  3. Having an issue with message signing.
1 Posts 1 Posters 825 Views 1 Watching
  • DbagioniD
    DbagioniD
    Dbagioni
    Hello again
    I am having an issue with message signing. I have begun to expand my mysensors devices to include some actuators and sensors I want to secure. I have tried to get this to work, but keep hitting a wall.
    Here;s my set up for my testing. My mega Ethernet gateway with software backed signing enabled, and my Uno set up as a mock relay actuator with software backed signing enabled. If I set up MY_SIGNING_SIMPLE_PASSWD "blahblahblah", everything works great. As soon as thats disabled...nothing wants to talk to each other.
    How I have programmed the devices. On the gateway I ran the personalizer sketch and generated the HMAC and AES keys. I copied that info into the proper sections, disabled generate keys and enabled personalize soft. I then ran the personalizer on both the gateway and the node and received a "Succes" message.
    This is my gateway sketch.
     * Version 1.0 - Henrik EKblad
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
     * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
    #define MY_DEBUG_VERBOSE_SIGNING
    #define MY_RADIO_RF24
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_IP_ADDRESS 192,168,1,69
    #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
    #define MY_PORT 5003//
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    // Enable inclusion mode
    #define MY_INCLUSION_MODE_DURATION 90
    // Set blinking period
    #define MY_WITH_LEDS_BLINKING_INVERSE
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 40  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  42  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  44  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
    #define MY_SIGNING_SIMPLE_PASSWD "MyEmmaBemma2015"
    #define MY_SIGNING_WEAK_SECURITY
    #include <Ethernet.h>
    #include <MyConfig.h>
    When I run the gateway I get the following message in the serial monitor
    8732 TSF:MSG:BC
    8734 TSF:MSG:FPAR REQ,ID=22
    8736 TSF:CKU:OK,FCTRL
    8738 TSF:MSG:GWL OK
    9288 SGN:SKP:MSG CMD=3,TYPE=8
    9293 TSF:MSG:SEND,0-0-22-22,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    9300 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    9306 TSF:MSG:PINGED,ID=6,HP=1
    9308 SGN:SGN:NREQ=6
    9312 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    10048 TSF:MSG:READ,6-6-0,s=3,c=1,t=1,pt=7,l=5,sg=0:53.3
    10778 TSF:MSG:READ,22-22-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    10783 TSF:MSG:PINGED,ID=22,HP=1
    10786 SGN:SKP:MSG CMD=3,TYPE=25
    10791 TSF:MSG:SEND,0-0-22-22,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    10813 TSF:MSG:READ,22-22-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
    10819 SGN:PRE:SGN REQ,FROM=22
    10822 SGN:PRE:SGN NREQ,TO=22
    10824 SGN:PRE:WHI NREQ,TO=22
    10827 SGN:SKP:MSG CMD=3,TYPE=15
    10834 TSF:MSG:SEND,0-0-22-22,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    10842 SGN:PRE:XMT,TO=22
    10846 TSF:MSG:READ,22-22-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
    10856 TSF:MSG:READ,22-22-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    12869 TSF:MSG:READ,22-22-0,s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
    12879 TSF:MSG:READ,22-22-0,s=255,c=3,t=12,pt=0,l=3,sg=0:2.0
    12890 TSF:MSG:READ,22-22-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
    12901 TSF:MSG:READ,22-22-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    12906 SGN:SKP:MSG CMD=3,TYPE=16
    12913 TSF:MSG:SEND,0-0-22-22,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
    12919 SGN:SGN:NCE REQ,TO=22
    12940 TSF:MSG:READ,22-22-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
    12946 SGN:NCE:FROM=22
    12948 SGN:BND:NONCE=B8E06B367486872EC1CE2CADBF969CAAE127BADED76DF0095DAAAAAAAAAAAAAA
    13035 SGN:BND:HMAC=0699DD1F9CE2830EC9F09D858D8AB9627DDA55AFBE587C1115A95C962E0AFFF1
    13043 SGN:SGN:SGN
    13048 TSF:MSG:SEND,0-0-22-22,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
    Here is my node sketch
     **** Dave Version 1
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    //#define MY_REPEATER_FEATURE
    #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
    #define MY_NODE_ID 22
    // Select soft/hardware signing method
    #define MY_SIGNING_SOFT  //SOFTWARE BASED
    //#define MY_SIGNING_ATSHA204 //HARDWARE BASED
    //Hardware configuration for signing services
    //#define MY_SIGNING_ATSHA204_PIN A3
    #define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 1// Total number of attached relays
    void before()
            pinMode(pin, OUTPUT);
        sendSketchInfo("Relay", "2.0");
            present(sensor, S_BINARY);
        if (message.type==V_STATUS) {
            // Change relay state
            // Store state in eeprom
            // Write some debug info
            Serial.print(message.sensor);
    And this is the serial monitor output.
