  3. Car present detector needed
7 Posts 4 Posters 2.7k Views 1 Watching
  • R Offline
    R Offline
    Rotech
    Hi, this is my first post, I have never experimented with arduino before but there always a first time. I would like to build some kind of sensor with some kind of long range that can detect if the car is in at least in the driveway, has anyone seen something similar to this ?
    • K Offline
      K Offline
      krayola
      Why not have a battery operated sensor transmitting every 2-5 min? When it's not in the driveway it wouldn't be in range :)
      • R Offline
        R Offline
        Rotech
        Thks for replying, what components are involved in a project like this?
        • H Offline
          H Offline
          2 Arduinos + 2 radios.
          Make sure to set the car sensor with static parent pointing to your gateway or repeater mounted near the driveway (see gw.begin()). This will make the car sensor node stop searching for other parents.
          • R Offline
            R Offline
            Rotech
            Where is GWbegin?
            H 1 Reply Last reply
            • R Rotech
              Where is GWbegin?
              H Offline
              H Offline
              @Rotech
              See API dcumentation on main site.
              • O Offline
                O Offline
                olaeke
                I you plan to put a sensor in your car you should add proper protection on the power supply to protect against load dump. You can get peak voltage up to 100V for several of ms, that kill most unprotected Electronic.
                12.1k
