  3. Whole house power monitoring.
hardware sensor power
44 Posts 11 Posters 14.5k Views 11 Watching
  • S
    shabba
    I see some commercial offering that count meter ticks but are there any clamp style current meters that people have used to measure power usage in a house?
    Thanks!
    T 1 Reply Last reply
      Of course there are, you could also make one out of an Arduino Uno one clamp an a small transformer, it depends if you want to go DIY or go with commercial product
      • S
        shabba
        DIY all the way! I assumed posting here would imply mysensors based but I guess I really should have been clear.
        Thanks!
        • D
          D
          dakipro
          Interested in the topic as well.
          Also, would it be possible get the power for arduino from the clamp itself, wirelessly? :D
          or you must have separate power source for arduino (I know this later is the case, but... you never know what smart people here can come up with)
          • rozpruwaczR
            rozpruwaczR
            rozpruwacz
            lately I discovered EnOcean. They produce energy harvesting sensors for home automation. E.g. a batteryless push button :) It harvests energy from button presses - how cool is that :D They also have other energy harvesting technologies, but I don't think they would provide enough power for arduino board that measures the current and voltage continuously ...
            gohanG 1 Reply Last reply
            • D
              D
              dakipro
              quick google search gave me this https://electronics.stackexchange.com/questions/189425/leach-circuit-to-power-microcontroller
              • rozpruwaczR rozpruwacz
                @rozpruwacz Why would want energy harvesting on an energy meter that is actually measuring the mains? You can just use a power supply and you are fine. Anyway, if you want to go DIY look at openenergymonitor site on how to build the sensor
                D 1 Reply Last reply
                • rozpruwaczR
                  rozpruwaczR
                  rozpruwacz
                  @gohan I don't know, I just pointed out that it may be possible ;)
                    I have looked at enocean stuff some time ago, and it works similarly to zwave but with energy harvesting in mind. Btw since I brought up zwave... https://aeotec.com/z-wave-home-energy-measure
                    • S
                      shabba
                      All I am looking for really is a sensor/circuit that I can hook up to a mini and mysensors network.
                        https://openenergymonitor.org/forum-archive/node/58.html then you add the mysensors code for communication.
                        S 1 Reply Last reply
                          shabba
                          @gohan Thank you!
                            D
                            D
                            dakipro
                            @gohan said in Whole house power monitoring.:
                            I live in building where meter is in a common locker, thus no plugs nor power supplies.
                            • D dakipro
                              @dakipro then you should probably have a breaker box in the apartment, so you could put it there instead
                              Nca78N 1 Reply Last reply
                                Nca78N
                                Nca78N
                                That's a good idea but it's a bit tight in there :(
                                • Nca78N Nca78
                                  @nca78 nobody said life is easy :sweat_smile:
                                  • TmasterT
                                    TmasterT
                                    Tmaster
                                    I'm using an arduino pro mini with an W500 Ethernet module connected directly to router,and a clamp from ebay(100amps i think). arduino and w500 fits inside a small box and its inside main power box,clamped to the main wire from main eletric deferential . I have the (ATI) Telecomonication box at side of power box so its easy to connect to the router. i dont use transformer for volt read,just read Amps because my power its very stable at 230/235v and this is just for " power waste "control
                                    on first moth that i build it i saved 30€/moth in power(i not a commercial advertisement :P ).i had the electric resistance from water solar heating panel (3000w) working during the night,useless because we don't need hot water in morning,only at end of the day. so now i have another arduino that handle the hot water if there is no enough sun during the day... ( arduino pro minifor the win!!!:+1: )
                                    This is a screenshot from my emoncms page. like you see my wife its doing cakes and dinner,and the oven and induction plate eat a lot of power ![0_1515953751100_1.jpg
                                    i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                                    • S
                                      superczar
                                      +1 to that
                                      I have been using a single clamp sensor on my neutral at the power meter (SCT-030) hooked to an arduino/ESP8266
                                      It's been working great close to 3 years now with an accuracy of +- 7%
                                      I even use the readings to detect brown-outs and trigger devices to original state after power flips back to mains from the back-up (I live in an area where brown-outs , or power-cuts as we call them , are quite common)
                                      • K
                                        K
                                        kimot
                                        wrote on last edited by kimot
                                        +/-7% is good, because Domoticz has it own error -8% when energy consumption calculation is done by Domoticz.
                                        When I send 660 W constantly a few hours, I obtain energy consumption 604 - 609 Wh in this interval :o(
                                        They do not add last 5 min energy consumption in one hour interval ( Argument - because data arrived not at xx:00:00 but XX:00:05 )
                                        Look at Domoticz forum about this bug, if interested.
                                        Boys from Domoticz said - it is not important ....
                                        gohanG Nca78N 2 Replies Last reply
                                        • K kimot
                                          @kimot yeah, 5 minutes intervals are not the best for that kind of statistics; you'd probably better look at influxDB for more accurate statistics
                                          zboblamontZ K 2 Replies Last reply
