  3. Whole house power monitoring.
hardware sensor power
44 Posts 11 Posters 14.5k Views 11 Watching
  • K kimot
    +/-7% is good, because Domoticz has it own error -8% when energy consumption calculation is done by Domoticz.
    When I send 660 W constantly a few hours, I obtain energy consumption 604 - 609 Wh in this interval :o(
    They do not add last 5 min energy consumption in one hour interval ( Argument - because data arrived not at xx:00:00 but XX:00:05 )
    Look at Domoticz forum about this bug, if interested.
    Boys from Domoticz said - it is not important ....
    Nca78N
    Nca78N
    @kimot thank you for that information. One more nail in Domoticz' coffin for me...
      @kimot yeah, 5 minutes intervals are not the best for that kind of statistics; you'd probably better look at influxDB for more accurate statistics
      zboblamontZ
      zboblamontZ
      zboblamont
      @gohan Agreed that the Domoticz 5 minute sample frequency is inadequate for any accurate measurement, there was talk on the forums that this was to change to accurate time based series for the next version of Domoticz, how true that was and when this might appear is unknown.
      I wasn't aware of that flaw @kimot, quite a curiosity...
      I was pointed to NodeRed previously as a mechanism to duplicate the data stream and accurately record time-based data from pulse meters while passing on the data to Domoticz, I just haven't waded into the thrills of NodeRed yet.
      Agreed that clamp meters are easier to install, when I was looking into them, many specifications show an average range of accuracy, but also read elsewhere that this accuracy is not linear, and becomes in reality quite inaccurate at low currents, I cannot recall the error %age.
      Nca78N 1 Reply Last reply
      • zboblamontZ zboblamont
        Nca78N
        Nca78N
        @zboblamont said in Whole house power monitoring.:
        But probably it's not a big issue if you have 30% or more (no idea of the real numbers) of inaccuracy at low current, as long as you're much closer at high current which make the bulk of your power consumption ?
        • Nca78N Nca78
          zboblamontZ
          zboblamontZ
          zboblamont
          @nca78 Possibly that would be one approach, but there are so many other effects on CTs as opposed to direct reading meters, proximity of adjacent cable, temperature, humidity, etc., all introducing errors on top of it's spec and how well it is QC'd at manufacture.
          Industrial 50A clamps can work down to 0.125A with 2.5% error, the typical 100A domestic variety would not get close I suggest.
          Don't misunderstand my comments, where it is impossible to install direct reading meters I see the necessity, just cautioning that they are by nature a compromise.
          gohanG 1 Reply Last reply
            wrote on last edited by gohan
            #25
            @zboblamont just for clarification, what do you mean by "direct reading "?
              zboblamontZ
              zboblamontZ
              zboblamont
              @gohan Sorry for any confusion, I meant in-line meters, where there is direct reading of voltage, current, pf, etc....
                @zboblamont have you found any worth mentioning?
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  @gohan I guess you meant in-line meters? Not specific device recommendations, but more a methodology, none of which is new.
                  The supply here is about 65A, so perhaps not euro-typical, in the UK it would be a standard 100A supply even though full load current would rarely top 50A unless you were simultaneously loading supply with some hefty coincidental peak demand, and electricity ain't cheap particularly in the UK.
                  If you were measuring each major circuit separately, a 45A meter could easily cover all sockets, another could cover all lighting, each with a kWh pulse output, all you need is space for 2 standard DIN units, or 3 if you had a high load such as an instant shower or cooker. These will comfortably measure kWh to a high degree of accuracy, pulsing out according to choice of model, probably 30 euro each.
                  Where expanding the consumer box or adding to it is not physically possible, that is where I view CTs as solution to achieve the objective, but it remains a compromise.
