  3. atmega328p small (SMD) alternative with more memory?
37 Posts 8 Posters 7.1k Views 9 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    You will then waste memory with "intercom" between the devices. As they have to speak together in some way..
      In terms of BOM cost, it would be cheaper to add a second atmega328p (or even multiple) than to use a 1284. Maybe worth considering if memory of just one is insufficient.
      alexsh1A
      alexsh1A
      alexsh1
      @neverdie Did you see any small devices with two atmega328p?
      Unfortunately, atmega1284p is more pricey (Moteino Mega is $15.95 on sale right now) and size wise it is much larger than atmega328p-au projects.
      • alexsh1A alexsh1
        @alexsh1 said in atmega328p small (SMD) alternative with more memory?:
        Yes, that's what I was trying to say.
          On the other hand, if you go with the cheapest source, the 1284p is not too bad. Here's the cheapest I could find:
          https://www.aliexpress.com/item/ATMEGA1284P-AU-ATMEGA1284P-ATMEGA1284-TQFP44/32864539405.html?spm=2114.search0104.3.1.2efd4b5asFo5Vr&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10344_10068_10130_10324_10342_5722912_10547_10325_10343_10546_10340_10341_10548_5722612_10698_10545_10697_10696_5722812_10084_10083_10618_5722712_10307_5711215_10059_10534_308_100031_10103_441_10624_10623_10622_5711315_10621_5723012_10620_5722512,searchweb201603_1,ppcSwitch_5&algo_expid=2d7e9a21-bc2a-4ce1-bfa8-6246a79e84df-0&algo_pvid=2d7e9a21-bc2a-4ce1-bfa8-6246a79e84df&priceBeautifyAB=0
          alexsh1A 1 Reply Last reply
            alexsh1A
            alexsh1A
            alexsh1
            @neverdie said in atmega328p small (SMD) alternative with more memory?:
            I paid around £3.5 (about $5) and thought it was the cheapest. WOW!
            • alexsh1A
              alexsh1A
              alexsh1
              #25
              My new toy (atmega1284p) - Mightyduino
              However, I have to think about connecting radio as this is just a bare board.
              Size wise it is quite small0_1523634439436_53944617-D2C8-4479-A40A-42DA90D8D896.jpeg
              • alexsh1A alexsh1
                tochinet
                wrote on last edited by tochinet
                #26
                @alexsh1 Wouldn"t a teensy 3.sth fill all the requirements ? Or an ESP8266 if you don't need ADC mux. ESP32 is you do.
                R alexsh1A 2 Replies Last reply
                • T tochinet
                  R
                  R
                  RWoerz
                  @tochinet
                  If you don't need a lot of them use a Mega it has lots more memory. They're much cheaper than they used to be. Of course an ESP8266 will also work if you don't need all the pins.
                  • coddingtonbearC
                    coddingtonbearC
                    coddingtonbear
                    You might want to consider the STM32F103 -- they're programmable over serial in much the same way that traditional ATMEGA chips are, are arduino-compatible, can be found for roughly the same price as the 1284p, are a ton faster, and most versions have a ton more memory and flash.
                    You can see the full lineup of chips here: http://www.st.com/en/microcontrollers/stm32f103.html?querycriteria=productId=LN1565 -- I've personally used the STM32F103CB and STM32F103RE in a handful of projects lately.
                    • T tochinet
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #29
                      @tochinet esp8266 and esp32 are hardly smaller than mega. Teensy is a good option. There is even an adapter to hook it up to Rfm69
                      • coddingtonbearC coddingtonbear
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @coddingtonbear interesting! Did you have any experience with STM32L0 (more suitable for battery power)? Do they have anything small enough?
                        coddingtonbearC 1 Reply Last reply
                          @coddingtonbear said in atmega328p small (SMD) alternative with more memory?:
                          STM32F103
                          Does it have any advantages over the ARM used in the nRF52832? The nRF52832 SoC is built around a 32-bit ARM® Cortex™-M4F CPU with 512kB + 64kB RAM. Not sure about other features, but I believe the nRF52832 wins on flash and RAM size.
                          mfalkviddM coddingtonbearC 2 Replies Last reply
                            STM32F103
                            @neverdie stm32 supports up to 51 i/o pins, compared to 32 for the nrf52. But very few projects need that many pins.
                            • mfalkviddM
                              #33
                              There are some small stm32 boards that pack a lot of io though. I like the double row approah. Not breadboard friendly, but very compact. Are there similar nrf5 boards?
                              • alexsh1A alexsh1
                                coddingtonbearC
                                coddingtonbearC
                                coddingtonbear
                                @alexsh1 I'm afraid I've only used STM32F103 variants. Although the Arduino core I've used (https://github.com/rogerclarkmelbourne/Arduino_STM32) is STM32F103 specific, it does look like the official core has support for that chip, though: https://github.com/stm32duino/Arduino_Core_STM32. Just keep in mind that different chips have differing capabilities as far as programming is concerned; I do think the STM32F103 is the most limited of them, though -- you can find details about the bootloader version for each chip here: http://www.st.com/content/ccc/resource/technical/document/application_note/b9/9b/16/3a/12/1e/40/0c/CD00167594.pdf/files/CD00167594.pdf/jcr:content/translations/en.CD00167594.pdf .
                                  STM32F103
                                  coddingtonbearC
                                  coddingtonbearC
                                  coddingtonbear
                                  @neverdie Not sure -- I do know that the STM32 lineup goes as high as a whole megabyte of flash and 96k of ram -- just a little north of the numbers you've quoted for the nRF52832. I have to say that I haven't looked into that specific chip in much depth, though, given that my recent projects have needed low power consumption and lots of pins more than they do onboard BLE. I have used the ESP32 on a few projects in that category though!
                                  • alexsh1A alexsh1
                                    tochinet
                                    @alexsh1 You didn't say which direction is too big. But another smaller alternative is also panstamp NRG. a bit pricey but it comes with its own RF component. I was actually thinking of asking about its support in another thread...
                                    • T tochinet
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @tochinet I am just looking for something really small like some atmega328p boards, but more memory.
                                      Like this - http://mklec.com/project-kits/kd-circuits/328-board-ATMEGA328P-microcontroller-board
                                      or
                                      https://www.openhardware.io/view/76/Stamp-size-MySensor-node
                                      with (1) signing (2) encryption plus a few libs one can quickly run out of memory.
