  3. sha204 library questions
6 Posts 3 Posters 3.4k Views 3 Watching
  • DbagioniD
    DbagioniD
    Dbagioni
    Hello all.
    Im a little confused here, what can I say Im a hardware, oscilloscope, soldering iron kinda guy so code is still a bit confusing to me. Im trying to set up the security personalizer ino and keep hitting a small wall.
    The code calls for the following; #include "sha204_library.h" #include "sha204_lib_return_codes.h"
    Except in all my searching Im only finding 'sha204_library.h', all of the branches and files I can get say "sha204_lib_return_codes.h is included".
    Does this mean I only need to include the main sha204_library and not include the 'return_codes' portion separately? If I use the main library the code compiles without issues, if I'm trying to include the 'return_codes' portion it gets flagged.
    Id appreciate any thoughts.
    Dave
    • DbagioniD Dbagioni
      Hello all.
      Dave
      rozpruwaczR
      rozpruwaczR
      rozpruwacz
      @dbagioni the sha204_lib_return_codes.h file is in sketch folder so it should be found by the compiler.
      • rozpruwaczR
        rozpruwaczR
        rozpruwacz
        proof: https://github.com/mysensors/MySensors/tree/development/examples/SecurityPersonalizer
        • DbagioniD
          DbagioniD
          Dbagioni
          Thats the example I used.```
          • The MySensors Arduino library handles the wireless radio link and protocol
          • between your home built sensors/actuators and HA controller of choice.
          • The sensors forms a self healing radio network with optional repeaters. Each
          • repeater and gateway builds a routing tables in EEPROM which keeps track of the
          • network topology allowing messages to be routed to nodes.
          • Created by Henrik Ekblad henrik.ekblad@mysensors.org
          • Copyright (C) 2013-2015 Sensnology AB
          • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
          • Documentation: http://www.mysensors.org
          • Support Forum: http://forum.mysensors.org
          • This program is free software; you can redistribute it and/or
          • modify it under the terms of the GNU General Public License
          • version 2 as published by the Free Software Foundation.
          #include <sha204_library.h>
          #include <sha204_lib_return_codes.h>
          #define MY_CORE_ONLY
          *********************************** User defined key data ***************************************/
          But Im still getting this error.
           #include "sha204_includes/sha204_lib_return_codes.h"
          compilation terminated.
          exit status 1
          Error compiling for board Arduino/Genuino Uno.
          Im at a total loss. The return_codes is located in a separate folder in the libraries file - SRC (which has the main sha204_library.h file), under the SRC folder is a folder titled "includes" which has the 'return_codes.h' file. Any attempt to place it in the #include decleration results in this error.
          Dave
          • rozpruwaczR
            rozpruwaczR
            rozpruwacz
            @dbagioni said in sha204 library questions:
            I don't understand what You trying to do, but why do You want to "place it in the #include decleration" ?
            • dbagioni77D
              dbagioni77D
              dbagioni77
              I really dont want to do anything special per se....im just trying to find out if the newer library includes the "return_codes.h" as part of it, do i need a seperate #include statement?
