  3. atmega328p small (SMD) alternative with more memory?
37 Posts 8 Posters 7.1k Views 9 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    Alternatively, this is a good size for a node - https://www.sparkfun.com/products/13664
    • alexsh1A alexsh1
      @NeverDie Check out this one nRF52. Its not cheap though
      https://www.tindie.com/products/onehorse/nrf52-add-on-for-butterfly-and-teensy/?pt=ac_prod_search
      @alexsh1 said in atmega328p small (SMD) alternative with more memory?:
      Yes, I would agree that's interesting. He uses it as a BLE device, albeit purely as a UART channel, which so far isn't something that we've managed to do here with the nRF52. @GertSanders might want to take notice, as he has been doing something similar for logging purposes, but with a different bluetooth.
      • AnticimexA Anticimex
        @neverdie a SenseBender mk2 based on samd would be a drop in replacement for SenseBender.
        @anticimex said in atmega328p small (SMD) alternative with more memory?:
        SenseBender mk2
        If that's how you define drop-in replacement, I'll concede the point.
        Actually, I suppose if you had a fast enough ARM, it could emulate an atmega328p (well, at least its software behavior), and thereby indirectly offer up additional memory. I actually own a board which, IIRC, does that, and it can run code even faster than the atmega328. Just don't expect low power performance out of it.
        AnticimexA 1 Reply Last reply
          SenseBender mk2
          AnticimexA
          AnticimexA
          Anticimex
          @neverdie I perhaps misread the thread title... I did not interpret the quest as something that should be binary identical to atmega328p.
          NeverDieN alexsh1A 2 Replies Last reply
            @anticimex Yeah, the title was ambiguous. Looking back, your interpretation is probably closer than mine as to what he meant though.
              alexsh1A
              alexsh1A
              alexsh1
              @anticimex you are absolutely correct. It does not have to be binary identical to atmega328p. However, size wise, it has to be small enough.
              For now atmega1284p is a direct replacement for atmega328p as code is almost identical. I do not need much more processing power just memory. However, I did struggle to find a very small footprint.
              • tbowmoT
                tbowmoT
                tbowmo
                @alexsh1
                Hmm.. perhaps I should pick up on the SenseBender MK2 again.. I lost focus as I had a lot of other projects running at the same time..
                If I remember right, it had problems in it's bootup sequence when I left it alone last..
                  In terms of BOM cost, it would be cheaper to add a second atmega328p (or even multiple) than to use a 1284. Maybe worth considering if memory of just one is insufficient.
                  alexsh1A 1 Reply Last reply
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    You will then waste memory with "intercom" between the devices. As they have to speak together in some way..
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @neverdie Did you see any small devices with two atmega328p?
                      Unfortunately, atmega1284p is more pricey (Moteino Mega is $15.95 on sale right now) and size wise it is much larger than atmega328p-au projects.
                      • alexsh1A alexsh1
                        Yes, that's what I was trying to say.
                          On the other hand, if you go with the cheapest source, the 1284p is not too bad. Here's the cheapest I could find:
                          https://www.aliexpress.com/item/ATMEGA1284P-AU-ATMEGA1284P-ATMEGA1284-TQFP44/32864539405.html?spm=2114.search0104.3.1.2efd4b5asFo5Vr&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10344_10068_10130_10324_10342_5722912_10547_10325_10343_10546_10340_10341_10548_5722612_10698_10545_10697_10696_5722812_10084_10083_10618_5722712_10307_5711215_10059_10534_308_100031_10103_441_10624_10623_10622_5711315_10621_5723012_10620_5722512,searchweb201603_1,ppcSwitch_5&algo_expid=2d7e9a21-bc2a-4ce1-bfa8-6246a79e84df-0&algo_pvid=2d7e9a21-bc2a-4ce1-bfa8-6246a79e84df&priceBeautifyAB=0
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @neverdie said in atmega328p small (SMD) alternative with more memory?:
                            I paid around £3.5 (about $5) and thought it was the cheapest. WOW!
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              #25
                              My new toy (atmega1284p) - Mightyduino
                              However, I have to think about connecting radio as this is just a bare board.
                              Size wise it is quite small0_1523634439436_53944617-D2C8-4479-A40A-42DA90D8D896.jpeg
                              • alexsh1A alexsh1
                                tochinet
                                wrote on last edited by tochinet
                                #26
                                @alexsh1 Wouldn"t a teensy 3.sth fill all the requirements ? Or an ESP8266 if you don't need ADC mux. ESP32 is you do.
                                R alexsh1A 2 Replies Last reply
                                • T tochinet
                                  R
                                  R
                                  RWoerz
                                  @tochinet
                                  If you don't need a lot of them use a Mega it has lots more memory. They're much cheaper than they used to be. Of course an ESP8266 will also work if you don't need all the pins.
                                  • coddingtonbearC
                                    coddingtonbearC
                                    coddingtonbear
                                    You might want to consider the STM32F103 -- they're programmable over serial in much the same way that traditional ATMEGA chips are, are arduino-compatible, can be found for roughly the same price as the 1284p, are a ton faster, and most versions have a ton more memory and flash.
                                    You can see the full lineup of chips here: http://www.st.com/en/microcontrollers/stm32f103.html?querycriteria=productId=LN1565 -- I've personally used the STM32F103CB and STM32F103RE in a handful of projects lately.
                                    • T tochinet
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #29
                                      @tochinet esp8266 and esp32 are hardly smaller than mega. Teensy is a good option. There is even an adapter to hook it up to Rfm69
                                      • coddingtonbearC coddingtonbear
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @coddingtonbear interesting! Did you have any experience with STM32L0 (more suitable for battery power)? Do they have anything small enough?
                                        coddingtonbearC 1 Reply Last reply
                                          @coddingtonbear said in atmega328p small (SMD) alternative with more memory?:
                                          STM32F103
                                          Does it have any advantages over the ARM used in the nRF52832? The nRF52832 SoC is built around a 32-bit ARM® Cortex™-M4F CPU with 512kB + 64kB RAM. Not sure about other features, but I believe the nRF52832 wins on flash and RAM size.
                                          mfalkviddM coddingtonbearC 2 Replies Last reply
