  3. MyController.org
  4. [Solved] FOTA Not Working
Scheduled Pinned Locked Moved MyController.org
21 Posts 4 Posters 5.5k Views 4 Watching
  • SoloamS
    SoloamS
    Soloam
    wrote on last edited by tekka
    Hello, I'm using mysbootloader from @tekka and I'm trying to make FOTA to work on MyController from @jkandasa. I have MySensors 2.2.0 and a ATMEGA Flashed with the latest mysbootloader. Gateway is MQTT.
    I load the firmware into MyController and add it to a node, I hit start upload And I can see the first package on the MQTT topic:
    mygateway1-in/99/255/4/0/1
    010001000003114C
    At the same time I see my node debug
    112152 TSF:MSG:READ,0-0-99,s=255,c=4,t=1,pt=6,l=12,sg=0:010001000003114CE8B01000
    Then nothing, no more messages.
    My settings:
    • MySensors 2.2.0
    • MQTT GW
    • MyController
    • MySbootloader (lattest)
    • ATMEGA 328 8Mhz
    • nRF24 Radios
    I compiled the hex file in the Arduino IDE and Exported it with Sketch > Export Compiled Binary, I ended up with 2 hex, LightActuator.ino.standard.hex and LightActuator.ino.with_bootloader.standard.hex. I used LightActuator.ino.standard.hex
    Just one extra question, I can't use the FTDI programmer to program my boards (but I'm able to see the serial monitor output), I was able to on the previews bootloader, but with the MySbootloader I can't. Is this normal?
    Thank You
    • tbowmoT
      tbowmoT
      tbowmo
      This post is deleted!
      • tekkaT
        tekkaT
        tekka
        FOTA with MYSBootloader requires a reboot before the update kicks in - maybe @jkandasa can help you with MyController and the actions needed.
        The latest MYSBootloader version handles both, serial and FOTA updates - make sure you have the correct fuse & baud settings.
        SoloamS 1 Reply Last reply
        • tekkaT tekka
          SoloamS
          SoloamS
          Soloam
          wrote on last edited by Soloam
          Thank you @tekka , so the FTDI should work! Correct?
          The reboot seems to be the problem! I lose communication with the node when I try to reboot, and I need to reset to make it work again!
          Do I need to change the baud on the MySensors? What should I use on the 8Mhz ?
          Thank you and great work
          • SoloamS
            SoloamS
            Soloam
            This is my read of the burn on the 8Mhz Burn with the Arduino IDE
            • SoloamS
              SoloamS
              Soloam
              @tekka , I think I'm getting to the root (or not) of what might be the problem... I stated that I was not able to upload sketches by FTDI, but now I can see that on some ATMEGA I can, and others I can't... I flashed the bootloader to all in series, all in the same way (some where fresh installs, other not, but I can't track witch ones are what). Some ATMEGA I can upload the sketch by FTDI (when I get home I will try the FOTA, and I hope that on the ones that I can upload by FTDI that the FOTA will work), but on others I can't and I get:
              avrdude: stk500_recv(): programmer is not responding
              avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
              avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
              This seems the error that I get when I try to upload a sketch in the wrong frequency, but I double checked and all the ATMEGAS have the same fuses (the ones in the image above) and all where flashed in the same way.
              Thank You
              • SoloamS
                SoloamS
                Soloam
                I tried to flash the several Bootloader into one of the ATMEGA that was not working, the results are strange:
                FTDI Access:
                • Arduino UNO Bootloader: OK
                • ATMEGA on a Breadboard (8Mhz Internal Clock) OK
                • MysBootloader 16Mhz OK
                • MysBootloader 8Mhz NOK
                • MysBootloader 1Mhz OK
                I would assume that the problem was something on the config, but that would not explain way it works on some ATMEGA, and on others not... Can it be defective units (ATMEGA)? Only not working the 8Mhz??
