  2. Enclosures / 3D Printing
  3. Best 3d printers
Best 3d printers
106 Posts 30 Posters 34.1k Views 28 Watching
  • C
    C
    Crumpy10
    Thanks everyone, good advice. A bit of trial and error learning, with a vertical learning curve...
    Looks like I may go for either the Creality CR10 or the Ender 3, then have a play printing some existing items to see whats possible before I do my own designs.
    • skywatchS skywatch
      @homer I think you've made a good choice - good luck with with your new source of frustration and learning! :)
      If it turns out you don't like it, feel free to send it to me (Heeeee) ;)
      From experience though, test out your printer with something simple from thingiverse.com and see how it goes....
      For me the following were the areas I had problems with at first.....
      1. Bed leveling - this has to be right to get the first layer the same thickness.
      2. Bed adhesion - I had 'lifting' problems that took a while to sort out.
      3. Supports - You'll get a feel for where and when to use supports, it takes a little trail and error though....
      HomerH
      HomerH
      Homer
      @skywatch said in Best 3d printers:
      Thanks mate! So far I'm liking it, so I'm sorry to say that I won't be sending it to you anytime soon haha
      So far I've printed 3 things. The first was the cat that was on the SD card, and this came out perfect. I used the filament that came with the printer. My next two models were the same, a sign for two of my kids who play Fortnite. The object was quite flat but spread across the bed. Each was printer with different filament. The first lifted very badly but not bad enough to use. The good thing was that this print was nice and easy to remove from the bed haha. The third printed perfectly but wow it was extremely difficult to get off the bed!
      I do have an issue with leveling. The bar that holds the printer head, no matter what I do in the way of adjustment, the right side is close to 3mm higher than the left. I'm in the process of having this addressed with who I bought it from, but at this stage all they are saying is to level the bed automatically, which seems to be working fine, but I don't know how it will go with taller prints.
      I would like to start making my own boxes for my Mysensors, but don't know what program to use. I've never done this sort of thing before, so at the moment I'm a little concerned about the learning curve, so if you or anyone knows of a program that is simple to use for this purpose, please share what it is!
      skywatchS 1 Reply Last reply
      • HomerH Homer
        skywatchS
        skywatchS
        skywatch
        @homer said in Best 3d printers:
        Thanks mate! So far I'm liking it, so I'm sorry to say that I won't be sending it to >you anytime soon haha
        Awwwww.... :(
        I would like to start making my own boxes for my Mysensors, but don't know >what program to use. I've never done this sort of thing before, so at the moment >I'm a little concerned about the learning curve, so if you or anyone knows of a >program that is simple to use for this purpose, please share what it is!
        As I said, try tinkercad. It's a free online 3D design tool that will give you a good taste of 3D design and the features you may want/need in a full paid product.
        You probably won't stop printing now for at least 6 months! ;)
        • C
          C
          cyberchuckTX
          I bought a PowerSpec Wanhao Duplicator Prusa i3 Plus and am quite happy with it (see https://www.microcenter.com/product/486543/wanhao-duplicator-i3-plus-3d-printer ).
          Several things to consider:
          • There are a LOT of great 3D communities for 3D printers; check out "Wanhao" on Thingiverse to see parts you can print to upgrade your printer(s) ( http://www.thingiverse.com/search?q=wanhao&dwh=995d35d8e0e03d1 ).
          • Check with your local makerspaces (Houston has 13 Makerspaces, I'd check with the major ones like TXRX Labs ( https://www.txrxlabs.org/ ) who not only can advise you on printers but may actually sell kits made by members.
          • C
            C
            Crumpy10
            wrote on last edited by Crumpy10
            #34
            Ok, so I got my hands on an Ender3 printer. So far so good, very impressed for the price. But could someone tell me what causes this?0_1564479120229_96D400A1-4B43-462F-8160-F1A376C13888.jpeg
            YveauxY bjacobseB NeverDieN 4 Replies Last reply
            • C Crumpy10
              @crumpy10 bad adhesion to printer bed, mixed with inconsistent filament extrusion.
