  3. atmega328p small (SMD) alternative with more memory?
37 Posts 8 Posters 7.1k Views 9 Watching
  • NeverDieN NeverDie
    In terms of BOM cost, it would be cheaper to add a second atmega328p (or even multiple) than to use a 1284. Maybe worth considering if memory of just one is insufficient.
    alexsh1A
    alexsh1A
    alexsh1
    @neverdie Did you see any small devices with two atmega328p?
    Unfortunately, atmega1284p is more pricey (Moteino Mega is $15.95 on sale right now) and size wise it is much larger than atmega328p-au projects.
    NeverDieN 1 Reply Last reply
    • alexsh1A alexsh1
      NeverDieN
      NeverDieN
      @alexsh1 said in atmega328p small (SMD) alternative with more memory?:
      Yes, that's what I was trying to say.
      • NeverDieN
        NeverDieN
        On the other hand, if you go with the cheapest source, the 1284p is not too bad. Here's the cheapest I could find:
        https://www.aliexpress.com/item/ATMEGA1284P-AU-ATMEGA1284P-ATMEGA1284-TQFP44/32864539405.html?spm=2114.search0104.3.1.2efd4b5asFo5Vr&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10344_10068_10130_10324_10342_5722912_10547_10325_10343_10546_10340_10341_10548_5722612_10698_10545_10697_10696_5722812_10084_10083_10618_5722712_10307_5711215_10059_10534_308_100031_10103_441_10624_10623_10622_5711315_10621_5723012_10620_5722512,searchweb201603_1,ppcSwitch_5&algo_expid=2d7e9a21-bc2a-4ce1-bfa8-6246a79e84df-0&algo_pvid=2d7e9a21-bc2a-4ce1-bfa8-6246a79e84df&priceBeautifyAB=0
        alexsh1A 1 Reply Last reply
          alexsh1A
          alexsh1A
          alexsh1
          @neverdie said in atmega328p small (SMD) alternative with more memory?:
          I paid around £3.5 (about $5) and thought it was the cheapest. WOW!
          • alexsh1A
            alexsh1A
            alexsh1
            #25
            My new toy (atmega1284p) - Mightyduino
            However, I have to think about connecting radio as this is just a bare board.
            Size wise it is quite small0_1523634439436_53944617-D2C8-4479-A40A-42DA90D8D896.jpeg
            T 1 Reply Last reply
            • alexsh1A alexsh1
              tochinet
              wrote on last edited by tochinet
              #26
              @alexsh1 Wouldn"t a teensy 3.sth fill all the requirements ? Or an ESP8266 if you don't need ADC mux. ESP32 is you do.
              R alexsh1A 2 Replies Last reply
              • T tochinet
                R
                R
                RWoerz
                @tochinet
                If you don't need a lot of them use a Mega it has lots more memory. They're much cheaper than they used to be. Of course an ESP8266 will also work if you don't need all the pins.
                • coddingtonbearC
                  coddingtonbearC
                  coddingtonbear
                  You might want to consider the STM32F103 -- they're programmable over serial in much the same way that traditional ATMEGA chips are, are arduino-compatible, can be found for roughly the same price as the 1284p, are a ton faster, and most versions have a ton more memory and flash.
                  You can see the full lineup of chips here: http://www.st.com/en/microcontrollers/stm32f103.html?querycriteria=productId=LN1565 -- I've personally used the STM32F103CB and STM32F103RE in a handful of projects lately.
                  • T tochinet
                    alexsh1A
                    alexsh1A
                    alexsh1
                    #29
                    @tochinet esp8266 and esp32 are hardly smaller than mega. Teensy is a good option. There is even an adapter to hook it up to Rfm69
                    • coddingtonbearC coddingtonbear
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @coddingtonbear interesting! Did you have any experience with STM32L0 (more suitable for battery power)? Do they have anything small enough?
                      coddingtonbearC 1 Reply Last reply
                      • NeverDieN
                        NeverDieN
                        @coddingtonbear said in atmega328p small (SMD) alternative with more memory?:
                        STM32F103
                        Does it have any advantages over the ARM used in the nRF52832? The nRF52832 SoC is built around a 32-bit ARM® Cortex™-M4F CPU with 512kB + 64kB RAM. Not sure about other features, but I believe the nRF52832 wins on flash and RAM size.
                        mfalkviddM coddingtonbearC 2 Replies Last reply
                          STM32F103
                          @neverdie stm32 supports up to 51 i/o pins, compared to 32 for the nrf52. But very few projects need that many pins.
                            #33
                            There are some small stm32 boards that pack a lot of io though. I like the double row approah. Not breadboard friendly, but very compact. Are there similar nrf5 boards?
                            • alexsh1A alexsh1
                              coddingtonbearC
                              coddingtonbearC
                              coddingtonbear
                              @alexsh1 I'm afraid I've only used STM32F103 variants. Although the Arduino core I've used (https://github.com/rogerclarkmelbourne/Arduino_STM32) is STM32F103 specific, it does look like the official core has support for that chip, though: https://github.com/stm32duino/Arduino_Core_STM32. Just keep in mind that different chips have differing capabilities as far as programming is concerned; I do think the STM32F103 is the most limited of them, though -- you can find details about the bootloader version for each chip here: http://www.st.com/content/ccc/resource/technical/document/application_note/b9/9b/16/3a/12/1e/40/0c/CD00167594.pdf/files/CD00167594.pdf/jcr:content/translations/en.CD00167594.pdf .
                                STM32F103
                                coddingtonbearC
                                coddingtonbearC
                                coddingtonbear
                                @neverdie Not sure -- I do know that the STM32 lineup goes as high as a whole megabyte of flash and 96k of ram -- just a little north of the numbers you've quoted for the nRF52832. I have to say that I haven't looked into that specific chip in much depth, though, given that my recent projects have needed low power consumption and lots of pins more than they do onboard BLE. I have used the ESP32 on a few projects in that category though!
                                • alexsh1A alexsh1
                                  tochinet
                                  @alexsh1 You didn't say which direction is too big. But another smaller alternative is also panstamp NRG. a bit pricey but it comes with its own RF component. I was actually thinking of asking about its support in another thread...
                                  • T tochinet
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @tochinet I am just looking for something really small like some atmega328p boards, but more memory.
                                    Like this - http://mklec.com/project-kits/kd-circuits/328-board-ATMEGA328P-microcontroller-board
                                    or
                                    https://www.openhardware.io/view/76/Stamp-size-MySensor-node
                                    with (1) signing (2) encryption plus a few libs one can quickly run out of memory.