                My boards.txt from github Dev brantch... I only had to change 3 lines to make it work... in Linux at lest we need this on the sketch folder (MYSBL.upload.tool=arduino:avrdude, MYSBL.bootloader.tool=arduino:avrdude, MYSBL.build.core=arduino:arduino, MYSBL.build.variant=arduino:standard)
                ## Add these lines to your boards.txt file in the Arduino installation directory
                ## Arduino Pro or Pro Mini (3V3 & 5V, 1 - 16 MHz) w/ ATmega328 MYSBootloader
                menu.frequency=Frequency
                MYSBL.name=ATmega328 with MYSBootloader 1.3.0
                MYSBL.upload.protocol=arduino
                MYSBL.upload.maximum_size=30720
                MYSBL.upload.maximum_data_size=2048
                MYSBL.build.mcu=atmega328p
                MYSBL.build.board=AVR_UNO
                MYSBL.menu.frequency.MYSBL16=16MHz XTAL
                MYSBL.menu.frequency.MYSBL16.build.f_cpu=16000000L
                MYSBL.menu.frequency.MYSBL16.upload.speed=115200
                MYSBL.menu.frequency.MYSBL16.bootloader.low_fuses=0xFF
                MYSBL.menu.frequency.MYSBL16.bootloader.high_fuses=0xD2
                MYSBL.menu.frequency.MYSBL16.bootloader.extended_fuses=0x06
                MYSBL.menu.frequency.MYSBL16.bootloader.unlock_bits=0x3F
                MYSBL.menu.frequency.MYSBL16.bootloader.lock_bits=0x0F
                MYSBL.menu.frequency.MYSBL16.bootloader.file=MySensors/MYSBootloader_16MHz.hex
                MYSBL.menu.frequency.MYSBL8=8MHz RC
                MYSBL.menu.frequency.MYSBL8.build.f_cpu=8000000L
                MYSBL.menu.frequency.MYSBL8.upload.speed=115200
                MYSBL.menu.frequency.MYSBL8.bootloader.low_fuses=0xE2
                MYSBL.menu.frequency.MYSBL8.bootloader.high_fuses=0xD2
                MYSBL.menu.frequency.MYSBL8.bootloader.extended_fuses=0x06
                MYSBL.menu.frequency.MYSBL8.bootloader.unlock_bits=0x3F
                MYSBL.menu.frequency.MYSBL8.bootloader.lock_bits=0x0F
                MYSBL.menu.frequency.MYSBL8.bootloader.file=MySensors/MYSBootloader_8MHz.hex
                MYSBL.menu.frequency.MYSBL1=1MHz RC
                MYSBL.menu.frequency.MYSBL1.build.f_cpu=1000000L
                MYSBL.menu.frequency.MYSBL1.upload.speed=9600
                MYSBL.menu.frequency.MYSBL1.bootloader.low_fuses=0x62
                MYSBL.menu.frequency.MYSBL1.bootloader.high_fuses=0xD2
                MYSBL.menu.frequency.MYSBL1.bootloader.extended_fuses=0x06
                MYSBL.menu.frequency.MYSBL1.bootloader.unlock_bits=0x3F
                MYSBL.menu.frequency.MYSBL1.bootloader.lock_bits=0x0F
                MYSBL.menu.frequency.MYSBL1.bootloader.file=MySensors/MYSBootloader_1MHz.hex
                • SoloamS
                  SoloamS
                  Soloam
                  The complete Log on trying to load the sketch with the FTDI to the ATMEGA! I don't know if not working with the FTDI has anyting related with not being able to flash with the MyController, but it's strange... Just giving all info as possible to try to get some help on the problem.
                  Arduino: 1.8.5 (Linux), Board: "ATmega328 with MYSBootloader 1.3.0, 8MHz RC"
                  Warning: Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
                  Sketch uses 13290 bytes (43%) of program storage space. Maximum is 30720 bytes.
                  Global variables use 714 bytes (34%) of dynamic memory, leaving 1334 bytes for local variables. Maximum is 2048 bytes.
                  /opt/arduino-1.8.5/hardware/tools/avr/bin/avrdude -C/opt/arduino-1.8.5/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b115200 -D -Uflash:w:/tmp/arduino_build_550364/LightActuator.ino.hex:i
                  avrdude: Version 6.3, compiled on Jan 17 2017 at 11:00:16
                           Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                           Copyright (c) 2007-2014 Joerg Wunsch
                           System wide configuration file is "/opt/arduino-1.8.5/hardware/tools/avr/etc/avrdude.conf"
                           User configuration file is "/home/diogo/.avrduderc"
                           User configuration file does not exist or is not a regular file, skipping
                           Using Port                    : /dev/ttyUSB0
                           Using Programmer              : arduino
                           Overriding Baud Rate          : 115200
                  avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
                  avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
                  avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
                  avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
                  avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
                  avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
                  avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
                  avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
                  avrdude done.  Thank you.