              See this page for 3d printer troubleshooting : https://www.simplify3d.com/support/print-quality-troubleshooting/
              • alowhumA
                alowhumA
                alowhum
                Woule the Mirobot in theory be capable of working like a 3D printer?
                https://www.kickstarter.com/projects/mirobot/mirobot-6-axis-mini-industrial-robot-arm/faqs
                bjacobseB 1 Reply Last reply
                • C Crumpy10
                  bjacobseB
                  bjacobseB
                  bjacobse
                  #37
                  @crumpy10
                  Looks like your skirt are fine (The round first prints) but inside your print you get to little PLA through your nozzle
                  is temperature correct?
                  is is a good source from PLA? or is it that came along the 3D printer, then swap and use new PLA
                  If you have Bowden extruder, is it extruding correctly? maybe the gear slips
                  And then maybe is your bed 100% calibrated?
                  I don't think your nozzle is clogged as the skirt looks ok
                  • alowhumA alowhum
                    bjacobseB
                    bjacobseB
                    bjacobse
                    @alowhum
                    NO it can't be used as 3D printer, it's not accurate enough
                    QA from their homepage:
                    Would it be possible to place circuit components on circuit boards using this arm or does it not have enough precision?
                    Yes, the repeatability is 0.2mm, This is enough for PCB soldering.
                    My 3D printer, zonestar 802 have this accuracy:
                    XY-Axis Positioning Accuracy: 0.012mm
                    • alowhumA
                      alowhumA
                      alowhum
                      @bjacobse thanks!
                      • C Crumpy10
                        bjacobseB
                        bjacobseB
                        bjacobse
                        @crumpy10
                        Try FIRST to level your bed - PLA can't stick to air if you have too much distance between nozzlehead and bed.
                        • V
                          V
                          vseprosto90211
                          I like Monoprice's Maker Select Plus, because it proves the fact that you don't need to spend a fortune to buy a good 3D printer. It has a large build area, a heated bed and can handle lots of different materials. Maybe you should also pay attention to this one.
                          • C Crumpy10
                            #42
                            @Crumpy10 said in Best 3d printers:
                            Your print head is too high: you need more "squish" on the first layer. Evidence: the print lines need to meld into one another without gaps between them and be flatter than what your picture shows. Running a calibration should fix this, though you can also do an "on the fly" adjustment if you notice it starting badly, generally when printing the skirt.
                            I have a Prusa 3 modded to use an all copper heatpath so that it can print faster than the stock version. An Ender 3 seems perfectly good though, and for the same money you can own more than one and parallel print. :eye:
                            If I were to upgrade further I'd build an enclosure to make it quieter and run some kind of hepa carbon air filter on it to minimize emissions, regardless of what brand I owned. The last I checked (around a year or so ago) there weren't any good kits for that except for one that was priced sky high for schools or corporate use.
                            • alowhumA
                              alowhumA
                              alowhum
                              #43
                              @alowhum said in Best 3d printers:
                              https://www.cnx-software.com/2019/04/22/zonestar-z6-entry-level-portable-3d-printer/
                              I bought the Ender 3 (non-pro). It's my first 3D printer. So far it's great. I'm going to add an Mini E3 board to decrease the high-pitched noise from the stepper motors. I also bought a $9 3D Touch, a fake BLTouch, for auto bed levelling. Although it's not really needed? The bed has remained stable. Then I'll install that following this guide.
                              I've also used a Pi Zero W I had lying around to install Octoprint. No more hassle with SD cards. There's even a plugin called "Spaghetti Detective" that uses machine learning to watch webcam images of your print being made. If your print goes wrong, it automatically stops it.
                              • dzjrD
                                dzjrD
                                dzjr
                                MySensors Friends,
                                I also plan to finally purchase a 3D printer.
                                What do you recommend for a beginner right now?
                                What do I want to make?
                                Enclosures for sensors.
                                small parts .
                                and who knows what else in the future.
                                So I am looking for a 3D printer that I can gain experience with as a beginner.
                                  not too small, maintenance friendly, but that does not mean that I do not want to carry out maintenance.
                                I don't really know yet what material I want to print with, what is the best and most versatile material to start with?
                                Thank you in advance for your advice and thinking along.
                                dzjr
                                P 1 Reply Last reply
                                • dzjrD dzjr
                                  MySensors Friends,
                                  small parts .
                                  dzjr
                                  P
                                  P
                                  pptacek
                                  @dzjr it depends what do you need it for. This is my 2 cents on 3d printing at the moment.
                                  If you need to print something small with high detail, get an SLA printer like Elegoo Mars. It is cheap, easy to understand and resolution is amazing. Prints out of the box, but it is messy and smelly.
