  3. Home Assistant
  4. Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it
36 Posts 5 Posters 6.4k Views 5 Watching
    I moved it to the home assistant section. Let's hope somebody could help you out, I'm not HA expert
    Sergio RiusS Offline
    Sergio Rius
    @gohan said in Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it:
    Don't know if that is caused by the controller, by I'm having the same issue months ago but with domoticz.
    When that happens, I've found that manually restarting the mys GW service makes it work again.
    • Huỳnh Minh KhảiH Offline
      Huỳnh Minh Khải
      The same issue here and solved by changing my NRF24L01
      • ? Offline
        ? Offline
        A Former User
        I have the same problem
        pi 3 as gateway ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=ethernet --my-port=5003
        logs gateway:
        Mar 13 17:00:40 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:00:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:00:42 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:00:44 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:00:46 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:00:48 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=2,c=1,t=1,pt=7,l=5,sg=0:58.3
        Mar 13 17:00:48 MySensorsGW mysgw: TSF:MSG:READ,5-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:00:49 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:00:52 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:00:59 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:01:02 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:01:09 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:01:12 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:01:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:01:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:01:29 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:01:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:01:39 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:01:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:01:49 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:01:52 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:01:59 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:02:02 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:02:09 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:02:12 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:02:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:02:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:02:29 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:02:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:02:39 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:02:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:02:49 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:02:52 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:02:59 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:03:02 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:03:09 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:03:12 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:03:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:03:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:03:29 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:03:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        communication stoped at Mar 13 17:00:49
        When I try to switch a relay:
        gateway:
        Mar 13 17:06:15 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
        Mar 13 17:06:15 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
        Mar 13 17:06:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:06:20 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
        Mar 13 17:06:20 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
        Mar 13 17:06:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:06:25 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;4;1;0;2;1
        Mar 13 17:06:25 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=4,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
        Mar 13 17:06:28 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
        Mar 13 17:06:28 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
        Mar 13 17:06:30 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:06:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:06:34 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
        Mar 13 17:06:34 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
        Mar 13 17:06:36 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;4;1;0;2;1
        Mar 13 17:06:36 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=4,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
        Mar 13 17:06:39 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:06:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        node:
        9839799 TSF:TDI:TSL
        9899802 TSM:FAIL:RE-INIT
        9899804 TSM:INIT
        9899811 TSM:INIT:TSP OK
        9899813 TSM:INIT:STATID=11
        9899816 TSF:SID:OK,ID=11
        9899819 TSM:FPAR
        9899855 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        9901864 !TSM:FPAR:NO REPLY
        9901867 TSM:FPAR
        9901903 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        9903912 !TSM:FPAR:NO REPLY
        9903915 TSM:FPAR
        9903951 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        9905960 !TSM:FPAR:NO REPLY
        9905963 TSM:FPAR
        9905999 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        9908008 !TSM:FPAR:FAIL
        9908011 TSM:FAIL:CNT=7
        9908013 TSM:FAIL:DIS
        9908015 TSF:TDI:TSL
        pi@MySensorsGW:~ $ systemctl is-active mysgw.service
        active
        When I restart the gateway service everything is back OK
        pi@MySensorsGW:~ $ sudo systemctl restart mysgw.service
        pi@MySensorsGW:~ $ tail -f /var/log/syslog
        Mar 13 17:21:55 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=6
        Mar 13 17:21:55 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
        Mar 13 17:21:55 MySensorsGW mysgw: TSF:MSG:GWL OK
        Mar 13 17:21:56 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:BC
        Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=6
        Mar 13 17:21:57 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
        Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:GWL OK
        Mar 13 17:21:58 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        Mar 13 17:22:01 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        Mar 13 17:22:01 MySensorsGW mysgw: TSF:MSG:PINGED,ID=6,HP=1
        Mar 13 17:22:01 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        Mar 13 17:22:03 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        Mar 13 17:22:03 MySensorsGW mysgw: TSF:MSG:PINGED,ID=6,HP=1
        Mar 13 17:22:03 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        Mar 13 17:22:05 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:07 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:09 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:BC
        Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=7
        Mar 13 17:22:11 MySensorsGW mysgw: TSF:PNG:SEND,TO=0
        Mar 13 17:22:11 MySensorsGW mysgw: TSF:CKU:OK
        Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:GWL OK
        Mar 13 17:22:12 MySensorsGW mysgw: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        Mar 13 17:22:12 MySensorsGW mysgw: New connection from 192.168.0.51
        Mar 13 17:22:12 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
        Mar 13 17:22:12 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:13 MySensorsGW mysgw: GWT:TSA:C=0,DISCONNECTED
        Mar 13 17:22:13 MySensorsGW mysgw: Ethernet client disconnected.
        Mar 13 17:22:13 MySensorsGW mysgw: New connection from 192.168.0.51
        Mar 13 17:22:13 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
        Mar 13 17:22:14 MySensorsGW mysgw: New connection from 192.168.0.35
        Mar 13 17:22:14 MySensorsGW mysgw: GWT:TSA:C=1,CONNECTED
        Mar 13 17:22:14 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:22:14 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:16 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:BC
        Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=7
        Mar 13 17:22:17 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
        Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:GWL OK
        Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        Mar 13 17:22:19 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:READ,11-11-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:BC
        Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=11
        Mar 13 17:22:20 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
        Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:GWL OK
        Mar 13 17:22:21 MySensorsGW mysgw: TSF:MSG:SEND,0-0-11-11,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        Mar 13 17:22:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:READ,11-11-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:PINGED,ID=11,HP=1
        Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:SEND,0-0-11-11,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        Mar 13 17:22:24 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:22:24 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:26 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:28 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:30 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
        Mar 13 17:22:32 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:34 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
        Mar 13 17:22:34 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:36 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:38 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:40 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
        Mar 13 17:22:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
          what version are you using?
