  3. Temperature + Humidity with OLED
3 Posts 2 Posters 2.7k Views 2 Watching
  • T
    titvs
    Hi everyone.
    I've introduced a small 0.96" OLED display (based on the SSD1306) on the temperature and humidity node, so you can read directly the values as you enter the house compartment (as you can see above).
    Since i dont know the reliability of this kind of displays and they are a bit bright (of if they have some kind of burn-in issue), im asking you guys for some ideas to turn it off and back on, maybe taking into account info got from the controller (and even display other info).
    Im using the u8g2 display library wich has the instruction "setContrast", but these displays dont support contrast control. It seems the only way is to turn it off with the instruction "setPowerSave".
    I was thinking of displaying the current date also and maybe turn it off at night. For this i was thinking of using the "requestTime()" command…
    What do you guys think?
    Here is my code so you can take a look and use on your own projects:
    // Enable debug prints
    //#define MY_DEBUG
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define MY_RFM69_NEW_DRIVER
    #define MY_RFM69_FREQUENCY RFM69_433MHZ
    #define MY_NODE_ID 15
    // #define MY_REPEATER_FEATURE
    #include <DHT.h>
    #include <U8g2lib.h>
    #include <Wire.h>
    U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, A5, A4);   // U8G2 Constructor (A5 - Clock SCL ; A4 - Data SDA)
    #define DHT_DATA_PIN 3
    // Set this offset if the sensor has a permanent small offset to the real temperatures.
    // In Celsius degrees (as measured by the device)
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    void before(){
       u8g2.begin();
       u8g2.firstPage();
       do {
         u8g2.setFont(u8g2_font_helvR14_tf);
         u8g2.drawStr(38,15,"OLED");
         u8g2.drawStr(15,35,"Temp+Hum");
         u8g2.drawStr(46,60,"v1.2");
       } while ( u8g2.nextPage() );
      delay(3000);
      u8g2.clear();
       u8g2.firstPage();
        do {
         u8g2.drawStr(3, 32, "Connecting...");
      sendSketchInfo("TEMPHUM_OLED", "1.2");
      present(CHILD_ID_HUM, S_HUM);
      u8g2.clear();
        u8g2.firstPage();
        do {
            u8g2.setFont(u8g2_font_haxrcorp4089_tr); // 7 PIXEL HIGHT
            u8g2.drawStr(1,12,"WARNING: UPDATE_INTERVAL");
           u8g2.drawStr(1,24,"is smaller than supported by");
            u8g2.drawStr(1,36,"the sensor!");
        delay(4000);
     while (transportCheckUplink() == false){
      u8g2.firstPage();
      do {
        u8g2.setFont(u8g2_font_helvR14_tf); // 14 px height
        u8g2.drawStr(3, 32, "Disconnected!");
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        // apply the offset before converting to something different than Celsius degrees
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      u8g2.firstPage();
      do {
       u8g2.setFont(u8g2_font_fub30_tn);
      u8g2.setCursor(2, 35);
      u8g2.print(temperature, 1);
      u8g2.setFont(u8g2_font_inb16_mf);
      u8g2.drawGlyph(88, 35, 0x00b0); // degree
      u8g2.drawStr(100, 35, "C");
      u8g2.setCursor(70, 60);
      u8g2.print(humidity, 0);
      u8g2.drawStr(100, 60, "%");
      u8g2.setFont(u8g2_font_open_iconic_thing_2x_t); // 16 pix height
      u8g2.drawGlyph(45, 60, 0x0048); // drop
      wait(UPDATE_INTERVAL);  // POWERED NODE
    Be advised that this code is almost near the memory capacity of the Nano 328P... :P
    • T titvs
      Hi everyone.
      //#define MY_DEBUG
      #include <DHT.h>
      #include <Wire.h>
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      void before(){
         u8g2.begin();
         u8g2.firstPage();
         do {
        delay(3000);
        u8g2.clear();
         u8g2.firstPage();
          do {
        u8g2.clear();
          u8g2.firstPage();
          do {
          delay(4000);
        u8g2.firstPage();
        do {
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
        u8g2.firstPage();
        do {
      @titvs I don’t think burn-in is a problem with these displays, but an elegant solution vould be to turn it on/off based on a PIR/motion sensor. Maybe you already have such a sensor in the same room?
      T 1 Reply Last reply
        titvs
        @mfalkvidd hmm, that’s a nice suggestion... I don’t have motion sensors where they are but maybe I can integrate it on the actual node...
        Will give it some thought.
        Thanks! :D
