  3. Home Assistant
  4. Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it
36 Posts 5 Posters 6.9k Views 5 Watching
    @gieljnssns said in Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it:
    mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    that looks like the message got lost between the gw and node. You could try moving the node closer or using a repeater halfway. Pls write the gw version since the git-clone is not telling me much
    ? 1 Reply Last reply
      A Former User
      @gohan
      how can I see wich version I'm using?
        when GW starts it prints the version in log
          A Former User
          @gohan
          version 2.2.0
          Mar 13 18:36:04 MySensorsGW systemd[1]: Stopping MySensors Gateway daemon...
          Mar 13 18:36:04 MySensorsGW systemd[1]: Stopped MySensors Gateway daemon.
          Mar 13 18:36:04 MySensorsGW systemd[1]: Started MySensors Gateway daemon.
          Mar 13 18:36:04 MySensorsGW mysgw: Starting gateway...
          Mar 13 18:36:04 MySensorsGW mysgw: Protocol version - 2.2.0
          Mar 13 18:36:04 MySensorsGW mysgw: MCO:BGN:INIT GW,CP=RNNGL-Q-,VER=2.2.0
          Mar 13 18:36:04 MySensorsGW mysgw: TSF:LRT:OK
          Mar 13 18:36:04 MySensorsGW mysgw: TSM:INIT
          Mar 13 18:36:04 MySensorsGW mysgw: TSF:WUR:MS=0
          Mar 13 18:36:04 MySensorsGW mysgw: TSM:INIT:TSP OK
          Mar 13 18:36:04 MySensorsGW mysgw: TSM:INIT:GW MODE
          Mar 13 18:36:04 MySensorsGW mysgw: TSM:READY:ID=0,PAR=0,DIS=0
          Mar 13 18:36:04 MySensorsGW mysgw: MCO:REG:NOT NEEDED
          Mar 13 18:36:04 MySensorsGW mysgw: Listening for connections on 0.0.0.0:5003
          Mar 13 18:36:04 MySensorsGW mysgw: MCO:BGN:STP
          Mar 13 18:36:04 MySensorsGW mysgw: MCO:BGN:INIT OK,TSP=1
          Mar 13 18:36:04 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:06 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:08 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:10 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:12 MySensorsGW mysgw: TSF:MSG:READ,5-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:12 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:12 MySensorsGW mysgw: TSF:MSG:READ,3-3-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:14 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:16 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:18 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:19 MySensorsGW mysgw: TSF:MSG:READ,2-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:19 MySensorsGW mysgw: New connection from 192.168.0.51
          Mar 13 18:36:19 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
          Mar 13 18:36:20 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:21 MySensorsGW mysgw: TSF:MSG:READ,1-1-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:21 MySensorsGW mysgw: TSF:MSG:READ,2-11-0,s=1,c=1,t=0,pt=7,l=5,sg=0:17.0
          Mar 13 18:36:21 MySensorsGW mysgw: TSF:MSG:READ,2-11-0,s=2,c=1,t=1,pt=7,l=5,sg=0:38.0
          Mar 13 18:36:22 MySensorsGW mysgw: GWT:TSA:C=0,DISCONNECTED
          Mar 13 18:36:22 MySensorsGW mysgw: Ethernet client disconnected.
          Mar 13 18:36:22 MySensorsGW mysgw: New connection from 192.168.0.51
          Mar 13 18:36:22 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
          Mar 13 18:36:22 MySensorsGW mysgw: New connection from 192.168.0.35
          Mar 13 18:36:22 MySensorsGW mysgw: GWT:TSA:C=1,CONNECTED
          Mar 13 18:36:22 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
          Mar 13 18:36:22 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:24 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:26 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=2,c=1,t=1,pt=7,l=5,sg=0:60.1
          Mar 13 18:36:26 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:28 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:29 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
          Mar 13 18:36:30 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
          Mar 13 18:36:32 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
            A Former User
            There is only 4 meter in between my gateway and node.
            @huỳnh-minh-khải said in Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it:
            The same issue here and solved by changing my NRF24L01
            I've already changed my radio
              Do you have a decent capacitor on the radio module? Have you tried a different maker of nrf24 module?
                A Former User
                @gohan
                I have these radios https://www.ebay.com/itm/400594940658?rmvSB=true
                I've used this adapter plate for my radio https://www.ebay.com/itm/200960749614?rmvSB=true
                And there is a capacitor on my radio
                  I don't like those nrf24 modules as they are 99% fake clones. Once I got some real ones I solved a lot of range issues
                    A Former User
                    @gohan
                    Can you give me a link to the real ones?
                      I bought them on aliexpress from the cdebyte shop. There are a few open topics about real and fake nrf24 if you want to read some more. As a general rule of thumb consider that the genuine nrf24 chip is normally sold around 1.2$ so you can't buy a fully assembled genuine module for less than a dollar.
