  3. atmega328p small (SMD) alternative with more memory?
37 Posts 8 Posters 7.1k Views 9 Watching
  • AnticimexA Anticimex
    @neverdie I perhaps misread the thread title... I did not interpret the quest as something that should be binary identical to atmega328p.
    @anticimex Yeah, the title was ambiguous. Looking back, your interpretation is probably closer than mine as to what he meant though.
      alexsh1A
      alexsh1A
      alexsh1
      @anticimex you are absolutely correct. It does not have to be binary identical to atmega328p. However, size wise, it has to be small enough.
      For now atmega1284p is a direct replacement for atmega328p as code is almost identical. I do not need much more processing power just memory. However, I did struggle to find a very small footprint.
      • tbowmoT
        tbowmoT
        tbowmo
        @alexsh1
        Hmm.. perhaps I should pick up on the SenseBender MK2 again.. I lost focus as I had a lot of other projects running at the same time..
        If I remember right, it had problems in it's bootup sequence when I left it alone last..
          In terms of BOM cost, it would be cheaper to add a second atmega328p (or even multiple) than to use a 1284. Maybe worth considering if memory of just one is insufficient.
          alexsh1A 1 Reply Last reply
          • tbowmoT
            tbowmoT
            tbowmo
            You will then waste memory with "intercom" between the devices. As they have to speak together in some way..
              alexsh1A
              alexsh1A
              alexsh1
              @neverdie Did you see any small devices with two atmega328p?
              Unfortunately, atmega1284p is more pricey (Moteino Mega is $15.95 on sale right now) and size wise it is much larger than atmega328p-au projects.
              • alexsh1A alexsh1
                @alexsh1 said in atmega328p small (SMD) alternative with more memory?:
                Yes, that's what I was trying to say.
                  On the other hand, if you go with the cheapest source, the 1284p is not too bad. Here's the cheapest I could find:
                  https://www.aliexpress.com/item/ATMEGA1284P-AU-ATMEGA1284P-ATMEGA1284-TQFP44/32864539405.html?spm=2114.search0104.3.1.2efd4b5asFo5Vr&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10344_10068_10130_10324_10342_5722912_10547_10325_10343_10546_10340_10341_10548_5722612_10698_10545_10697_10696_5722812_10084_10083_10618_5722712_10307_5711215_10059_10534_308_100031_10103_441_10624_10623_10622_5711315_10621_5723012_10620_5722512,searchweb201603_1,ppcSwitch_5&algo_expid=2d7e9a21-bc2a-4ce1-bfa8-6246a79e84df-0&algo_pvid=2d7e9a21-bc2a-4ce1-bfa8-6246a79e84df&priceBeautifyAB=0
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @neverdie said in atmega328p small (SMD) alternative with more memory?:
                    I paid around £3.5 (about $5) and thought it was the cheapest. WOW!
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      #25
                      My new toy (atmega1284p) - Mightyduino
                      However, I have to think about connecting radio as this is just a bare board.
                      Size wise it is quite small0_1523634439436_53944617-D2C8-4479-A40A-42DA90D8D896.jpeg
                      • alexsh1A alexsh1
                        tochinet
                        wrote on last edited by tochinet
                        #26
                        @alexsh1 Wouldn"t a teensy 3.sth fill all the requirements ? Or an ESP8266 if you don't need ADC mux. ESP32 is you do.
                        R alexsh1A 2 Replies Last reply
                        • T tochinet
                          R
                          R
                          RWoerz
                          @tochinet
                          If you don't need a lot of them use a Mega it has lots more memory. They're much cheaper than they used to be. Of course an ESP8266 will also work if you don't need all the pins.
                          • coddingtonbearC
                            coddingtonbearC
                            coddingtonbear
                            You might want to consider the STM32F103 -- they're programmable over serial in much the same way that traditional ATMEGA chips are, are arduino-compatible, can be found for roughly the same price as the 1284p, are a ton faster, and most versions have a ton more memory and flash.
                            You can see the full lineup of chips here: http://www.st.com/en/microcontrollers/stm32f103.html?querycriteria=productId=LN1565 -- I've personally used the STM32F103CB and STM32F103RE in a handful of projects lately.
                            • T tochinet
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #29
                              @tochinet esp8266 and esp32 are hardly smaller than mega. Teensy is a good option. There is even an adapter to hook it up to Rfm69
                              • coddingtonbearC coddingtonbear
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @coddingtonbear interesting! Did you have any experience with STM32L0 (more suitable for battery power)? Do they have anything small enough?
                                coddingtonbearC 1 Reply Last reply
                                  @coddingtonbear said in atmega328p small (SMD) alternative with more memory?:
                                  STM32F103
                                  Does it have any advantages over the ARM used in the nRF52832? The nRF52832 SoC is built around a 32-bit ARM® Cortex™-M4F CPU with 512kB + 64kB RAM. Not sure about other features, but I believe the nRF52832 wins on flash and RAM size.
                                  mfalkviddM coddingtonbearC 2 Replies Last reply
                                    STM32F103
                                    @neverdie stm32 supports up to 51 i/o pins, compared to 32 for the nrf52. But very few projects need that many pins.
                                    • mfalkviddM
                                      #33
                                      There are some small stm32 boards that pack a lot of io though. I like the double row approah. Not breadboard friendly, but very compact. Are there similar nrf5 boards?
                                      • alexsh1A alexsh1
                                        coddingtonbearC
                                        coddingtonbearC
                                        coddingtonbear
                                        @alexsh1 I'm afraid I've only used STM32F103 variants. Although the Arduino core I've used (https://github.com/rogerclarkmelbourne/Arduino_STM32) is STM32F103 specific, it does look like the official core has support for that chip, though: https://github.com/stm32duino/Arduino_Core_STM32. Just keep in mind that different chips have differing capabilities as far as programming is concerned; I do think the STM32F103 is the most limited of them, though -- you can find details about the bootloader version for each chip here: http://www.st.com/content/ccc/resource/technical/document/application_note/b9/9b/16/3a/12/1e/40/0c/CD00167594.pdf/files/CD00167594.pdf/jcr:content/translations/en.CD00167594.pdf .
                                          STM32F103
                                          coddingtonbearC
                                          coddingtonbearC
                                          coddingtonbear
                                          @neverdie Not sure -- I do know that the STM32 lineup goes as high as a whole megabyte of flash and 96k of ram -- just a little north of the numbers you've quoted for the nRF52832. I have to say that I haven't looked into that specific chip in much depth, though, given that my recent projects have needed low power consumption and lots of pins more than they do onboard BLE. I have used the ESP32 on a few projects in that category though!
