  3. Node running on supercaps and a solar panel.
59 Posts 5 Posters 11.2k Views 6 Watching
  • N Offline
    N Offline
    Are you using the passive mode option for mysensors? If not, that could be part of what's draining you.
    alexsh1A 1 Reply Last reply
    • N NeverDie
      alexsh1A Offline
      alexsh1A Offline
      alexsh1
      #42
      @neverdie said in Node running on supercaps and a solar panel.:
      I did notice there is an option:
      #define MY_PASSIVE_NODE
      What is the passive node option please?
      I am not using it and yet I do not have any problems with draining
      EDIT: I see now
          All transport-related checks and safety-mechanisms are disabled.
          Requires that MY_NODE_ID is set, MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC are optional.
          Singing, registration, and OTA FW update are disabled.
      • alexsh1A alexsh1
        EDIT: I see now
        alexsh1A Offline
        alexsh1A Offline
        alexsh1
        In my view disabling transport related checks is not an option.
        Singing, registration, and OTA FW do take a lot of power. Especially OTA. It is slow and takes a lot of up time.
        • N Offline
          N Offline
          It sounds like you're happy already. Good luck!
            If I remeber well, passive node is used when you have a very tiny node, with low memory that only send data one way, like RF433
              alexsh1A Offline
              alexsh1A Offline
              alexsh1
              @gohan OK, but I think the key here is to get consumption down to something meaningful - 5uA or something. The only down side when not using a passive node is that if GW is disconnected, node would not go to sleep, but will be trying to connect to GW. define MY_TRANSPORT_UPLINK_CHECK_DISABLED would disable the node sending more than MY_TRANSPORT_STATE_RETRIES times message
                even if it drains the battery when the GW is dead, it is no big deal as you just have to wait for some sunlight
                  alexsh1A Offline
                  alexsh1A Offline
                  alexsh1
                  @gohan True! I was more talking about super small nodes working on CR1632. I have a few of these.
                  • alexsh1A Offline
                    alexsh1A Offline
                    alexsh1
                    Another interesting set of graphs (voltage scale is wrong - please ignore):
                    This is with signing:
                    This is without signing:
                      It looks a little irregular to me, doesn't it?
                        alexsh1A Offline
                        alexsh1A Offline
                        alexsh1
                        @gohan Well, the point is that signing does take more tx time. Therefore, voltage does drop upto 0.2-0.3V.
                        I am not sure about irregularities though
                          Maybe it has to do with the harvesting chip. My graph looks like a sawtooth from day to day.
                          • N Offline
                            N Offline
                            For this type of comparison, I think you're better off charging up the supercap in a standardized way and then running with the solar panel disconnected. Otherwise, how recently and how long the supercap was charged to full capacity can affect the rate of discharge.
                              alexsh1A Offline
                              alexsh1A Offline
                              alexsh1
                              @gohan there is no harversting - this is just 30F cap connected to a node.
                              I have two setups:
                              1. BQ25570 + 2x10F supercaps in series and a small solar panel connected to a node. This is an excellent setup which can last for days without recharging
                              2. 30F cap connected directly (initially I tried it via mcp1640) to a different node. The above graphs are from this setup.
                                I am re-measuring it them right now as the code was wrong.
                              • alexsh1A alexsh1
                                A Offline
                                A Offline
                                Anticimex
                                @alexsh1 with signing you also get message bursts. Not only is the max size data transmitted for every signed message, two more messages are exchanged; a nonce request (small) and a nonce (big).
                                • A Anticimex
                                  alexsh1A Offline
                                  alexsh1A Offline
                                  alexsh1
                                  @anticimex said in Node running on supercaps and a solar panel.:
                                  That's clearly visible on the graph.
                                  • alexsh1A alexsh1
                                    I have got my hands on 30F 2.7V supercapacitor.
                                    With it was charged for the first time, it only lasted sending 2583 times (1 time a minute voltage and an 20ms LED pulse and then sleeping; sleeping consumption is 4-5uA). The number is a bit disappointing. It is however connected via boost MCP1640 to provide the node with a stable 3.3V. I may try to get the supercapacitor connected directly to the node to see if I can extract more packets.
                                    alexsh1A Offline
                                    alexsh1A Offline
                                    alexsh1
                                    #57
                                    @alexsh1 said in Node running on supercaps and a solar panel.:
                                    Supercap connected directly to the node stopped working at 2V.
                                    I got about 8949 packets (10ms LED and sent voltage every minute. No signing). It has been running about 6 days.
                                      basically you got 3 times packets sent without the booster?
                                        alexsh1A Offline
                                        alexsh1A Offline
                                        alexsh1
                                        @gohan That's correct and I am sure the result is not final
