  3. OpenHAB
  4. OpenHAB 2.3 and MQTT
7 Posts 4 Posters 2.9k Views 4 Watching
    martim
    wrote on last edited by martim
    Hi All,
    I am very new to openHAB and I have a lot of problems installing/configuring openHAB 2.3 so that mysensors are working. Does anyone have a guidline how to install this?
    It seems that MQTT connect well but I got an error which I do not understand. I am already busy with it for days but I do not get it working. Unfortunatly I am not able to find openHAB 2.2 img so that I can install this on my PI.
    Anyone willing to help me?
    Error:
    2018-12-07 20:23:01.046 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:gateway' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): org/eclipse/smarthome/io/transport/mqtt/MqttActionCallback
    ==> /var/log/openhab2/openhab.log <==
    2018-12-07 20:23:01.025 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while initializing handler of thing 'mysensors:bridge-mqtt:gateway': org/eclipse/smarthome/io/transport/mqtt/MqttActionCallback
    java.lang.NoClassDefFoundError: org/eclipse/smarthome/io/transport/mqtt/MqttActionCallback```
    TheoLT 1 Reply Last reply
    • M martim
      Hi All,
      Error:
      TheoLT
      TheoLT
      TheoL
      @martim I'm sorry myFriend. I've tried OpenHaB a couple of years ago. But in those days I couldn't get it to work. To complicated for me. That's why I've switched to Domoticz. That does what I need. You could give that - or another controller - a try. OpenHAB is overly complicated if you ask me.
      • G
        G
        Guillermo Schimmel
        I'm using mysensors with openhab and mqtt and works great.
        Check your config files!
        Let's take a look at your mqtt.cfg.
        Which broker are you using? I'm on mosquitto.
        M 1 Reply Last reply
        • G Guillermo Schimmel
          martim
          @guillermo-schimmel
          Could you check here? I am really getting frustrated by the OpenHAB :)
          https://forum.mysensors.org/post/95623
          G 1 Reply Last reply
          • M martim
            @guillermo-schimmel
            G
            G
            Guillermo Schimmel
            @martim I would recommend you to use plain mqtt.
            Don't use the binding or the bridge stuff. Once you have the mysensors-mqtt, use plain mqtt items on your openhab config and it will work great.
            I already have several sensors this way.
            Perhaps after openhab 2.4 I will play a little with the binding and then I could be more useful to you.
            • G
              G
              Guillermo Schimmel
              wrote on last edited by Guillermo Schimmel
              Just for you to know, I just updated to 2.4 and can confirm that with the new mqtt binding I can connect with mysensors.
              You have to create the MQTT Broker think via the web ui and then each thing, finally you have to modify your items, like this:
              //Contact GaragePorton "Portón Garage [%s]" <garagedoor> { mqtt="<[mosquitto:mygateway1-out/11/3/1/0/16:state:default]" }
              //Contact GaragePuerta "Puerta Garage [%s]" <door>       { mqtt="<[mosquitto:mygateway1-out/11/4/1/0/16:state:default]" }
              Contact GaragePorton "Portón Garage [%s]" <garagedoor> { channel="mqtt:topic:efe295fe:porton_garage" }
              Contact GaragePuerta "Puerta Garage [%s]" <door>       { channel="mqtt:topic:efe295fe:puerta_garage" }
                momo90
                Use this tutorial for OH 2.3 and mqtt
                https://www.smarthomeblog.net/diy-home-automation-sensors/
                Was working for me