                  Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
                  option enabled in File -> Preferences.
                  Thank You
                  • SoloamS
                    SoloamS
                    Soloam
                    Can It be my version of the Arduino AVR Boards? I have 1.6.21, and the same occurs on 1.6.20.
                    Thank You
                    • SoloamS
                      SoloamS
                      Soloam
                      Ok, at this point I can't access by FTDI to the 8Mhz, all the other frequencies ar working... I only tested the FOTA with the 8Mhz, so I'll teste it again today with the 1Mhz and post back the results.
                      • SoloamS
                        SoloamS
                        Soloam
                        I can confirm that FOTA is working on all frequency, except 8Mhz... I can't get it working on FOTA or FTDI on the 8Mhz version of MYSBootloader!
                        Can any one help me with this?
                        Thank you
                        tekkaT 1 Reply Last reply
                        • SoloamS Soloam
                          Thank you
                          tekkaT
                          tekkaT
                          tekka
                          @soloam I assume 115200 baud@8Mhz could be an issue, decreasing it to 57600 may help (i.e. in mysbootloader & boards.txt settings)
                          • SoloamS
                            SoloamS
                            Soloam
                            @tekka said in FOTA Not Working:
                            57600
                            hello @tekka I tested out with:
                            57600
                            38400
                            19200
                            9600
                            4800
                            2400
                            None worked, strange that is working on the 16Mhz and 1Mhz, and only the 8Mhz is giving problems... exactly the one that I wanted to use... lol
                            Thank You
                            gohanG tekkaT 2 Replies Last reply
                            • SoloamS Soloam
                              57600
                              57600
                              38400
                              19200
                              9600
                              4800
                              2400
                              Thank You
                              @soloam said in FOTA Not Working:
                              Murphy's law :sweat_smile:
                              • SoloamS Soloam
                                57600
                                57600
                                38400
                                19200
                                9600
                                4800
                                2400
                                Thank You
                                tekkaT
                                tekkaT
                                tekka
                                @soloam When you tested the different baud settings, did you also change it in mysbootloader and recompiled it?
                                • SoloamS
                                  SoloamS
                                  Soloam
                                  Do you mean over here @tekka?
                                  /* set the UART baud rate defaults */
                                  #ifndef BAUD_RATE
                                  	#if F_CPU >= 8000000L
                                  		#define BAUD_RATE   115200L
                                  	#elif F_CPU >= 1000000L
                                  		#define BAUD_RATE   9600L   // 19200 also supported, but with significant error
                                  	#elif F_CPU >= 128000L
                                  		#define BAUD_RATE   4800L   // Good for 128kHz internal RC
                                  	#else
                                  		#define BAUD_RATE 1200L     // Good even at 32768Hz
                                  No, I will try it... Can I do it in "Atom"? any special settings?
                                  Thank You
                                  • SoloamS Soloam
                                    #ifndef BAUD_RATE
                                    	#else
                                    Thank You
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @soloam Yes, that's the correct location (if BAUD_RATE is not set via compiler settings).
                                    Sorry, but I have no experience with Atom.
                                    • SoloamS
                                      SoloamS
                                      Soloam
                                      @tekka it worked :) Thank you for your assist, it was my first time doing this... so... :)
                                      I made the change to HW.h to
                                      #ifndef BAUD_RATE
                                      	#if F_CPU >= 16000000L
                                      	#elif F_CPU >= 8000000L
                                      		#define BAUD_RATE   57600L
                                      	#else
                                      Compilled the new bootloader, and replaced it on the Arduino IDE folder... Flashed the new 8Mhz Bootloader to my node and now FTDI works... When I get home I'll test out FOTA and post back the results.
                                      Will you change the GitHub Repo to take into account this change? Or is this a local problem only to me? Do you want me to submit change the code and hex file and submit a change request?
                                      Thank You
                                      • SoloamS Soloam
                                        #ifndef BAUD_RATE
                                        	#else
                                        Thank You
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @soloam well done! Yes, please go ahead and submit a PR with the necessary changes. I will review it later this week.
                                        • tekkaT tekka
                                          SoloamS
                                          SoloamS
                                          Soloam
                                          @tekka FOTA and FTDI now working on 8Mhz Bootloader... PR submited!
                                          Thank you for your help
