  3. [Help] - Improvement for Multisensor sketch
5 Posts 3 Posters 1.4k Views 4 Watching
  • R Offline
    R Offline
    Ruric
    Hello everybody, I'm new to this forum but starting reading some months ago. Really great work you're doing here and sharing with the community.
    I'm looking for some help to improve my understanding of the mySensors sketches. Until now, I succeeded in setting up a gateway (serial for OpenHab) and some basic sensors. Also the combination of several sketches seemed to work (thanks again for the big pile of information, that can be found in this forum). And that's where my questions start. I've a working sketch, that I'd like to improve. What and how would you do this? Is there a better way to distribute the PINs? Etc. any comment, that will help me to better understand, why and how things are working is welcome.
     * Version 1.0 - Henrik EKblad
     * Version 2.0 - Ruric
     * My general Multisensor build
    #include <DHT.h>
    #define MY_NODE_ID 1
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    #define CHILD_ID_MOTION 3
    #define CHILD_ID_DOOR 4
    // Set this to the pin you connected the sensor's data pin to
    #define DHT_DATA_PIN 3
    #define MOTION_DATA_PIN 4
    #define DOOR_DATA_PIN 5
    // Set this to the pin you connected the light level analog pin to
    #define LIGHT_SENSOR_ANALOG_PIN 0
    // Set this offset if the sensor has a permanent small offset to the real temperatures.
    // In Celsius degrees (as measured by the device)
    #define SENSOR_TEMP_OFFSET 0
    static const uint16_t UPDATE_INTERVAL = 60000; // max 65500 due to uint16_t
    int lastLight;
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    uint8_t nNoUpdatesLight;
    uint8_t nNoUpdatesMotion;
    bool metric = true;
    bool lastMotion;
    bool lastDoor;
    unsigned long lastRefreshTime = 0; // Use this to implement a non-blocking delay function
    MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
    MyMessage msgDoor(CHILD_ID_DOOR, V_TRIPPED);
    DHT dht;
    	sendSketchInfo("MySensor", "2.0");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_MOTION, S_MOTION);
      present(CHILD_ID_DOOR, S_DOOR);
      // sleep(dht.getMinimumSamplingPeriod());
      wait(dht.getMinimumSamplingPeriod());
      pinMode(MOTION_DATA_PIN, INPUT);
      pinMode(DOOR_DATA_PIN, INPUT_PULLUP);
      // Read digital motion value
      bool motion = digitalRead(MOTION_DATA_PIN) == HIGH;
      if (motion != lastMotion) {
      send(msgMotion.set(motion?"1":"0"));  // Send tripped value to gw
      lastMotion = motion;
      bool door = digitalRead(DOOR_DATA_PIN) == HIGH;
      if (door != lastDoor) {
        send(msgDoor.set(door?"1":"0"));
        lastDoor = door;
      boolean needRefresh = (millis() - lastRefreshTime) > UPDATE_INTERVAL ;
      if (needRefresh)
          lastRefreshTime = millis();
        dht.readSensor(true);
        if (isnan(temperature)) {
          lastTemp = temperature;
          // apply the offset before converting to something different than Celsius degrees
          // Reset no updates counter
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          Serial.print("T: ");
          Serial.println(temperature);
        } else {
          nNoUpdatesTemp++;
        if (isnan(humidity)) {
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
        } else {
          nNoUpdatesHum++;
        // Get LightLevel from Analog input
      	uint16_t light = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
        if (light != lastLight || nNoUpdatesLight == FORCE_UPDATE_N_READS) {
          lastLight = light;
          nNoUpdatesLight = 0;
          send(msgLight.set(light));
          #ifdef MY_DEBUG
          Serial.print("L: ");
          Serial.println(light);
        } else {
          nNoUpdatesLight++;
    berkseoB 1 Reply Last reply
    • R Ruric
      #include <DHT.h>
      int lastLight;
      float lastTemp;
      float lastHum;
      bool metric = true;
      bool lastMotion;
      bool lastDoor;
      DHT dht;
          lastDoor = door;
        if (needRefresh)
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
          } else {
            nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
          } else {
            nNoUpdatesHum++;
            lastLight = light;
            #ifdef MY_DEBUG
          } else {
            nNoUpdatesLight++;
      berkseoB Offline
      berkseoB Offline
      berkseo
      @ruric
      To improve? Do not use DHT temperature sensors
      ...But seriously, you can add descriptions to the presentation of sensors, and if seriously enough - I did not see the use of " void receive (const MyMessage & message)", no protection from situations where delivery failed.
      • rejoe2R Offline
        rejoe2R Offline
        rejoe2
        Seems already to be quite good, congratiulations!
        Beside the DHT-topic: Use a different PIN as 3 as long as possible - reserving an interrupt-option, e.g. for adding a counter imo is always a good idea :grinning: .
        Besides that you may use a debouncing method like bounce2.h for the door and motion PIN's to avoid false triggers.
        R 1 Reply Last reply
        • rejoe2R rejoe2
          R Offline
          R Offline
          Ruric
          Thanks for this feedback. For what kind of interrupt should I preferably use pin3? For the door sensor? Do you happen to have a link, where I could find more about interupt and its usecases?
          I‘ll try to see, what I can find about adding void receive. And come back with the results (or more questions to understand better).
          Which temperature and humidity sensors would you recommand?
          rejoe2R 1 Reply Last reply
          • R Ruric
            rejoe2R Offline
            rejoe2R Offline
            rejoe2
            @ruric For usage of interrupts see the Pulse-Meter (Water/Engergy) examples in Mysensors. As your sensor is not sleeping and has no longer blocking phases, usage of interrupt functionality for door or motion is not necessary.
            Combined Temp/Humidity: BME280 or SI7021, Temp alone: DS18B20.