                                  Otherwise:
                                  1. You are a complete noob, you have no clue how that stuff works, you just want to print. Get Prusa and print PLA. Basic printer, not great but reliable and great company support and great community.
                                  2. You are a complete noob on a budget but willing to learn. Get Ender 3 and print PLA. It is basic, cheap, but gets a job done. Community support is great, but expect you will have to tinker with the printer.
                                  3. You are a moderately experienced in tech and you need a workhorse. Get FlashForge Creator Pro or similar and print PLA, PETG or even ABS. Community support is great, that thing is an older design but it just works.
                                  4. You are moderately experienced, with special (tinkering) demands. Here it gets very personal. There is a bunch of RepRap style printers with a moving bed (which I hate). There are some deltas (why??) and there is growing number of CoreXY printers of various sizes (Two Tree, Elf, Tronxy...). I would probably go that route. Stick with PLA and PETG.
                                  5. Geek with time, resources, and curiosity. Build your own CoreXY printer. Voron, Railcore, etc. Print what you want.
                                  I skipped 1) and 2) and went through 3) - 5). I personally own Elegoo, FlashForge CP, Elf, and CoreXY of my own design.
                                  dzjrD 1 Reply Last reply
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    #46
                                    @dzjr have a look here:
                                    https://www.reddit.com/r/3Dprinting/comments/gdbu1o/purchase_advice_megathread_what_to_buy_who_to_buy/
                                    I think the 'consensus' is that these are the beginner printers to go for currently:
                                    Under $200
                                    Ender 3. It's recommended as a cheap beginners machine. This does not have any automation features though, such as automatic bed levelling, detecting if your fillament runs out, etc. Although you can add those if you want. It's also quite noisy.
                                    Above $200
                                    For a more hassle free experience I believe the Prusa i3 Mk3S is the recommended one to go for. It's more expensive of course, but you get a lot of that automation.
                                    It also depends on what material you want to print. Woodgrain filament cannot be used with the Ender's default extruder, for example, it will damage it. Something worth checking before purchase is it it can print flexible filament. That stuff is amazing! In general it seems ABS filament has become very unpopular.
                                    Don't worry too much about things like touch screens. You'll likely want to get a Raspberry Pi and install Octoprint on it. That way you can send prints to your printer and monitor its progress without having to babysit it. You don't want to be sitting next to those fumes and the noise all the time.
                                    Also don't worry about flexible removable magnetic printer beds. From what I can tell glass beds offer the best quality for things like PLA, which is what you'll most likely be printing in generally.
                                    Whatever you do, go for a printer that has a large community of users. If you go on websites like Thingiverse you'll immediately notice which printers are popular. If you look at the most popular new 3D print designs you'll currently find a lot of Ender specific creations.
                                    • A
                                      akyle32
                                      Im using the Monoprice 3D Printer the price is below $200. I bought it a few months ago so Im not sure what its price today. 3d printing is a really fun hobby. If you need more 3d printer options, you should check out this website.
                                      • P pptacek
                                        Otherwise:
                                        dzjrD
                                        dzjrD
                                        dzjr
                                        wrote on last edited by dzjr
                                        #48
                                        @pptacek
                                        Thank you for your response to my message,
                                        It took a little longer on this side because my work took a lot of time this week.
                                        1 & 2 will not apply to me either, I may not have 3D printing experience, but I have enough technical skills to adjust and assemble something, but I don't want to be able to print something first. half an hour to adjust everything.
                                        So if I see your message like this, it would end up on the Ender 3 (Pro?) Or the Flashforge Creator Pro.
                                        I was thinking of max € 500 myself, but is it worth the price difference of about € 400?
                                        Ender 3 = € 180
                                        Ender 3-Pro = € 235
                                        Flashforge Creater Pro = 625
                                        • alowhumA alowhum
                                          Under $200
                                          Above $200
                                          dzjrD
                                          dzjrD
                                          dzjr
                                          @alowhum
                                          I have read through part of the link, and keep reading that the Ender-3 (pro) would be the best choice?
                                          Of the Prusa i3, I read on the Dutch platform Tweakers.net that there are some safety aspects, so would the power supply not be fireproof?
                                          So if I see your message like this it would end up on the Ender 3 (Pro?)
                                          Also thanks to @pptacek's response
                                            How did you mean the touch screen? do you mean that you actually have to replace the controller with a Raspberry pi?
