  3. Redefinition warning when Compiling for RFM69W-915 Radio
4 Posts 2 Posters 1.1k Views 2 Watching
  • JohnRobJ
    JohnRobJ
    JohnRob
    wrote on last edited by JohnRob
    I'm working on my first MySensors Node. My code is a simple read an analog input function. Now because my radio is a 915MHz version I must add a line to state such. When I do the compiler gives me a warning "warning: "MY_RFM69_FREQUENCY" redefined"
    Now I know I am redefining the default radio frequency so the warning is understood, however I am wondering if I am coding is a clumsy manor to get this warning.
    My Code:
    // Sensor node code
    // 2018-01-26  V_01b
    // Target: Aarduino MiniWirelessW-915
    //MySensors API V2.2.0
    // from:  https://www.mysensors.org/download/sensor_api_20
    // *** Initialization *** //
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RF69_915MHZ
    #define CHILD_ID 5
    #define sensortype S_MULTIMETER
    #define analoginputPIN A0
    #define LEDPIN 9 //PB1 is pin 9 on ProMini
    uint16_t analogPinRdg;
    MyMessage msg_Voltage(CHILD_ID, V_VOLTAGE);
    pinMode(LEDPIN, OUTPUT);
    digitalWrite(LEDPIN, HIGH);   // turn the LED on (doesn't work, may not get here)
      present(CHILD_ID, S_MULTIMETER);
    //  digitalWrite(LEDPIN, HIGH);   // turn the LED on (HIGH is the voltage level)
    //  delay(1000);                       // wait for a second
    //  digitalWrite(LEDPIN, LOW);    // turn the LED off by making the voltage LOW
      asm ("sbi %0, %1 \n": : "I" (_SFR_IO_ADDR(PINB)), "I" (PINB1)); // Toggle LED
      analogPinRdg = analogRead(analoginputPIN);
      send(msg_Voltage.set(analogPinRdg));
      wait(5000);    //unsigned long
    • JohnRobJ JohnRob
      My Code:
      // Sensor node code
      // 2018-01-26  V_01b
      #define CHILD_ID 5
      @johnrob all defines for MySensors need to be done before including MySensors.h. Otherwise, they won't have any effect.
      So move define MY_RFM69_FREQUENCY RF69_915MHZ a few lines up.
      • JohnRobJ
        JohnRobJ
        JohnRob
        @mfalkvidd said in Redefinition warning when Compiling for RFM69W-915 Radio:
        MySensors.h
        Thank you.
        I was under the impression that the RFM69 default frequency was 868Mhz and if I placed the "#define MY_RFM69_FREQUENCY RF69_915MHZ" before the MySensors.h the frequency would be reset to 868.
        I'm guessing by your answer that this is not the case. Perhaps an if not defined.
        • JohnRobJ JohnRob
          MySensors.h
          Thank you.
          @johnrob exactly. All MySensors defines are designed that way.
