1.1k Posts 105 Posters 790.4k Views 98 Watching
  • B boozz
    @berkseo
    I do not want to be too offensive, but it seems to me as if your skills in electronics and 3D-printing is way better developed than your trust in the plumbing :sweat_smile:
    Now for the serious part: how often do you experience water leaks? And how long do the batteries in this design last?
    Boozz
    @boozz serious water leak heppened once in 40 years
    B 1 Reply Last reply
      B
      B
      boozz
      @gohan
      I was referring to @berkseo 's situation and images/examples. I just wondered why this person would put this amount of effort in creating a device that would probably not be functional at the moment it should be functional. I'm just thinking about corrosion of the pcb, a drained battery, change of properties of the 'sensor' due to time-effects etc.
      Do not misunderstand me: I'm absolutely enthousiastic about this device (and I'm impressed by how small it is and the design), but I'm a bit concerned about the effects that could negatively affect the behaviour of it.
      Nca78N berkseoB 2 Replies Last reply
      • B boozz
        @gohan
        @boozz said in What did you build today (Pictures) ?:
        @gohan
        You can see on the picture he already had a leak under his kitchen sink :p
        And in some countries pipes installations are not very reliable, for example yesterday evening my dishwasher emptied on the floor because the workers did not glue the PVC pipe angle so it went away. Would have love to be warned at the first drops instead of realizing it much later when walking in water in the middle of the kitchen. I also had problem with drinkable water fountain not stopping when tank was full and emptying the 20l bottle on the floor, leaks of sinks and bathtub in the bathrooms in previous apartment, etc etc
        So there's truly a "market" for those sensors, they could also be slightly modified to make rain detection instead and warn you if rain is coming and some windows are still opened (very useful here in tropical weather when you can switch from sunny to tropical rain in a mater of minutes).
        And if you use the low power comparator of the nrf5 it uses only a few uA in sleep mode, easily detects a bit of water between the 2 contacts and can last for 1-2 years on button cell.
        • Nca78N Nca78
          @gohan
          zboblamontZ
          zboblamontZ
          zboblamont
          #816
          @nca78 I suspect what @boozz is referring to is not the functionality but the direct effect of water on the device.
          Pretty sure a pair of threaded socket bolts could be swapped for the cover screws and permit wall mounting on a couple of threaded SS electrodes to solve it though, and it would still make for a very compact and unobtrusive arrangement.
          • K
            K
            kimot
            wrote on last edited by kimot
            #817
            I think very useful device.
            Stainless screw like detectors - no corrosion.
            And all the time this device sits in dry area - no corrosion.
            But software must call controller ( with battery level for example ) sometimes, say one per a day, to inform it is alive.
            And if controller does not receive this message - sends alert.
            I am using this for all my nodes - very easy in Domoticz.
            If node dies, Domoticz send me e-mail ( and SMS ) with information.
            And 40 years with this hoses for example ?
            Try it .....
            • K kimot
              Try it .....
              zboblamontZ
              zboblamontZ
              zboblamont
              #818
              @kimot I followed your logic until you suggested 40 years in the future with presumably failed wash hand basin umbillicals..
              K 1 Reply Last reply
              • berkseoB berkseo
                My new micro-sensor water leak ready. Powered by NRF52832-CIAA
                7_1562099024631_photo_2019-07-02_19-55-19.jpg 6_1562099024631_photo_2019-07-02_19-51-25.jpg 5_1562099024631_photo_2019-07-02_19-49-52.jpg 4_1562099024631_photo_2019-07-02_19-49-51.jpg 3_1562099024631_photo_2019-07-02_19-49-51 (2).jpg 2_1562099024630_photo_2019-07-02_19-49-50.jpg 1_1562099024630_photo_2019-07-01_02-46-18.jpg 0_1562099024629_photo_2019-07-01_02-45-11.jpg
                cr2032, ... ~3μA consumption
                sindrome73
                @berkseo I'm sorry if I can, but what kind of sensor are you using to detect water ?? I would like to do something like that but with an Arduino pro !!
                berkseoB 1 Reply Last reply
                • B boozz
                  @berkseo
                  Boozz
                  berkseoB
                  berkseoB
                  berkseo
                  #820
                  @boozz A leak of water in my memory occurred two or three times. Yes, this is not a common problem in the modern world. But sometimes it is enough once. And here it is important how this leakage will be quickly detected and, accordingly, the source of water supply will be blocked. And one more thing: insurance can not cover everything. One situation is when it’s a country house, but for example in Moscow I live in an apartment on the 6th floor, that is, there are 5 floors below with apartments, and I may have to pay for repairs in these apartments.
