  3. Home Assistant
  4. MySensors ethernet 2.2.0 problem with control node switches
12 Posts 3 Posters 3.7k Views 3 Watching
  • pepsonP
    pepsonP
    pepson
    wrote on last edited by pepson
    Hi
    I am beginner… Yesterday i installed Haspbian on my RPI3 and start configuration…Home Assistant version 0.63.3
    I also connect radio RFM69HW to GPIO on raspberry and start compile and build MySensors Gateway based on ETHERNET. Finally i finished it and connect MySensors Gateway to Home Assistant by ethernet.
    Configuration mysensors gatway looks like:
    mysensors:
    gateways:
    • device: '127.0.0.1’
      persistence_file: '/home/homeassistant/.homeassistant/mysensors.json’
      tcp_port: 5003
      optimistic: false
      persistence: true
    Then i connected node Mysenors based on Arduino MIni Pro with connected relay.
    Sketch uploaded to node looks like:
    Relay with button sketch
    modified to work with no uplink
    to gateway and try to maintain sync to controller
    #define MY_DEBUG // Enable debug prints to serial monitor
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define RFM69_868MH
    #define MY_RFM69_NEW_DRIVER
    //#define MY_NODE_ID 203 // Node id defaults to AUTO (tries to fetch id from controller)
    #define MY_TRANSPORT_WAIT_READY_MS 5000 //set how long to wait for transport ready in milliseconds
    #define MY_REPEATER_FEATURE // Enabled repeater feature for this node
    #include <Bounce2.h>
    #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN 3 // Arduino Digital I/O pin number for button
    #define CHILD_ID 1 // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool uplinkAvailable = true;
    bool state = false;
    bool requestState;
    bool firstStart = true;
    unsigned long uplinkCheckTime ; // holder for uplink checks
    unsigned long uplinkCheckPeriod = 30*1000; // time between checks for uplink in milliseconds
    unsigned long returnWait = 1000; // how long to wait for return from controller in milliseconds… adjust as needed
    unsigned long oldTime = 0;
    unsigned long newTime = 0;
    MyMessage msg(CHILD_ID, V_STATUS);
    void setup(){
    pinMode(BUTTON_PIN, INPUT_PULLUP); // Setup the button pin, Activate internal pull-up
    debouncer.attach(BUTTON_PIN); // After setting up the button, setup debouncer
    debouncer.interval(5);
    pinMode(RELAY_PIN, OUTPUT); // set relay pin in output mode
    digitalWrite(RELAY_PIN, RELAY_OFF); // Make sure relay is off when starting up
    void presentation() {
    sendSketchInfo(“1xRelay & Button”, “2.2.0”);
    present(CHILD_ID, S_BINARY);
    void loop(){
    if (firstStart) { // this code is only run once at startup
    Serial.println(“First run started”);
    requestTime(); // get time from controller
    wait (returnWait); // delay to allow time to return
    if (oldTime == 0){ // check to see if there was a return from the time request
    Serial.println(“uplink not available”);
    uplinkAvailable = false; // no uplink established
    uplinkCheckTime = millis();
    else{
    Serial.println(“uplink available”);
    request( CHILD_ID, V_STATUS); // get status of switch on controller
    wait (returnWait); //wait needed to allow request to return from controller
    Serial.print("controller state — ");
    Serial.println(requestState);
    if (requestState != state) { // check that controller is corectly showing the current relay state
    send(msg.set(state), false); // notify controller of current state
    firstStart = false; // set firstStart flag false to prevent code from running again
    debouncer.update();
    int value = debouncer.read(); // Get the update value
    if (value != oldValue && value == 0) { // check for new button push
    state = !state; // Toggle the state
    digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF); // switch the relay to the new state
    requestTime();
    if (oldTime != newTime){ // if times are different then uplink is available
    oldTime = newTime;
    else{ // if times are the same no uplink is available
    uplinkAvailable = false; // no uplink available, set flag false
    uplinkCheckTime = millis(); // start the timer from now
    oldValue = value;
    if (!uplinkAvailable && (millis() - uplinkCheckTime > uplinkCheckPeriod) ) { // test to see if function should be called
    uplinkCheck(); // call uplink checking function
    /-------------------start of functions--------------------------/
    if (message.type == V_STATUS) { // check to see if incoming message is for a switch
    switch (message.getCommand()) { // message.getCommand will give us the command type of the incomming message
    case C_SET: //message is a set command from controller to update relay state
    state = message.getBool(); // get the new state
    digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF); // switch relay to new state
    uplinkAvailable = true; // uplink established
    /---- Write some debug info----/
    Serial.print(“Incoming change for sensor:”);
    Serial.print(message.sensor);
    break;
    case C_REQ: // message is a returning request from controller
    requestState = message.getBool(); // update requestState with returning state
    break;
    void uplinkCheck() {
    requestTime();
    wait (returnWait); // wait for time return… this may need to be varied for your system
    Serial.println(“uplink re-established”);
    send(msg.set(state), false); // notify controller of current state no ack
    oldTime = newTime;
    uplinkCheckTime = millis(); // reset the checktime
    Serial.println(“uplinkchecktime reset”);
    void receiveTime(unsigned long time)
    if (firstStart){
    oldTime = time;
    newTime = time;
    else{
    newTime = time;
    Serial.print("time received---- " );
    Serial.println(time);
    All based on library 2.2.0 MySensors.
