  3. Programming needed to enable RFM69 radio with 5100 ethernet code.
7 Posts 3 Posters 1.9k Views 2 Watching
  • JohnRobJ
    JohnRobJ
    JohnRob
    wrote on last edited by JohnRob
    Can someone suggest a sketch code that would work with a sensebender_Gw. Using a RFW69 radio and a 5100 enternet.
    • korttomaK
      korttomaK
      korttoma
      The example sketch included in the MySensors library should work just fine if you enable the correct radio and define the frequenzy to be used and radio hardware type if it is HW like this:
      #define MY_RADIO_RFM69
      #define MY_IS_RFM69HW
      • Tomas
      • korttomaK korttoma
        zboblamontZ
        zboblamontZ
        zboblamont
        @korttoma The last line to be clear being dependent on whether using the high powered rfm69, otherwise it should be omitted or commented out...
        • JohnRobJ
          JohnRobJ
          JohnRob
          Thanks the information was helpful. But I'm still hung up on the pin designators. In this code:
          //#define MY_RADIO_NRF24
          #define MY_GATEWAY_W5100
          #define MY_W5100_SPI_EN 4
          // radio on the same spi bus.
          #define MY_SOFTSPI
          #ifndef MY_RF24_CE_PIN
          #define MY_RF24_CE_PIN 5
          #ifndef MY_RF24_CS_PIN
          #define MY_RF24_CS_PIN 6
          Here I'm struggling, because the Sensebender_GW does not wire the RF24 pins to pin 5 & 6 as shown in the above code (based one the Github schematic ) So as I try to understand how to code the RFM69 I'm lost as to what pins need to be defined in the sketch.
          In the old days I would simply pickup the CPU datasheet and be good to go, however the Arduino pin mapping has me completely baffled. Even after reading every variant.h on my computer!
          So I thought if someone could post the code for the same configuration I would using, I could go backwards and learn the pin mapping.
          korttomaK 1 Reply Last reply
          • JohnRobJ JohnRob
            #define MY_SOFTSPI
            korttomaK
            korttomaK
            korttoma
            @johnrob You should not need to edit or define any pin asigning from the example sketch.
            You might want to edit the IP address:
            #define MY_IP_ADDRESS 192,168,178,66   // If this is disabled, DHCP is used to retrieve address
            MAC address:
            And define the frequenzy of your RFM69 (this is an example using the 433MHZ version):
            • Tomas
            JohnRobJ 1 Reply Last reply
              MAC address:
              JohnRobJ
              JohnRobJ
              JohnRob
              @korttoma
              Thanks I just make the changes you suggested.
              However I'm still uncomfortable not knowing how the pins get sorted out by the software.
              JohnRob
              • korttomaK
                korttomaK
                korttoma
                As far as I know all the radio pins have some kind of "default" pin assignment and only in special cases you need to reassign them. Also depending on the processor type or board type you choose in the tool the default pin assignment may differ. I think it in case of RFM69 is handled in the RFM69_old.h (someone with better knowledge please correct me if I am wrong).
                • Tomas