                    I am using a couple of sonoff pow to measure kitchen and washing machine as they are the most power hungry devices. I am also using a pulse counter on the electric company meter but I figured it is not really working well in reporting instant power readings, while the pulse counter is counting fine but power calculation by domoticz is too slow and I can't use it to switch off the big loads in case of overload ( over here we have 3000W maximum allowed and if you exceed that for few minutes the main switch will cut the power and I was planning to avoid those situations with the help of the sonoffs pow)
                    raptorjrR 1 Reply Last reply
                      raptorjrR
                      raptorjrR
                      raptorjr
                      @gohan Just curious, where do you live with those restrictions?
                      • raptorjrR raptorjr
                        @raptorjr Italy, that is the most common contract for homes, but there are other contracts with 4500w or more and you get charged with an higher fixed monthly fee for the extra power availability even if you actually use it once a month
                          K
                          K
                          kimot
                          @gohan
                          5 min interval is not big problem for me.
                          Problem is, that this last 5 min interval in each hour is completely lost.
                          They do not add it to next hour.
                          Next hour is calculated from hh:mm:00 again.
                          So first interval hh:00:00 to hh:mm:04.
                          InfluxDB is good, but I want all at one web ( domoticz ).
                          I try calculate power consumption myself through some Domoticz script.
                          • S shabba
                            I see some commercial offering that count meter ticks but are there any clamp style current meters that people have used to measure power usage in a house?
                            Thanks!
                            terryrow
                            @shabba I have used a clamp meter and arduino uno to monitor power levels, disadvantages are that you need to full wave rectify, provide load resistor and smoothing. Measurement becomes a bit of guesswork as to how many volts o/p in a Kwh.
                            Here in Britain, meters have a LED that flashes 1000 times per Kw. I have used a digital light sensor input into arduino uno digital input and then measured the time between flashes in msecs to give accurate readings. I use have used both methods to monitor solar panel output, then turn on Leaf BEV car when sufficient free power is available and off again when clouds arrive. Next step is to o/p readings to a Nextion for both solar and grid power readings with adjustment of turn on thresholds to optimise summer and winter useage.
                            gohanG zboblamontZ 2 Replies Last reply
                            • T terryrow
                              @terryrow do you mind sharing your pulse meter code?
                              T 1 Reply Last reply
                              • T terryrow
                                zboblamontZ
                                zboblamontZ
                                zboblamont
                                @terryrow Out of curiosity, was there no output pulse connection on the meter, or is it a sealed 'smart' meter from the supplier?
                                Wh pulses appear to be rare on supplier provided meter which piqued my curiosity, they are generally kWh pulses...
                                  #36
                                  Our utility company meters have a flashing led that flashes 1000 times for every Kwh, so 1 flash is a wh
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    wrote on last edited by zboblamont
                                    #37
                                    @gohan said in Whole house power monitoring.:
                                    Fair comment for Italy, but I do not recall similar for the UK, although I must confess I had little interest with respect to monitoring systems at the time.
                                    In Romania they have the habit of placing smart meters with pulse flashers in rather large acrylic bubbles (a la Klockner Moeller) out on the main road, which not only renders optical detection difficult, put potentially removeable by every passing drunk.... Hence placing a padlock on the isolator access to dissuade the same folks from switching off the entire house from the main road...
                                      terryrow
                                      @zboblamont I cannot see any sockets for a digital o/p. Neither is a smart meter, but both are only 2 years old. The grid meter has an additional green led when power is going out of the house.
                                        terryrow
                                        @gohan Sorry I have been so long, some things, apparently, are more important than playing on my laptop. I managed to lose the "saved" copy when looking at Nextion mods. I have recovered/repaired and tidied the code but I need your help as to how to share with you.
                                        • T terryrow
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @terryrow Sorry, perhaps I am misunderstanding your scenario in thinking it may be similar to my own.
                                          I cannot access the supplier's meter or optically couple safely as explained above, but I can shut down power to the house, which allowed fitting of a DIN mounted meter in the consumer box. This has both external flashing LED and 2 connections for pulse measurement via clamp screws.
                                          If the house meter is less than two years old, it will be digital, and these USUALLY have a connector for external pulse.
                                          If you can physically access the meter, google the make and meter type for info, perhaps you have a model with similar pulse connection available. Hence my query...