    After that i found in Home Assistant node and add friendly name and add to my one of group. But after boot Home Assistant i can by frontend only one change status relay… Example set ON, but when i try OFF it not working and button for one secund go to OFF and again go to ON.
    When change by pin wire on Arduino Mini Pro status always change ok. But only not work by frontend. Only one i can change.
    On my old Domoticz all works ok.
    Next problem is also with test controller. When i change relay to ON , then ex reboot gateway MySensor and when gateway is rebooting i change by wire pin status relay , it is not refresh on frontend HA. Still show status ON before reboot gateway. But on domoticz works ok and status after reboot gateway was refreshed and show correct status OFF.
    Please help me…
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Please edit your post and put the sketch within code blocks so it's readable.
      • pepsonP
        pepsonP
        pepson
        ok corrected
        • martinhjelmareM
          martinhjelmareM
          martinhjelmare
          You need to feedback and send the changed state to home assistant, after writing the new state to the pin, in the receive function. Otherwise home assistant thinks that the message to change state did not reach the node, and returns to the old state.
          pepsonP 1 Reply Last reply
            pepsonP
            pepsonP
            pepson
            @martinhjelmare
            Can you explaine me more. Sorry i am begginer user and i dont know how ? Please
            Or please correct it in my sketch...please
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              Add the following line in the receive function eg after the call to digitalWrite.
              send(msg.set(state));
              • pepsonP
                pepsonP
                pepson
                Hi
                Ok i add this and now sketch look like:
                #define RFM69_868MH
                #define RELAY_ON 1
                #define RELAY_OFF 0
                int oldValue = 0;
                bool state = false;
                bool requestState;
                unsigned long returnWait = 1000;               // how long to wait for return from controller in milliseconds.. adjust as needed
                void setup(){
                  sendSketchInfo("1xRelay & Button", "2.2.0");
                void loop(){
                    Serial.println("First run started");
                      Serial.println("uplink not available");
                     else{
                      Serial.println("uplink available");
                      Serial.print("controller state --- ");
                  debouncer.update();
                    requestTime();
                      oldTime = newTime;
                  oldValue = value;
                /*-------------------start of functions--------------------------*/
                        /*---- Write some debug info----*/
                        break;
                        break;
                    requestTime();
                    wait (returnWait);                       // wait for time return.. this may need to be varied for your system
                     Serial.println("uplink re-established");
                      oldTime = newTime;
                  Serial.println("uplinkchecktime reset");
                  if (firstStart){
                    oldTime = time;
                    newTime = time;
                  else{
                  newTime = time;
                Now works ok but another problem. Ex When i enable relay and then reboot my RPI with Home Assistant and under reboot i manual change state relay by put pin to GND, then after run RPI with Home Assistant , it come back to previus state relay. Again set my relay as ENABLE.
                Is any chance to change it to after start HA he check state relay and setup in home assistant actual phisicaly state relay... not remembered before reboot ?
                And next problem... When node has relay ENABLE and power lost, then power come back relay again to ENABLE. But i want to RELAY always after power lost and power come back to relay go to DISABLE.
                  Set the relay state in setup function?
                    pepsonP
                    pepsonP
                    pepson
                    @gohan
                    Can you explaine me more because I am beginner and I don't know how?
                    It is in "void setup" ?
                    And what is command for setup state?
                      add
                      send(msg.set(RELAY_OFF), false);           // notify controller to show off state
                      at end of setup function and see if you get the result you want
                        add
                        pepsonP
                        pepsonP
                        pepson
                        @gohan
                        But it is for only show state off or also physical change state relay to off?
                        void setup(){
                        This is OK code?
                        • pepsonP
                          pepsonP
                          pepson
                          @gohan said in MySensors ethernet 2.2.0 problem with control node switches:
                          ok looks that is ok but please give me a time i test it more.
