  3. Node running on supercaps and a solar panel.
59 Posts 5 Posters 11.2k Views 6 Watching
  • alexsh1A alexsh1
    @neverdie you mean like using a mosfet or something?
    It is used to supply 3.3v to atmega328p, I do not think I can just turn it off.
    N Offline
    N Offline
    @alexsh1 said in Node running on supercaps and a solar panel.:
    Sorry, I meant switch to "pass through".
    alexsh1A 2 Replies Last reply
    • N NeverDie
      alexsh1A Offline
      alexsh1A Offline
      alexsh1
      @neverdie Yes, that's on my 'to do' list. However, right now I'd like to see how much I can extract from supercap directly wired to the node.
        How much does the supercap self discharge?
        alexsh1A 1 Reply Last reply
          alexsh1A Offline
          alexsh1A Offline
          alexsh1
          #24
          @gohan I need to implement the voltage measurement (simple voltage divider) as I have a pass though buck converter so 3.3v is shown. All I can say now is that after a few charges self discharge really improved.
            That is something you can do by leaving the supercap on a desk for 24 hours and a multimeter 😁
              alexsh1A Offline
              alexsh1A Offline
              alexsh1
              @gohan not an option. Sorry :grin:
              • alexsh1A Offline
                alexsh1A Offline
                alexsh1
                Did anyone try using 3V solar cell for 2.7V caps?
                Seems a perfect fit - no need to use two supercaps in series
                https://www.ebay.co.uk/itm/3V-x-500-ma-Mini-solar-panel-epoxy-encapsulated-virtually-indestructible-1-5W/171216986698?hash=item27dd53e24a:g:14YAAOxyRhBS1H0O
                • N NeverDie
                  alexsh1A Offline
                  alexsh1A Offline
                  alexsh1
                  @neverdie Did you make any estimates running your mote on supercap? I cannot understand how come on RFM69HW (lowpowerlab), this guy managed to extract 14,111 packets transmitted https://lowpowerlab.com/forum/projects/a-solar-supercap-powered-moteino/
                  This is on 15F supercap.
                  N 1 Reply Last reply
                  • alexsh1A alexsh1
                    N Offline
                    N Offline
                    @alexsh1 His numbers are 100% accurate.
                    • N NeverDie
                      alexsh1A Offline
                      alexsh1A Offline
                      alexsh1
                      #30
                      @neverdie I am not questioning his numbers. I am trying to understand why with a normal transceiver (non-H) I am getting so much less. I must admit also that with BQ25570, I have 2x10F in series, which makes it 5F in total only vs 15F.
                      I should wait until my 30F cap runs out of juice and see how many packets I extracted
                        If you are happy with your setup to power the node, why are you bothering that much to send that many more packets if you actually don't need them anyway?
                          alexsh1A Offline
                          alexsh1A Offline
                          alexsh1
                          @gohan This is not about being happy. Engineering mind can never be satisfied ;-)
                            alexsh1A Offline
                            alexsh1A Offline
                            alexsh1
                            #33
                            @gohan However, in the nutshell you are right. With a small solar battery (53mm x 30mm, 5V 0.15W), this is what I get:
                            and today is an extremely cloudy day (no sun at all). Harvesting works really well.
                            I implemented a voltage divider yesterday with 1.8M / 470k resistors. Now I can monitor voltage in Domoticz:
                            voltage at 22:00 yesterday - 4.797V
                            voltage at 12:00 today - 4.887V
                            gohanG 1 Reply Last reply
                            • N Offline
                              N Offline
                              #34
                              Try running with your fuses set to xFF xDA xC2, That way your BOD will be turned off, you'll be running from the internal 8mhz resonator, and you'll be waking from sleep in <4uSec.
                              • N NeverDie
                                alexsh1A Offline
                                alexsh1A Offline
                                alexsh1
                                #35
                                @neverdie I have already all that. I am using this node https://www.openhardware.io/view/76/Stamp-size-MySensor-node
                                Let's see when I have final results. I have this supercap AVX 30F with ESR = 0.02ohm (vs Vishay 15F ESR=1.8Ohm used with Moteino and BQ25570 at lowpowerlab)
                                EDIT: Another point is signing/encryption. This would affect supercap charge as the node would be transmitting more data to GW.
                                • alexsh1A alexsh1
                                  @alexsh1 I use a total of 20F 5.5V supercaps and they discharge much more during night most likely because the buck/boost converter is not very low power and supercaps are chinese quality, but as far as I can get 36/48h of runtime without solar charge I should be fine
                                    alexsh1A Offline
                                    alexsh1A Offline
                                    alexsh1
                                    #37
                                    @gohan As you may see from the graph above my self discharge + sleep/tx consumption during the night dropped voltage from 4.851V at 21:00 (I charged supercaps initially) to 4.549V at 08:00. This is the rate of about 0.3V per 12 hours, I estimate that I have around 10 days without any charging before I run out of energy.
                                    It took 4h 25mins on a cloudy day (see another graph) to get 2x10F in series supercaps fully charged to 5.047V
                                      You are using a very efficient circuit and good quality supercaps, I loose about 1V in 12 hours
                                        alexsh1A Offline
                                        alexsh1A Offline
                                        alexsh1
                                        @gohan Did you try to measure your sleeping current?
                                        • alexsh1A alexsh1
                                          N Offline
                                          N Offline
                                          If anything, you should have an advantage, since the nRF24L01 transmits at a faster bitrate, and using significantly less Tx power also.