          ? 1 Reply Last reply
            ? Offline
            ? Offline
            A Former User
            @gohan
            My last node (8-relay) 2.2.0
            my gateway RPi3 git clone https://github.com/mysensors/MySensors.git --branch master
            I think I have some other nodes on 2.0.0
            • ? Offline
              ? Offline
              A Former User
              sometimes I see this in my gateway log
              Mar 13 17:42:32 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                @gieljnssns said in Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it:
                that looks like the message got lost between the gw and node. You could try moving the node closer or using a repeater halfway. Pls write the gw version since the git-clone is not telling me much
                  ? Offline
                  ? Offline
                  A Former User
                  @gohan
                  how can I see wich version I'm using?
                    when GW starts it prints the version in log
                      ? Offline
                      ? Offline
                      A Former User
                      @gohan
                      version 2.2.0
                      Mar 13 18:36:04 MySensorsGW systemd[1]: Stopping MySensors Gateway daemon...
                      Mar 13 18:36:04 MySensorsGW systemd[1]: Stopped MySensors Gateway daemon.
                      Mar 13 18:36:04 MySensorsGW systemd[1]: Started MySensors Gateway daemon.
                      Mar 13 18:36:04 MySensorsGW mysgw: Starting gateway...
                      Mar 13 18:36:04 MySensorsGW mysgw: Protocol version - 2.2.0
                      Mar 13 18:36:04 MySensorsGW mysgw: MCO:BGN:INIT GW,CP=RNNGL-Q-,VER=2.2.0
                      Mar 13 18:36:04 MySensorsGW mysgw: TSF:LRT:OK
                      Mar 13 18:36:04 MySensorsGW mysgw: TSM:INIT
                      Mar 13 18:36:04 MySensorsGW mysgw: TSF:WUR:MS=0
                      Mar 13 18:36:04 MySensorsGW mysgw: TSM:INIT:TSP OK
                      Mar 13 18:36:04 MySensorsGW mysgw: TSM:INIT:GW MODE
                      Mar 13 18:36:04 MySensorsGW mysgw: TSM:READY:ID=0,PAR=0,DIS=0
                      Mar 13 18:36:04 MySensorsGW mysgw: MCO:REG:NOT NEEDED
                      Mar 13 18:36:04 MySensorsGW mysgw: Listening for connections on 0.0.0.0:5003
                      Mar 13 18:36:04 MySensorsGW mysgw: MCO:BGN:STP
                      Mar 13 18:36:04 MySensorsGW mysgw: MCO:BGN:INIT OK,TSP=1
                      Mar 13 18:36:04 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:06 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:08 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:10 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:12 MySensorsGW mysgw: TSF:MSG:READ,5-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:12 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:12 MySensorsGW mysgw: TSF:MSG:READ,3-3-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:14 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:16 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:18 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:19 MySensorsGW mysgw: TSF:MSG:READ,2-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:19 MySensorsGW mysgw: New connection from 192.168.0.51
                      Mar 13 18:36:19 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
                      Mar 13 18:36:20 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:21 MySensorsGW mysgw: TSF:MSG:READ,1-1-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:21 MySensorsGW mysgw: TSF:MSG:READ,2-11-0,s=1,c=1,t=0,pt=7,l=5,sg=0:17.0
                      Mar 13 18:36:21 MySensorsGW mysgw: TSF:MSG:READ,2-11-0,s=2,c=1,t=1,pt=7,l=5,sg=0:38.0
                      Mar 13 18:36:22 MySensorsGW mysgw: GWT:TSA:C=0,DISCONNECTED
                      Mar 13 18:36:22 MySensorsGW mysgw: Ethernet client disconnected.
                      Mar 13 18:36:22 MySensorsGW mysgw: New connection from 192.168.0.51
                      Mar 13 18:36:22 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
                      Mar 13 18:36:22 MySensorsGW mysgw: New connection from 192.168.0.35
                      Mar 13 18:36:22 MySensorsGW mysgw: GWT:TSA:C=1,CONNECTED
                      Mar 13 18:36:22 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                      Mar 13 18:36:22 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:24 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:26 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=2,c=1,t=1,pt=7,l=5,sg=0:60.1
                      Mar 13 18:36:26 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:28 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:29 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                      Mar 13 18:36:30 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                      Mar 13 18:36:32 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                      • ? Offline
                        ? Offline
                        A Former User
                        There is only 4 meter in between my gateway and node.
                        @huỳnh-minh-khải said in Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it:
                        I've already changed my radio
                          Do you have a decent capacitor on the radio module? Have you tried a different maker of nrf24 module?
                            ? Offline
                            ? Offline
                            A Former User
                            @gohan
                            I have these radios https://www.ebay.com/itm/400594940658?rmvSB=true
                            I've used this adapter plate for my radio https://www.ebay.com/itm/200960749614?rmvSB=true
                            And there is a capacitor on my radio
                              I don't like those nrf24 modules as they are 99% fake clones. Once I got some real ones I solved a lot of range issues
                                ? Offline
                                ? Offline
                                A Former User
                                @gohan
                                Can you give me a link to the real ones?
                                  I bought them on aliexpress from the cdebyte shop. There are a few open topics about real and fake nrf24 if you want to read some more. As a general rule of thumb consider that the genuine nrf24 chip is normally sold around 1.2$ so you can't buy a fully assembled genuine module for less than a dollar.
                                  12.2k
