  3. [SOLVED] Batteries powered temperature sensore node drawn too much current
3 Posts 2 Posters 1.0k Views 2 Watching
  • D
    D
    David Muller
    Hi everyone, I just finished to build a Mysensors DS18B20 node, everything is working fine with sending, but now I wanted to power my device with batteries and I discovered that the node is drawning 3mA current in sleep mode, this is really too much for a battery device, I tried to include the "Low-power" library, but it seems that it's not compatible.
    Did somone ever had such an issue with the power consumption on Mysensor battery powered node ?
    I'm not using a Nano, but directly a ATMega328 chip, with a NRF24L01+, two AA batteries.
    Thank you
    • D
      D
      David Muller
      Hi, I finally solved the issue, the node takes about 0.02mA in sleep mode, the problem was located on the nrf24L01+, I had a 5 of them, and two nrf did the same problem (to much current in sleep mode).
      So I will keep the "hungry" NRF for sector supply nodes.
      Bye
      • D David Muller
        Bye
        Great that you found the problem @david-muller, thanks for reporting the solution.
