  3. OpenHAB
  4. The temperature and humidity sensor sends only humidity. Please help me understand.
10 Posts 3 Posters 3.4k Views 2 Watching
  • vladimirV
    vladimirV
    vladimir
    Hello! I'm trying to connect a temperature and humidity sensor to Openhab 2.2.
    The sensor is detected automatically as "Humidity Sensor".
    But it displays the following:
    Humidity Sensor
    Please help me understand and solve the problem. What am I doing wrong?
    Sensor code:
    //#define MY_RS485
    #include <DHT.h>
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 10000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    Debug information from the sensor:
    16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
    25 TSM:INIT
    26 TSF:WUR:MS=0
    33 TSM:INIT:TSP OK
    35 TSF:SID:OK,ID=24
    37 TSM:FPAR
    73 TSF:MSG:SEND,24-24-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    627 TSF:MSG:READ,0-0-24,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    632 TSF:MSG:FPAR OK,ID=0,D=1
    2081 TSM:FPAR:OK
    2082 TSM:ID
    2083 TSM:ID:OK
    2085 TSM:UPL
    2088 TSF:MSG:SEND,24-24-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2191 TSF:MSG:READ,0-0-24,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2196 TSF:MSG:PONG RECV,HP=1
    2198 TSM:UPL:OK
    2200 TSM:READY:ID=24,PAR=0,DIS=1
    2204 TSF:MSG:SEND,24-24-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2332 TSF:MSG:READ,0-0-24,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2340 TSF:MSG:SEND,24-24-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
    2349 TSF:MSG:SEND,24-24-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2586 TSF:MSG:READ,0-0-24,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2593 TSF:MSG:SEND,24-24-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:TemperatureAndHumidity
    2604 TSF:MSG:SEND,24-24-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    2612 TSF:MSG:SEND,24-24-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2653 !TSF:MSG:SEND,24-24-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
    2660 MCO:REG:REQ
    2663 TSF:MSG:SEND,24-24-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
    2938 TSF:MSG:READ,0-0-24,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2944 MCO:PIM:NODE REG=1
    2946 MCO:BGN:STP
    2952 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2957 TSF:TDI:TSL
    2959 MCO:SLP:WUP=-1
    2961 TSF:TRI:TSB
    2963 MCO:BGN:INIT OK,TSP=1
    2972 TSF:MSG:SEND,24-24-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.8
    T: 26.80
    2980 TSF:MSG:SEND,24-24-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:14.2
    H: 14.20
    2988 MCO:SLP:MS=10000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2993 TSF:TDI:TSL
    2995 MCO:SLP:WUP=-1
    2997 TSF:TRI:TSB
    3005 TSF:MSG:SEND,24-24-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.5
    T: 26.50
    3014 TSF:MSG:SEND,24-24-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:14.3
    H: 14.30
    3021 MCO:SLP:MS=10000,SMS=0,I1=255,M1=255,I2=255,M2=255
    3026 TSF:TDI:TSL
    My node is built on Arduino Nano + NRF24L01+
    My gateway node is built on NodeMcu + NRF24L01+
    Controller Openhab 2.2 (Openhabian + Raspberry Pi 3)
    MySensors library 2.2
    • vladimirV vladimir
      Humidity Sensor
      Sensor code:
      //#define MY_RS485
      #include <DHT.h>
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
      25 TSM:INIT
      26 TSF:WUR:MS=0
      33 TSM:INIT:TSP OK
      35 TSF:SID:OK,ID=24
      37 TSM:FPAR
      2081 TSM:FPAR:OK
      2082 TSM:ID
      2083 TSM:ID:OK
      2085 TSM:UPL
      2198 TSM:UPL:OK
      2660 MCO:REG:REQ
      2946 MCO:BGN:STP
      2957 TSF:TDI:TSL
      2959 MCO:SLP:WUP=-1
      2961 TSF:TRI:TSB
      T: 26.80
      H: 14.20
      2993 TSF:TDI:TSL
      2995 MCO:SLP:WUP=-1
      2997 TSF:TRI:TSB
      T: 26.50
      H: 14.30
      3026 TSF:TDI:TSL
      @vladimir the presentation message for temperature failed (indicated by st=NACK in the log)
      Add wait(200); before the presentation line, that usually helps
      vladimirV 2 Replies Last reply
        vladimirV
        vladimirV
        vladimir
        This post is deleted!
          vladimirV
          vladimirV
          vladimir
          @mfalkvidd Thank you! :raised_hands: Everything worked! :star2:
            @vladimir great! Thanks for reporting back.
            vladimirV 1 Reply Last reply
              vladimirV
              vladimirV
              vladimir
              @mfalkvidd Tell me please, can I somehow unite them in one device? Now this sensor is displayed as two separate devices. But this is one physical device.
                @vladimir I have no experience with OpenHab. Sorry.
                  vladimirV
                  vladimirV
                  vladimir
                  @mfalkvidd I assumed that this change is made in the code of the sensor itself. For example, during its presentation.
                    @vladimir in my experience, it is not. Domoticz unites some of my sensors even when I don't want them united. My guess is that OpenHab is equally annoying, but in the other direction.
                    • bgunnarbB
                      bgunnarbB
                      bgunnarb
                      I agree with @mfalkvidd. This is not due to the sensor code but this is the way OH handles the data.
                      I'm using OH but the MQTT 1.x binding that does not support discovery. I manually define three logical devices, temp, hum and batt in the .items file. I think this is the expected behaviour of OH.
                      If you want them presented as one device you could combine the measurements into one string by using a rule and do some string manipulation. I do this to combine wind speed and direction into one string.
                      I have never been so busy since I retired!
