  3. Gateway - Ethernet stops
2 Posts 2 Posters 1.3k Views 2 Watching
  • O
    O
    olaeke
    wrote on last edited by olaeke
    I got a problem that the Ethernet card sometimes (actually very often) just turns "off", all the leds stops blinking so it looks like dead. If I unlug the networkcable and plug it in again then all leds start to blink again. However I can't ping the IP adress until I have done reset on the Arduino.
    I use one 5v 2A powersupply for 2 Arduino, 2 Radio, 1 Ethernet module and one 433MHz transmitter. Could it be to little with 2A for this? Have
    Anyone else experienced the same or similar problem?
    T 1 Reply Last reply
    • O olaeke
      tbully
      @olaeke I would think you may be pushing it. Any way to use a few separate supplies for a short time to see if that helps? If you decide to just upgrade your supply, you may want to put caps on the radios to help stabilize the bus.