            |___/                      2.3.0
    16 MCO:BGN:INIT NODE,CP=RNNNAS--,VER=2.3.0
    25 MCO:BGN:BFR
    50 !SGN:PER:TAMPERED
    86 SGN:INI:BND OK
    87 TSM:INIT
    88 TSF:WUR:MS=0
    95 TSM:INIT:TSP OK
    97 TSM:INIT:STATID=22
    102 TSF:SID:OK,ID=22
    104 TSM:FPAR
    105 SGN:SGN:NREQ=255
    142 TSF:MSG:SEND,22-22-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    954 TSF:MSG:READ,0-0-22,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    959 SGN:SKP:MSG CMD=3,TYPE=8
    962 TSF:MSG:FPAR OK,ID=0,D=1
    988 TSF:MSG:READ,6-6-22,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    992 SGN:SKP:MSG CMD=3,TYPE=8
    1762 TSF:MSG:READ,1-1-22,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    1767 SGN:SKP:MSG CMD=3,TYPE=8
    2150 TSM:FPAR:OK
    2151 TSM:ID
    2152 TSM:ID:OK
    2154 TSM:UPL
    2155 SGN:SGN:NREQ=0
    2161 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2176 TSF:MSG:READ,0-0-22,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2181 SGN:SKP:MSG CMD=3,TYPE=25
    2184 TSF:MSG:PONG RECV,HP=1
    2187 TSM:UPL:OK
    2188 TSM:READY:ID=22,PAR=0,DIS=1
    2191 SGN:PRE:SGN REQ
    2193 SGN:PRE:WHI NREQ
    2195 SGN:SGN:NREQ=0
    2198 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
    2205 SGN:PRE:XMT,TO=0
    2207 SGN:PRE:WAIT GW
    2217 TSF:MSG:READ,0-0-22,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2223 SGN:SKP:MSG CMD=3,TYPE=15
    2226 SGN:SGN:NREQ=0
    2230 TSF:MSG:SEND,22-22-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
    2236 SGN:SGN:NREQ=0
    2242 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4248 SGN:SGN:NREQ=0
    4253 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
    4260 SGN:SGN:NREQ=0
    4264 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
    4271 SGN:SGN:NREQ=0
    4277 TSF:MSG:SEND,22-22-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4283 MCO:REG:REQ
    4284 SGN:SGN:NREQ=0
    4290 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4297 TSF:MSG:READ,0-0-22,s=255,c=3,t=16,pt=0,l=0,sg=0:
    4302 SGN:SKP:MSG CMD=3,TYPE=16
    4320 SGN:SGN:NREQ=0
    4327 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    4334 SGN:NCE:XMT,TO=22
    4468 TSF:MSG:READ,0-0-22,s=255,c=3,t=27,pt=1,l=1,sg=1:1
    4473 !SGN:VER:STATE
    4475 !TSF:MSG:SIGN VERIFY FAIL
    4477 MCO:BGN:STP
    4480 MCO:BGN:INIT OK,TSP=1
    What am I missing here?