                  Now I have three sensor options: on a cr2032 battery, on a cr2477 battery, and on a 2 / AA (14250) battery with an amplifier.
                  The devices consume 3 micro amperes in a dream :) , on conventional radio modules they consume 7–9 milliamperes while the transmission is running, for modules with an amplifier of 24–26 milliamperes, and I can programmatically decide when I should turn on the amplifier.
                  2_1562761536405_IMG_20190710_142956.jpg 1_1562761536405_IMG_20190710_142942.jpg 0_1562761536404_IMG_20190710_142758.jpg
                  • B boozz
                    @gohan
                    berkseoB
                    berkseoB
                    berkseo
                    #821
                    @boozz It was just a photo session in various locations :).
                    The pcb, of course, will be coated with acrylic varnish. Stainless steel contacts are used. Conclusions do not have direct contact with the ground, there is a gap of about 0.5-1mm. Button holes are made from below, but look at how it is done in the photo. Well and places where leakage is possible, usually should not be wet, otherwise a mold and td. If there is moisture, then it is somehow better to eliminate :).
                    • S sindrome73
                      berkseoB
                      berkseoB
                      berkseo
                      @sindrome73 said in What did you build today (Pictures) ?:
                      Used by SN74LVC1G00. Recently I was asked for this scheme in myssensor_rus telegram-chat. I drew it by hand in PAINT, I can offer it to you. I apologize, but nevertheless it is a scheme :)
                      S bjacobseB 2 Replies Last reply
                      • zboblamontZ zboblamont
                        K
                        K
                        kimot
                        @zboblamont said in What did you build today (Pictures) ?:
                        umbillicals
                        It is rubber hoses with metal braiding.
                        But rubber degrades and this equipment is the most common cause of water leakage.
                        • berkseoB berkseo
                          sindrome73
                          @berkseo thanks for the scheme. but therefore don't use a sensor ?? i'm sorry noni and clear how do you detect the presence of water ...
                          • S sindrome73
                            @sindrome73 the sensor is the two screws. Without water, the elevtrical between the screws is very high. With water, the electrical resistance is lower.
                            S 1 Reply Last reply
                              sindrome73
                              @mfalkvidd ok now I understand, and then commands an Arduino or other. thank you
                              • K kimot
                                umbillicals
                                zboblamontZ
                                zboblamontZ
                                zboblamont
                                @kimot The elastomers used are resilient and will last decades from new, never seen one burst yet. Most folks remodel bathrooms every 5-10-20 years and should replace these at the same time, which was why I chuckled at the 40 years.
                                With the technology and battery longevitity available nowadays, they are certainly a handy device to have where problems have occured or may.
                                • berkseoB berkseo
                                  bjacobseB
                                  bjacobseB
                                  bjacobse
                                  @berkseo
                                  Clever idea to use SN74LVC1G00 as while both inputs are same voltage it only consume ICC = 10uA (10 mircoA) in whole voltage range 1.65V -5,5V
                                  berkseoB Nca78N 2 Replies Last reply
                                  • bjacobseB bjacobse
                                    @berkseo
                                    berkseoB
                                    berkseoB
                                    berkseo
                                    @bjacobse said in What did you build today (Pictures) ?:
                                    Power consumption of the entire device in a sleep - less than 3 mircoA.
                                      @berkseo
                                      @berkseo
                                      Not when when you have a low power comparator available that runs with only 0.5µA...
                                      • berkseoB
                                        berkseoB
                                        berkseo
                                        Wireless expansion module for very cheap soil moisture sensor from Aliexpress :)
                                        https://youtu.be/Toto1Cw4QBo
                                        • zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          Finally the round-tuit UPS got built after the last power cut clobbered the Controller/Gateway system, lesson learned...
                                          Meanwell AD-55A, 7.2Ah Acid gel battery, two usb 5v buck converters, a spare socket for raw volts, and a 15 euro IP66 box from the local shops.. Some drilling and filing to the lid, couple of brackets, spare bolts, banding, soldering and hot glue...
                                          A bit bulky, but disappears in a void under the stairs, two tiny drill holes let the buck converter leds shine threw...
                                          No monitoring as yet, but sailed through a power cut this morning and the Pi didn't skip a beat.. First up is the Pi's RTC then can put the cover back on the Controller...
                                          tbowmoT W 2 Replies Last reply
