN
                            NeverDieN
                            #53
                            @skywatch said in Sketch for Lightning Sensor:
                            Please do let us know how it compares and which one you like the best.
                              skywatchS
                              skywatchS
                              skywatch
                              @neverdie Last night was the first lightning to test it out - 3 storm cells went through with hail and lightning, but nothing from the sensor :(
                              So today I have rewired it, made some changes to the program and if we get lightning tonight I might have some news :)
                              Nca78N 1 Reply Last reply
                                Nca78N
                                Nca78N
                                I have the same problem. Insane storms, and nothing from the sensor, the bast I had were events identified as noise. I've had storms around and sensor doesn't detect anything, very disappointing.
                                I've tried to disconnect my laptop from main so it's not grounded (seem it can be a problem) but I still had nothing.
                                • Nca78N Nca78
                                  skywatchS
                                  skywatchS
                                  skywatch
                                  #56
                                  @nca78 As you might expect there was no lightning last night to test it. :(
                                  It's taken 2 years to get this far as storms are not frequent around here.
                                  My sensor is from Embedded Adventures, is that the same one you are using?
                                  I run it from 5V, it is set for 'indoors' and is placed on a window sil. I can see 'noise' if I place a laptop near to it. If I enable 'disturbers' I see them flooding in. The noise floor is set to 3 and I get no triggers at that level. Previously the noise floor was at 6.
                                  So for the moment I am a little frustrated/disappointed with this 'sensor'. But I have to wait for the next storm, which should be tonight or tomorrow :)
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @skywatch I have the same sensor for months working like a charm. Sadly I had to disable it as I had one node and several sensors interfering with each other.
                                    I will have to have the lightning sensor on a separate node
                                    • alexsh1A alexsh1
                                      BTW, I am not sure the sensor is similar to what you guys have.
                                      K
                                      K
                                      kijagas663
                                      Embedded Adventures is a fake website anymore. They don't send the mod-1016 sensor.
                                      The website still gets payment for products but there is no shipment.
                                      embedded adventures is fraudulent.
